Question about Landice L 7 Club Cardio Trainer Treadmill
Treadmill shut down (L7 cardio)
I finished a distance program. When the program completed. the treadmill just totally shut down. The safety key is in, but no power is going to the treadmill.
  • Howard
    Howard May 11, 2010
    when you do a program you lose all power to the unit. normally when a program finishes the treadmill stops and give you you information. you reset it and then you on your way again.
4 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: Landice L7 gives me a L5 reading on the screen
Your L7 error looks like L5 , but its really LS which mean lost signal. Unplug unit take motor shroud off then plug unit back in wall outlet. When looking in front unit you will see a Motor control board and there are LED lit up one of them should be an amber light this is you speed sensor which is attached to the top of your motor. Manually rotate the fly wheel and see if that light flickers if it does then your speed sensor is working properly if not replace speed sensor. The next thing to look at is the motor brushes to if they are worn unplug unit you should see slitted caps on both side of motor remove them if they are less than 3/8" they need replacing. That for the most parts should take of your problem. Call Landice @ 1800-526-3423 have the serial# handy their on all the components in the unit
Posted on Feb 28, 2010
SOURCE: the treadmill comes on but but the belt doesnt
At first glance, It looks like a lower control board issue and/or motor issue (more likely lower control board).
Before calling Landice I would check all the connections to the Lower control board. I would also check under the display overlay if all the connections are good.
I know it is not much, but I hope it helps.
Posted on Mar 05, 2011
damneddle
  • 1607 Answers
SOURCE: When I turn on the
According to Landice, this is usually an indication of a speed control malfunction. The upper board is not recognizing a signal pickup from the speed sensor. This could be due to the speed sensor being misaligned, improper connection, or bad speed sensor.
You need to service it. Or if you are a technical guy, you can use this guide:
Landice Service Manual
Posted on Sep 09, 2011
When I press start the treadmill goes for about 1second and stops. Incline/decline works, no error messages. Red flashing light on the control board after the treadmill motor quits. Stops flashing if I...
Contact the store where you bought it. I'm sure your treadmill is covered by the warranty.
Anyway, the next time buy some high quality treadmill to avoid any hassle. I like the treadmills reviewed here: http://www.your-workout-routine.com/cardio/best-treadmills-2014/
Nov 14, 2014 | Exercise & Fitness
Bremshey treadmill maintenance,treadmill wont run until i have safety button pressed in
Your treadmill should not run without the safety button pushed in, or safety key in. this is to shut the unit down if you were to fall.
Sep 21, 2013 | Exercise & Fitness
Factory reset code
follow this instruction and reset. God bless you
Unplug the treadmill. Locate the console key and place the
safety or reset key into the treadmill console. Replace any parts that
need replacing, or move on to the next step.
  • 2
    Locate the reset switch on the underside of the treadmill
    console. Usually the button is large enough to trigger with a pencil
    eraser or Q-tip. Plug the treadmill plug back into the wall. Use the
    Q-tip to press the reset button. It may be necessary to hold the reset
    button down for a few seconds. "CL11" will appear in the display of the
    treadmill.
  • 3
    Press the reset button one more time with the Q-tip. "CL21"
    should appear on the screen. Press the enter key. The display will
    change again and show "CL22." Keep pressing the enter key until the
    numbers cycle through to the number "CL26." Press enter one more time.
    The letter E should appear on the display screen.
  • 4
    Press enter twice more. The letters "SS" should appear on
    the screen. When this happens, press the start/stop key. Making sure to
    keep well away from the tread, press enter to start the treadmill. The
    treadmill will start on its own. The treadmill will stop on its own
    after a few seconds. When it stops, press the power key two times.
    Remove the safety key and put in a safe place. Your treadmill is reset.
  • Read more: http://www.ehow.com/how_5731107_reset-treadmills.html#ixzz2Z4hlSTfH
    Jul 15, 2013 | Landice L7 LTD Executive Trainer Treadmill
    Two lines appear on the console screen and incline starts going up, then when key is removed all lights go on but nothing works.
