Question about Refrigerators
My Maytag MSD2641KES Fridge is not working. The coils in the freezer won't defrost. I replaced the assembly board, it worked for a week. not working now....any ideas?
fridgetech
  • 473 Answers
SOURCE: Maytag MSD2356 Freezer frosts up quickly, fridge warm
If you jumped the defrost board and it went into defrost then that board is bad. I assume by "freezes up" you are talking about the evaporator is frosting up? That defrost board puts it into defrost automatically. If you have to jump it to get it go into defrost then the board is not doing its job.
Posted on Nov 16, 2007
breddi2
  • 126 Answers
SOURCE: Coils freeze up,refridgerator and freezer stops working
The defrost cycle is not working properly, there are three things involved in system. #1 Defrost timer in refrigerator #2 Thermostat on coils to tell if unit is frozen #3 heater element located under coils thaws coils when frozen. the defrost timer if it is manual < located at the front of light assembly panel in top of refrigerator there will be a hole with a plastic piece that resembles a screw strait screw head> it turns and every 8hrs aprox. it stops operations and starts defrost cycle by allowing voltage to the thermostat and if thermostat is frozen it allows power to element for thawing coils. If defrost timer is manual look for direction it is facing and mark edge to see if timer is turning< very slow turning and is easiest way> if you can get an ohm meter ohm the element on high setting< if it has continuity element is operable> check wiring just to be sure not problem. If you find the timer does turn and doesn't stay in one position over 40 minutes then the thermostat is bad.If element fails tesing then the element is bad and if timer stays in one position then it is bad. If unit is equiped with electronic defrost timer and element is good in would replace timer and thermostat to guaranty that resolved problem
Posted on Apr 22, 2009
  • 108 Answers
SOURCE: Freezer coils freezing, fridge warm
You might want to check and make sure the interior fan is working above the evaporator coils. If the fan isn't working the air won't circulate over the evaporator and it will frost over very quickly, and also cold air won't be pushed into the fridge side.
The fan might turn off when the door is open, hold the door switch shut while you check it.
Posted on Apr 27, 2009
  • 2694 Answers
SOURCE: Maytag MZD2766GEW side by side refrigerator fridge not cooling
you have a defrost problem, could be bad adaptive defrost board,t-stat heater,when you open freezer door listen for fan if fan is blowing check the t-stat,look at it and see if it has a buldge on it,sometime you can see this and tell it's bad,you'll need a meter to read out the heater and other parts to see whats bad,might be a good idea to call a tech to do this,when you find problem you have to melt everything out again
Posted on Oct 31, 2009
toolkits
  • 1099 Answers
SOURCE: My Maytag MSD2756GES freezer coil is completely
Defrost problems can cause the fresh food section not to work. You need to find out why it’s not defrosting. There are three things that cause a defrost problem: defrost heater, defrost thermostat and defrost control.
If you have an older refrigerator, it probably has a mechanical defrost control. Find it and turn it clockwise until the refrigerator cuts off. (Note that the defrost control is normally located either in the refrigerator near the cold control or at bottom behind the kick plate). If your refrigerator is newer it will have an electronic defrost control and you won’t be able to turn to defrost so just continue without doing so. Now that it’s in defrost, wait a few minutes. If the defrost heater gets hot, replace defrost control. If it doesn’t get hot, then the problem is either the heater or the thermostat.
At this point, you need to melt the ice. The best way to melt the ice is to use either a hair dryer or by using hot water (this will be faster but will make a mess).
Once the ice is gone, you can check the heater by unplugging wires and using an ohmmeter to check for continuity. If you have continuity, the heater is good and you should replace thermostat. If you don’t replace the heater, at this point you won't be able to check the thermostat but if the heater is good replace it. Defrost parts can be found at AppliancePartsPros.com
If you have a GE refrigerator made after the year 2000, do not replace the defrost thermostat. Trust me the thermostat is not your problem. 99.9% of the time it will be the heater. Sometimes it is the main board or the thermistor.
Also note that
It's possible that the defrost terminator is bad.
If it doesn't have an electronic adaptive defrost control, then the mechanical defrost control is bad.
