Home | Remote Controls | Philps remote i Need the...
Remote Controls
Problem for Remote Controls
Generic problem for all Remote Controls
Philps remote i Need the codes for cl0...
By MsRock on Sep 10, 2007
i need help with codes for my remote Clo34
Same Problem
Mar 05, 2009
-   i have a phillips clo34 universal and i need to get the codes to a emerson vcr/dvd player -   steventyler1
Jun 26, 2008
-   I have a phillips remote control model #cL034 need code #-   katt_bruce
Jun 18, 2008
-   i need the code for a CL034 Philips universal remote, i need it for a Sharp TV model C25S100
Thanks my email is schwags1228@hotmail.com
-   schwags1228
Jun 14, 2008
-   I have a Philips Uniersal Remote CL034, and i just moved and seem to get it to work with my Manavox TV and Sharp DVD Player. Please help me, these things are expensive and i lost the manual, and cant go buy another. I searched online forever and cant any inforamtion regarding codes for this remote.-   Karlfod
May 27, 2008
-   i nead a cl034 universal remote orper. manual-   ash8427
Best Solution
posted on Dec 27, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
The remote does not have a "Mute" button, what button do I press?
Solution #2
posted on Nov 11, 2008
Very Helpful)
andrewmason
Rank: Apprentice
Rating: 95%, 4 votes
the remote is actually a US2-P63S Go to this website and view information on how to get codes. http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?sct=REMOTE_CONTROLS_SU&cat=REMOTE_CONTROLS_CA&session=20081111175256_67.86.216.34&grp=HOME_ENTERTAINMENT_GR&scy=US&ctn=US2-P63S&slg=AEN its displayed as a package of 2 remotes but if you look the smaller one is the correct one. Look for the get codes for my device link and your all set ! Also look at the user manual pdf to learn how to program the codes into the remote !
Comments:
Nov 11, 2008
- the remote is actually a US2-P63S Go to this website and view information on how to get codes. http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?sct=REMOTE_CONTROLS_SU&cat=REMOTE_CONTROLS_CA&session=20081111175256_67.86.216.34&grp=HOME_ENTERTAINMENT_GR&scy=US&ctn=US2-P63S&slg=AEN its displayed as a package of 2 remotes but if you look the smaller one is the correct one. Look for the get codes for my device link and your all set ! Also look at the user manual pdf to learn how to program the codes into the remote !
Was this helpful?
Yes
No
Solution #3
posted on Jun 02, 2008
Very Helpful)
hobbs32
Rank: Apprentice
Rating: 95%, 2 votes
need codes for remote to work a tv the name of the tv is symphonic
Was this helpful?
Yes
No
Solution #4
posted on Jan 15, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
its the button in the middle with the 'M' on it
Solution #5
posted on Sep 12, 2007
Helpful)
Treehugger06
Rank: Apprentice
Rating: 90%, 137 votes
hi i have the same exact remote and i've been looking for the codes and none of them work but if you feel like taking 5 or 10 minutes out of your day to reprogram your universal remote this is the manual way to do it without a code:
Programming with Code Search Button
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times* it only took me about 60 times**) until the device can change the channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library, until the device changes back to the original station. Pressing Channel Up changes direction to forward again.Finally, press and release the Mute button to install the code.
Was this helpful?
Yes
No
11 people thought this was helpful
Solution #6
posted on Jan 01, 2008
Not Helpful)
DHeinrich
Rank: Master
Rating: 85%, 5 votes
This is very similar to the Phillips SRU2040
I found all the codes work from that unit on this unit.
I think this unit was only sold thru Radio Shack.
David.Heinrich@gmail.com
Was this helpful?
Yes
No
Solution #7
posted on Dec 01, 2008
Very Helpful)
HaloChamp360
Rank: Apprentice
Rating: 100%, 4 votes
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #8
posted on Oct 24, 2009
Not Rated)
chelaba
Rank: Apprentice
Rating: 0%, 0 votes
I found the solution on www.remotecentral.com
1. Press and hold the code serach key
2. Press the key for the device you want to program, on my case TV
3. enter the code, I have a sharp Tv and i used code# 0509 and worked.
4 Press enter
5. try to change the channel or the volume
If doesnt work for you go to the website I used there you can download a document with all the different codes.
Was this helpful?
Yes
No
Solution #9
posted on Oct 17, 2008
Not Rated)
supafly484
Rank: Apprentice
Rating: 0%, 0 votes
how do you "punch through" the volume?
I lost the remote and it is so annoying to have to switch to TV when I need to change the volume
I remember there were instructions on how to do this, but it's not posted as part of the codes.
Thanks for the codes for those who posted them
Was this helpful?
Yes
No
Solution #10
posted on Sep 15, 2008
Not Rated)
djVin
Rank: Apprentice
Rating: 0%, 0 votes
I followed TreeHugger09s' instructions and it worked!! Thank you so much
Was this helpful?
Yes
No
Solution #11
posted on Sep 13, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
you can download the code sheet here: http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/1500115_AD_EN.pdf
or look on my page at a tv code list: http://www.geocities.com/frank+e+m+white/SRU4040_TV_CODES
Solution #12
posted on Jul 17, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
It's the M button in the middle of the directional arrows.
Solution #13
posted on May 12, 2008
Not Rated)
gymbrall
Rank: Apprentice
Rating: 0%, 0 votes
Here is the document you are looking for:
Found it on this site: http://wiki.answers.com/Q/What_are_the_codes_for_a_Phillips_Universal_Remote_Codes_CL034
Comments:
May 12, 2008
- Let me try this again...
Here is the link to the document you need. I found it on this site.
Was this helpful?
Yes
No
Popular Solutions for Remote Controls
Questions and Unsolved Problems for Remote Controls
Answer
What universal remote should I buy to operate my Hitachi Model # CT-7894BC. I have two IR on my... (More)
Answer
The remote control worked the first year, but now it does not, even with new batteries. I have to... (More)
Answer
Looking for a replacment battery for my rc5400, it does not seem to hold a charge after about two... (More)
10 Other Users Have The Same Problem - Continued
Comment by Guest, posted on May 18, 2008
i need codes for my cl034
Comment by Guest, posted on May 12, 2008
hi i just moved my house and i cant seem to find the booklet for my codes. and the discriptuon is phillips clo34 ,30/07 , my wife is not happy,i need help. because if she isnt happy , well you know ;] thanx unhappy chef
Comment by Guest, posted on Apr 07, 2008
after I press mute nothing happens
Comment by Guest, posted on Mar 21, 2008
i use MsRock's solution and it worked except when it came to setting the code with the mute button. I can find the code because it will eventually change the station but only once and then I have to go through it all over again.
Comment by Guest, posted on Nov 23, 2007
remote sucks no support from Philips
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Remote Controls:
Top Remote Control Experts
Rank: Guru Guru
Solutions: 696
Experience: 30 Years of professional repair and design.
Ask Me
Find more Remote Control Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
