Question about GE Hotpoint Top-Freezer Refrigerator
Water collecting in the bottom of refrigerator & running out the bottom of the door
You ned to defrost the freezer and unclog the drain hole in the bottom.
Posted on Jul 30, 2009
Water accumulating inside fridge bottom make GE Model #gta18pbnaww
That's normal especially if you tend to leave the door open alot. Moisture from the outside air condenses and drips to the bottom. Also, if the refrigerator is automatic self-defrosting it will melt ice collecting around the refrigerator and the resulting water will collect at the bottom. Check under the food drawers for a drain hole. If it is clogged, clean it out. If it doesn't exist, periodically sponge out the bottom under the drawers.
Jan 12, 2013 | Refrigerators
Unit runs all the time and water collects at interior bottom floor.
Is the unit cooling properly? Its a broken or misaligned water hose that runs from freezer to water reservoir for evaporation from compressor heat. Or there is too much humidity causing lots of water to collect inside and your unit is running all time, it can be a case of door not closing properly.
- Please check the door if its closing properly without any gap.
- Any broken pipe inside
- Chiller tray flooded or not in its position.
May 11, 2011 | Refrigerators
Water is collecting and freezing under deli tray
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 23, 2011 | Samsung RF265AA Bottom Freezer French Door...
I have an ge french door bottom freezer model gfss6kkxass. it has started collecting water under the vegtable drawers and leaking down front of freezer
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
ll
Sep 26, 2010 | General Electric GFSS6KKXSS Stainless...
Water collects, runs alot, food freezes
Sounds like the defrost timer may be out of whack. Is the temp control turned all the way up?
Are the coils clean? Are the door seals sealing?
Are the penguins still working when you close the door.
Hope these help,
Matt
Sep 14, 2009 | Refrigerators
Water collecting in the bottom of freezer.
There's a small drain in the bottom of the freezer compartment. It will clog up from time to time and cause water to pool up, then run wherever it can. So, find that little drain (small hole about the size of a dime or so) and un-clog it. you can do this with hot water and a turkey baster!
Aug 30, 2009 | KitchenAid 25.4 cu. ft. Side-By-Side...
Water collects under crisper drawers
Does it have darin at the bottom to drain out the bottom of the frifge into the drip pan? if it does push a wire threw the hole with the unit unplugged.
Aug 28, 2009 | Refrigerators
Water/liquid collects at bottom of refrigerator under vegetable drawers
For water collecting inside of a refrigerator, there is usually something leaking inside, or perhaps the door seal is letting moist air into it.
Jul 08, 2009 | Kenmore Refrigerators
Water on btm of glass shelves and water in bottom of frig
sounds like you have a gap in the door seal, which results in condensation forming inside unit. Use a blow dryer to heat the seal around the door and ensure that the fit is tight.
Jan 07, 2009 | Kenmore 72073 Top Freezer Refrigerator
Refrigerators Logo
231 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