In the future, avoid ALL appliances that use electronics. They fail very very regularly and are expensive to replace.
Just think if you had a fridge with a TV in it, and the tv went out. Who would you call? A TV repairman or an appliance repairman?
Buy a Whirlpool refrigerator with the least amount of electronics you can get.
Also, there is a door switch that goes to the freezer section. It controls the light and the adaptive defrost. If the switch is bad, that too can cause the problem.
Lastly, do not buy anything made by electrolux corporation (frigidaire is one of them for example).
They have cheap evaporators that leak and can't be fixed, thus causing you to buy a new fridge every year or so.
Hope this helps your problem......
Posted on Jul 28, 2010
My fridge side is not cooling,but my freezer is freezing
seems like you have a defrost issue, with this unit, its more than likely the adaptive defrost control found in the upper right hand corner of the fridge. You have to take down the lights and control....
You can find your part on any of the Parts websites for around 75.00..
IMPERITIVE unplug the fridge before replacing the board..
Aug 01, 2012 | Maytag MSD2756G Side by Side Refrigerator
I have a Maytag MZD2766GEW ref/freezer that the freezer works, but the fridge is warm. I removed the back panels and the coils were all froze over. I am trying to test the Defrost Control Board. How do I...
in most cases its not the defrost board test the defrost element/s make sure they are not blown test at both ends like a fuse you should get a resistence rating of around .2 ohm if the curcuit is open then the defrost elements need replacing maytag have very reliable defrost control boards they dont fail all that often
best of luck
please take the time to rank my reply
Dec 01, 2010 | Whirlpool Refrigerators
Refrigerator not cooling-Freezer Coils Freeze Up & Don't Defrost
check the fan assembly theres not enough air flow going over the coils
Feb 11, 2010 | Maytag MBB2254G Bottom Freezer...
Kenmore refrigerator will not cool. Freezer works
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Aug 27, 2009 | Kenmore Refrigerators
Won't get cold
Aug 25, 2009 | Maytag MSD2732GR Side by Side Refrigerator
MAYTAG SIDE BY SIDE FRIDGE FREEZER STAINLESS STEEL
The problem will come back in about a week once the coils frost up again. This seems to be a common problem with these refrigerators. I had the same problem a while back. Sounds like your defrost board is dead. part number is 12002104. You can find it at searspartsdirect.com
Jun 20, 2009 | Maytag MZD2766GES Side by Side...
Freezer all frosted
i have the same problem and the maytag repair man said 99% of the time its the auto defrost board. i ordered one from ebay for 32.02 and will let you know if it works when it gets here.
Jan 06, 2009 | Maytag Refrigerators
After many repairs to my maytag mzd2766ges, my fridge side cools for a while and then it stops until a new repairs
If either door is open, the airflow will be wrong. Do you see a lot of "snow" or frost building up at the bottom of the freezer rear wall?
Do you hear a fan running in the freezer compartment?
Where are your controls set?
Is the fan back by the compressor running?
Have you checked the air duct at the bottom behind the lower crisper drawers?
The main reason for this type of problem is that the (evaporator) coils below the fan would be iced up.
So, i need you to do this,
1.unscrew the back panels on the freezer side and note whether the evaporator coils were all iced up.
2. If it is iced up, then defrost the coils and then replace the defrost board in the refrigerator.
Regrigerator will be back to normal . Defrost board is located on top of refrigertor side underneath the temp control unit.
Easy repair once you remove the temp control cover. Unscrew the defrost board and plug new connection in.
Post your comments about how things turned up.
Thanx for using fixya,
Cheers.
you can also mail your comments: mailmeswami@yahoo.co.in
Sep 27, 2008 | Maytag MZD2766GES Side by Side...
Nov 16, 2007 | Maytag 23 cu. ft. Side-by-Side...
Coil is Freezing Up
MWKT, did the service tech replace the adaptive defrost board? By your post it sounds like a defrost problem. Check out the pic, this is the adaptive defrost board. I find that the heater and bi-metal usually don't fail on these models and the board is the culprit. Catriver..post back
Apr 01, 2007 | Maytag MSD2758GEW
Refrigerators Logo
172 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
