Question about Pentair 2.0 Hp Whisperflo Pump
Two speed pool making noise on low speed any help
    Problem Solver:
  • 16 Answers
Replace pump or have motor rebuilt.
Posted on Jan 16, 2010
Water not heating, low pressure pump needs reset. How?
When you say low pressure pump and high-pressure pump...? Are you referring to low-speed water flow, and high-speed/Jets, waterflow?
do you have a one pump system with a two speed single pump? Or do you have two separate pumps? Is one pump, which is normal, a two speed pump? Answers to these questions, will help us, help you!
make and model?
Mar 07, 2015 | Pool & Spa
Pool pump running low psi
your pump should be just fine once the water starts flowing again. You may have run it too long without enough water to cool the seal.
If it is leaking water between the Jacuzzi Pump housing and the motor then you will need a new pump seal. Those are common pool parts.
Rod
US Parts Center
888-521-6183
Jun 09, 2012 | Jacuzzi Magnum Force Series Pool Pump 1...
REPLACE BEARING IN A USQ1202 POOL MOTOR AND STILL NOT SOUNDING CORRECT. NOT SURE WHAT GOING ON. NEED HELP
bad bearing, damaged bearing during install or a bad end bell= makes a low to high roaring noise over and over
Jul 15, 2011 | Smith 2hp Pool Pump Motor A O Electric...
I replaced my motor 1 yr ago and all worked fine...now the low speed works but the high speed only makes a humming noise.
SOUNDS LIKE A DIRTY START SWITCH OR CAPICITOR. THES MOTORS ARE NO JOKE AS I'M SURE YOU ARE STILL FEELING THE PAIN OF THE PURCHASE PRICE.. LOOK FOR YOUR LOCAL POOL PUMP REPAIR GUY WITH FREE TESTING ,USE YOU ZIP CODE ..
I WOULD HAVE THIS TYPE OF MOTOR SERVICED EVRY YEAR ! 1ST TIME ABOUT 80$ NEXT YEAR 40$ WHAT I CHARGE..
DON'T TAKE THE CHANCE HAVE A PRO LOOK AT IT, THERE TOO EASY TO SCREW UP .$$$... IF YOU UN-HOOK THE WIRES TAKE PICTURES OR WRITE DOWN WERE EACH ONE GOES !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!BEST OF LUCK..
HOPE I WAS OF SOME HELP, VOTE IF'N I WAS
Aug 07, 2010 | AO Smith 1 hp 3450/1725rpm 56J Frame 230...
Raypak pool heater is making a knocking noise
low water flow check manual bypass in heat exchange if spring broke letting too much water bypass and overheating water in unit also see if pump ok and filters
Jun 11, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Replaced Single Speed Pool Pump Motor with 2-Speed Motor
You will need a two speed time clock to really take advantage of real energy efficiency savings. Intermatic makes one that fits in place of the original t104 time clock. You will need to run an additional wire to the pump as well. You will have the ground. Then one common wire that is always hot whether or not you are on high speed or low speed. You could make this a white wire. Then a black wire for your high speed that is energized in high speed and a red wire for the low speed. It is important that the high and low speeds not be energized at the same time, otherwise you will hear a very unpleasant sound coming from the motor, and failure and shortened life of the motor will be realized. HTH
May 29, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
Hi I have a magnum 1000 Jacuzzi pump for my
alot of companies use to have a damper ring on pump shaft which would knock down some of the noise a pump motor made pumps make noise and the bigger the pump the louder the noise if its not vibrating or clunking then its running as it should
Apr 21, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
My 2 speed jandy pool pump is over heating
you may either have a bad start/run capacitor for the high speed side or bad supply voltage feeding the high speed side. If there are no loud bearing noises, it should just be either of those two problems.
Aug 15, 2009 | Jandy PlusHP Pool Pump EE Dual Speed - 2.0...
My propane heater rumbles and thumps when turned on.
Sounds like you have a 2 speed pump. The heater needs high speed to operate. The noise is due to the low water flow. The water is actually boiling in the heater. Crank up the flow and that should solve your problems.
Dec 18, 2008 | Hayward H Series Propane Electronic...
Pentair 2.0 Hp Whisperflo Pump Logo
69 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
