Question about KitchenAid KP2671 Professional 6 Series Stand Mixer
The mixing part of mixer not working motor is fine
Hi. Ok so my Kitchenaid pro 6 quart mixer starts and look like it working but when I try for example mixing a cake batter while it just has the flour it mixes as soon as I add more ingrediants like water and eggs the thicker the batter the motor still runing but the bottom mixing part gets stuck or dont mix. I took it apart but cant seem to figure out whats wrong. model #KP2671GR
  • madriz13 Apr 24, 2009
    I took it completely apart and I did look at the transmission housing but could not see any cracks but the gears do seem to be worn so I am going to order a new transmission housing and the gears hopw this fixes the problem. Thank you for your help.
  • 135 Answers
Hi. Since I can't tell how much you have taken apart, I'll start from the beginning.
Remove the silver band, remove the top cover. At the top front of the mixer locate the transmission housing. If it's plastic, inspect it carefully for cracks around the screws and the body of this housing. If you find cracks, you have found the cheap plastic part that kitchenaid still installs in new mixers, and the cause of your trouble. They know that it's substandard but don't care enough to place a recall notice on this part. It may not please you to know that their replacement part is METAL like the original part should have been. "For the way it's made"! Indeed!
If you intend to repair the mixer yourself, go to kitchenaid's website, enter your model # and locate the parts list for your mixer. Download the drawings, they will assist you with your project.
Be sure to tell kitchenaid what you think of their cheap plastic part.
If this solution has assisted you, please rate it. Good luck! ricardok45
Posted on Apr 19, 2009
I own the 6 QT Stand mixer. Is there a Is there a 4 or 5 qt bowl that works with this mixer?
Kitchenaid does not make a 4 or 5 quart bowl that would fit your 6 quart mixer, but other 3rd party companies do!
You may be in luck.
I haven't seen this bowl in person, but it apparently will fit your 6qt mixer. Here is a link to a page selling the mentioned attachment. It comes in a set, with appropriate wire-whip attachments:
http://www.chefscatalog.com/product/25686-kitchenaid-3qt-stainless-bowl-and-whip-set.aspx
Jan 13, 2015 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
Kitchenaid kp26m1xer won't turn on
If the mixer died completely and no noise at all comes from the machine you need one of three things.
1. New brushes2. new speed control switch3. a new motor.
The KP26 is a 6 quart mixer of the new design, post 2002, it is easy to work on and relatively inexpensive for parts if it turns out to be the motor that will be about $100.00, the speed control about 30.00, the brushes on this mixer cannot be replaced you have to install a new motor, sry about that. Hope this helps let us know. But first check that the electric outlet you are working from has not tripped the breaker on the circuit too. I know I know it's silly to say but check the outlet first before you spend a dime on anything.
Mar 11, 2013 | KitchenAid 32685 Mixer
325 k5ss mixer stir speed not working, but works in all other gears
First congrats on the great mixer that you have. next the pro 6 or professional 600 series mixers are of an entirely different design than the one that you have even though they are both bowl lift. Do you really need 6 quarts capacity? The pro series is a 575 watt mixer BTW, and it will have more power available to you IF you are doing bread or a lot of food grinding, if that is a requirement that you have then the 6 / 600 series is the better suited mixer but if all you are doing is general medium to light mixing duties then fix and keep the K5SS it a great machine,
Mar 02, 2013 | KitchenAid K5SS Heavy Duty Commercial...
Kitchenaid mixer 600 won't turn on
bread is very tuff on mixers. always buy the strongest mixer that you can afford. im guessing the field in the motor fried.
Feb 07, 2013 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
KitchenAid stops working when anything other than liquid is in the bowl..
There is a non metal gear inside the motor head that is stripped and no longer engaging the worm drive. What happens when you try to assist the turning process (try it only on stir speed, sloooowwwww) if it starts to turn and then stops again then it is the gear I spoke of. It will require tearing down the machine, cleaning all old grease, to insure that you have no ground up parts in the grease, then replace the grease gasket and gear. Hope this helps
Jan 11, 2013 | KitchenAid Professional 600 Series 6-Quart...
My KitchenAid mixer will not turn it makes a loud noise.
thebsjunk - I don't know if you've canned the old mixer. If you've bought a new KA, congratulations to Kitchenaid. If you haven't, there's still a possiblilty that you might be able to fix it yourself. (For the price of KA mixers you'd think they's last a 'lifetime', but alas, KA quality is sorely lacking from their current products...but I editorialize.)
It's quite possilbe that you've had a gear tooth break in the transmission, which would lock up and prevent the planetary gear (agitator) from rotating in mixing bowl. This is what happend to my wife's 6 Quart Pro KA mixer. Since it was out of warranty, I decided to troubleshoot myself. First I downloaded the Parts List manual from the KA website so I knew what to expect. Then I easily disassemble the mixer to find that a bevel gear tooth had broken. After ordering the correct parts, and reassembling, it works better than when we first upacked it. The loud whining is absent...
If the motors gone bad, you can still replace that, too. Fixing your mixer yourself is much easier than shipping it off to a repair center, and you have the gratification of doing it yourself.
I hope this helps! Howard, Burke, VA
Oct 14, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
My mixer just started smoking while i was mix some
Your mixer may still be good, let it cool down and then check it out, If it runs OK then there is no problem. The motor in your mixer probably over heated from trying to mix bread dough which will make any mixer work hard. These mixers will get warm when over worked but unless heavy smoke was coming out and you were getting a burning enamel smell it is probably OK. Let it cool and try it but I suggest you not use it for bread any more.
Oct 08, 2009 | KitchenAid KT2651X Epicurean Stand Mixer
4 1/2 quart kitchenaid mixer head jumps when mixing
Adjusting the screw didn't work for me the first time I tried it.  I was afraid of loosening the screw too much, and so I didn't turn it far enough.  Turning the screw counter-clockwise until it stuck out several millimeters finally worked.
Mar 15, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid KP2671 Professional 6 Series Stand Mixer Logo
286 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
