Question about Dryers
Ignites then burner shuts down then rignites over and over wont dry
I have a maytag se 1000 staked gas dryer and after starting ..it ignites for a short time then the burner shuts down for a short time then it reignites do you have any ideas why tis is happening? any help would be greatly appreceated thanks
  • 1 more comment
  • pgrutz1 Apr 13, 2009
    ive taken my vent hose off and ran for 45 min clothes just about dried i think this is my problem... i have about 18 feet of tubing to tear apart and clean i will let you know by tomorrow if this cures it thanks!!!!
  • pgrutz1 Apr 15, 2009
    the dryer did not function properly after cleaning out the exhaust vent i tore the dryer apart to investigate further and found a broken wire on one of the sensors next to the fan motor.. high heat limit sensor? not sure if thats what it is but i fixed the broken wire and now it works like a new one, and my vents are clean so i shouldnt have any dryer problems for awhile i hope!!!thanks !!
  • pgrutz1 Apr 20, 2009
    your solution didnt cure my problem trousertrout. I answered the questions i was asked at the end of my fixya solution.. i didnt mean to bend you all out of shape.. your solution was not helpfull in my case ,,if you take an honest answer personally you shouldnt be answering questions on fixya. i will change it for you..grow up jerkwad!!!!
  • Dryers Master
  • 3,361 Answers
Check your connecting exhaust vent for a blockage.
Remove the vent and run a 45 minute timed dry load and see if it works correctly.
Report back.
Posted on Apr 12, 2009
  • steve
    steve Apr 15, 2009
    So glad you got it working.
  • steve
    steve Apr 19, 2009
    rgputz1 it is most probable that your broken wire occured after the vent removal and satisfactory drying, simply because you would have had exactly zero heat and zero drying with a broken hi-limit wire.
    THANK YOU SO MUCH FOR THE INAPPROPRIATE RATING.
Maytag naptunedryer dryer heating goes off before they get dry
One of your gas valve coil solenoids is defective. There are two of them. One has two contacts and the other has three contacts. They are easily replaced and you can get them fairly cheap on eBay. What is happening is the one good solenoid allows the burner to ignite but after a few seconds the burner is shut down because the second solenoid is faulty. Its a safety feature in most gas dryers. Replacing them should take care of your problem.
Apr 25, 2017 | Maytag Dryers
I have a Kenmore Elite older model dryer that will fire the burner up when started, but when the burner shuts down and then tries to cycle on again, the glow igniter starts but no gas is released and the...
most likely its gonna be your coil kit, but it could also be ur gas valve,but the gas valve is not common. I would go with the silinoid coil kit first, its much cheaper too
Oct 11, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag LP Gas burner problem
are you sure the pin in the gas pressure regulator under the plastic cap and brass nut was turned 180 degrees to set it for propane gas?
Aug 20, 2012 | Maytag Dryers
Maytag mdg6700aww dryer clicks to start the igniter. Sometimes the burner ignites, other it doesn't and I can smell raw natural gas from the vent. Not drying. Help
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 14, 2011 | Maytag Neptune MDG6700A Gas Dryer
I have the Maytag MCG8000AWW gas "drying center", it tumbles but does not have any heat. The burner lights when the cycle is started, and for a few minutes it does heat. Then the humidity indicator changes...
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 06, 2010 | Maytag Neptune MCG8000AW Gas Dryer
I dont' think it is drying my clothes. It's not getting hot?
gas or electric? if electric then probably either plugged exhaust hose or bad element....if gas then probably either plugged exhaust hose or temperature shut off switch or 1 0r both magnets on the gas valve,listen for the burners to ignite,if the burner shuts off afer 1 minute of running then double check the exhaust hose,the burner should run lots longer if working right.
Sep 10, 2009 | Maytag Dryers
The dryer stops heating before the clothes are dry.
Maytag gas dryer MDG7600aww, (Model number corrected). Below is a link, courtesy of www.repairclinic.com showing the parts breakdown and disassembly procedures.
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
This link shows the most likely cause of your issue.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg7600aww-%3d%3di3479&PartID=3479
This link shows the next likely cause of your issue. Remove the front panel and inspect the sensor bar which is located at the 4 o'clock level on the drum bulkhead, ( see the first link for location). Ascertain that 2 wires are connected to it and that black sensor bar is not cracked or broken.
This link will offer more assistance if the above 2 items check good.
http://www.repairclinic.com/0088_8_1.asp#Subtitle_2
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg7500aww-%3d%3di516693&PartID=516693
Aug 22, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag gas dryer model # SDG305DAWW
replace the coils atop the burner assy itself, part number 279834..
Dec 02, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryer is gas model dg212 flame come on but will not stay on long enough to dry clothes
if burner lights but fails to relight after several shut offs suspect burners solenoids change both they come in a kit ..once the solenoids get hot they will sometimes open electrically and fail to reenergize after cool down they will open gas valve and alow burner to reignite..also be sure vent to outside to clean and vent behind dryer is not flattened or kinked has know flame to not be properly burning due to exhaust problems and flame sensor would shut burner down
Sep 16, 2008 | Maytag Dryers
After a few heating cycles the burner does not ignite
The problem you are describing is usually associated with a bad gas valve coil. The dryer runs normally until it gets hot, then starts making a strange clicking noise. After it cools down, the dryer runs normally again. The gas valve coils (there are two of them) usually run about $20 a piece. I recommend replacing both of them at the same time just to be sure. I hope this helps.
Apr 15, 2007 | Maytag MDG3600BW Gas Dryer
Dryers Logo
157 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