    I assume you are talking about the safety key. It should have a string attached to it and a clip on the other end of the key's string.
    The key is a safety feature and the key should be in the control panel and the clip attached to your shorts or shirt when you are using the treadmill. If you fall of the treadmill, the clip pulls the string and the key is pulled from the panel on the treadmill. This should stop the treadmill instantly by cutting main power to the unit. Main power is shut off because the key is a safety device and it MUST work every time. To help avoid design errors or unreliable stops when the key is pulled, a good designer will shut everything off, not just the motor for the tread belt. I would say your unit was designed by a good design team since everthing goes off when the key is pulled.
    From my point of view, it is working as designed unless you are talking about a different key.
    I know someone who did not wear their safety key and they slipped on the treadmill, the treadmill threw them into the wall behind the unit and they were stuck with their leg against the treadmill. The belt on the treadmill wore their skin down to the bone on their knee in only a few seconds. Lesson one, keep your treadmill at least 3 feet from the wall. Lesson 2, use the safety key and clip.
    -Mark
    Jul 17, 2011 | Reebok V 680 Treadmill
    Nordictrack exp 1000 xl not shutting off
    Your treadmill is in "Demonstration mode".
    Here are the instructions to shut it off.
    First you must enter "Information mode".
    To select the information mode, hold down the Stop
    button whilst inserting the key into the console. When
    the information mode is selected, the following information
    will be shown:
    Total number ofhours that the treadmill has been used.
    The Distance/Incline display will show the total number of miles.
    An "E," for English miles, or an "M," for metric kilometres.
    If a "d" appears in the display, the console is in the "demo" mode.
    Press the Speed - button so the Heart Rate/Calories display is blank.
    To exit the information mode, remove the key from the console.
    Please be advised, when the safety key is removed THE TREADMILL IS NOT SHUT OFF, only the console is shut off. You must turn the machine off using the power switch in the front of the machine near the power cord, or I recommend purchasing a power bar with a power switch and turning the power off at the power bar.
    Mar 01, 2011 | Nordic Track Exercise & Fitness
    Stuck in safe mode
    Error Code: Replace Safety Key (SAFE)
    Meaning: Safety key is not recognize
    Diagnostic: Replace safety key
    If problem persist replace upper display board
    you should also try cleaning the area where you insert the key magnetic
    Sep 11, 2010 | Landice L 7 Club Cardio Trainer Treadmill
    Just bought from store press reset button it lights up but does not display after or start
    Make sure the safety key is inserted this engages the power up sequence for the unit to start operating. Also as a simple test try to get the unit into calibration mode by pressing the stop and speed up buttons at the same time while inserting the safety key Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. Press either incline key and the incline will calibrate automatically. BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON THE WALKING BELT. Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window). After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing. Press the Stop key once and remove the safety key.
    If either attempts fail then call the store where you purchased the treadmill, either have them send a service tech out or exchange theunit.
    Jun 26, 2010 | Weslo Cadence Ct 5.8 Treadmill
    Will not move belt
    Press the Stop and the Speed Up keys down while inserting the safety key.
    If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled. The max speed potentiometer is a small square with a mobile center and is located in one corner of the board and is labeled MAX SPD. It is near the harness that carries the speed signal labeled H,W,L. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments. It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure. THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED. After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing. Press the Stop key once and remove the safety key.
    May 27, 2010 | Proform 560hr Treadmill Walking Belt
    Landice L7 motor voltage in wet conditions
    What do you think--what changes when something happens???
    Sep 19, 2017 | Landice L8 LTD Cardio Trainer Treadmill
    Landice L 7 Club Cardio Trainer Treadmill Logo
    Top Landice Exercise & Fitness Experts
    Howard
    Howard
    lloyd cole
    Sportsmith LLC
    Sportsmith LLC
    Are you a Landice Exercise and Fitnes Expert? Answer questions, earn points and help others
