Question about GE 25413RE3 Corded Phone
TReset for GE Pro Series Model 29451A
We have recently moved one of our GE Pro Series phones to a different office and when plugged back in, it shows "AC Off" flashing and will only connect to one line and also the line light does not light. Is there a reset exercise or reconfiguration necessary and how do I do that?
  • jtsmith32 Jul 08, 2008
    I bought a set of GE Pro Series phones. These are used phones and I can not use the intercom or page system. Does this phone have a reset on it.
  • Anonymous Jan 21, 2009
    I have the same problem. All of our GE 4 line phones have flashing red intercoms. I don't know how to turn them off. The manual isn't helpful at all.
Remove the plastic speed dial card covering and the speed dial card. Press "program" with a pen tip. Press the intercom button. The lcd display says "address-xx" (probably out of range). Type in a new 2-digit address within range (the number of phones you have), probably 01, 02, 03 or 04. Then press the # key. The intercom light should turn green, and there you have it.
Posted on Mar 23, 2009
6ya staff
SOURCE:
My laser jet pro map m177fw is stuck initializing, and i have tried everything. i have read several other's issues, but mine persists. can you help?
Please review the HP troubleshooting for your printer:
HP Color LaserJet Pro MFP M177fw
If this printer is new, you may need to make sure the toner cartridges are seated and installed correctly.
It appears others have had similar issues and solutions are provided here:
Laserjet Pro MFP M177FW stuck in Initializing
May 16, 2017 | The Office Equipment & Supplies
I have tried every configuration of the wiring I can think of. I have 2 jacks and a Ring Selector for the fax machine.
What is the make or brand/model of the phone you are referring to? Does it has a line 1/2 selector or a ringer selector on the panel?
Maybe the phone you have has a selector on its side.
I need more info.
Best regards.
Sep 01, 2015 | Lands Phones
How do I replace the yellow ink cartridge?
Open up the Panel It has the writing HP office jet pro Etc. on it, then the cartridge/head will move toward you, push in on the yellow cartridge until it clicks and release it will disengage and you can remove old cartridge.
Installation is exactly like removal insert new cartridge until it clicks release and it will engage.
Close panel and the cartridge/head will move back to previous position
Jun 02, 2015 | HP Officejet Pro 8600
I recently got moved from my regular office to a different office. how can i use same phone extension in new office? we are using norstar m7310 phones.
Should be simple ... just change the pair you used in the former office to the new office in your punch down closet.
Aug 10, 2010 | NorStar Meridian M7310 Phone
I need the owner manual for ge pro series model 2-9438b
I found the manual for the 9438 at http://157.254.235.130/public/29438.pdf.
It seems to be accurate for my 9438b.
Jun 10, 2009 | GE Telephone
Phone works in one jack but not another
Hi, Looks like either the wiring is slightly different or the jack plug not quite with in the tolerance limit. Can you swap the cables between the units (if they are removeable) to eliminate the cable as well. I would suspect the cable on the new phone! I would also make sure there is no dirt on the connectors on the plug...there are minute grooves where you can see the meatl...sometinmes these get blocked!
Jan 08, 2009 | GE 28111 Cordless Phone
When preparing making a call, I get a series of short dial tones.
Have you tried erasing all of your recorded messages? Usually the short dial tone beeps mean you have a pending message.
Jan 05, 2009 | Big Button GE 29369GE1 Speakerphone
Help with GE pro series 3 line phone
http://www.home-electronics.net/ge/pc/user-manuals.asp
must have your model number. manuals are on this page of thompson consumer electronics, the manufacturer of GE phones.
Dec 04, 2008 | Lands Phones
Power problem
just reading this forum I think I have bought a total POS. Damn! wich i would have read this first. This boat anchor has all of my backup on it, is only a month old and is now junk. What is this the 3rd world's way of collecting all of our data when we return them?
Apr 27, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
GE 25413RE3 Corded Phone Logo
1,004 people viewed this question
Top GE Lands Phones Experts
martin hogg
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
