Question about Denon AVR-3300 Receiver
Intermittent audio output
The AVR-3300 will work great for a while then loses audio output when I switch sources. I've discovered when I wiggle the Adio/DSP card the sound comes back. But then the problem repeats, sometimes hours, sometimes days later. I examined the board and found what appeared to be an intermittent ground connection and thought I had it fixed. But a week or so later the problem returned. I'm using it in analog mode only, so the problem apparently has nothing to do with digital processing. Any help appreciated! Ken
  • 1 more comment
  • Anonymous Apr 05, 2008
    I have the same issue. Mine seems localized to the front panel controls. I took the case off and "wiggled" the boards and it seems to have fixed it...for now. Did you ever find a permanent fix or did you replace the receiver? Regards, Josh
  • Brails Jun 04, 2008
    I have the same problem. I don't have sound when I turn the unit on and I lose sound when I switch between audio components. There seems to be no rhyme or reason to when it will come back on....sometimes a few minutes later, sometimes a few hours and all of a sudden the sound returns. I have not opened up the unit and jiggled boards as others have done but will try that next.
  • eddy shack Jun 29, 2008
    My receiver has been losing its audio output as well. For a while all I had to do was tap or touch the receiever and the audio would come back. Now, I have to bang the receiver a little harder and sometimes it comes back. I haven't opened the rceiver yet as I am not a technician. Has anyone found the real problem as to why this is happening ?
It's quite possible one of the relays is failing that is part of the switch between audio output choices.  Do you notice any output difference between a certain output (i.e. dvd, tape etc)or is that point arbitrary?
Posted on Jan 08, 2008
6ya staff
SOURCE:
Cant get ps4 to pass signal thru avr to projector.
Possible PS4 HDMI Handshake Output Problem - AVS Forum ' Home ...
www.avsforum.com/.../1508885-possible-ps4-hdmi-handshake-output-p...
Dec 31, 2013 - 20 posts - ‎15 authors
Nothing seems to make the PS4 pass a signal through the AVR. .... can output videothrough the Integra, why can't Sony get the HDMI working? PS4 - 3D Playback Not Working :-(
Aug 12, 2014
Run HDMI Directly to TV or A/V Receiver?
Dec 19, 2013
AV receiver problem with Xbox One
Nov 23, 2013
Solution to HDMI @ 1080p receiver/display HDCP ...
Dec 14, 2008
More results from www.avsforum.com
My Denon AVR-X4000 won't output video signal from attached HDMI ...
forum.blu-ray.com > Audio > Receivers
Dec 21, 2015 | Denon AVR-3311CI 7.2 Channel Networking...
RE: Denon AVR 3300 - I cannot get the system setup menu to display on Phillips P50PFP5332D tv screen? All connected components work and sound great, but I cannot see Denon's Setup menu on tv to a
I understand, it's something I've misunderstood on my denon avr-790 as well when connected to a samsung 8000 series led tv.
The answer isn't in the receiver's settings (you can be on whatever source you want on the receiver end when toggling the menu). You need to toggle through the tv's sources to find the menu (usually found on hdmi 1). I've spent towards an hour recently troubleshooting only to find that it was the tv's source that wasn't set properly and I was trying to change the receiver's settings instead of the tv's source.
Hope that helps!
Jan 16, 2012 | Denon AVR-485 Receiver
I have connected the audio from 3 devices into the 3 optical inputs on my Denon AVR-3300. Audio for each device plays perfectly through main speakers but not through the multi-room output (which goes to...
the unit is ok. User manual on page 42 says that the digital sources can not be output trough multisource output.
Try to use VCR-1 VCR-2 audio output jacks instead.
Sep 24, 2011 | Denon AVR-3300 Receiver
How to connect and set up my DENON AVR-3300 to my LG tv. Waht connections on amp and tv do I use?
  • if you want to listen your TV on your Stereo system thru your receiver, AVR-3300 ** you need to connect "Audio Output " RCA jacks or "Optic cable output" of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver ( except Phone ) or "Optic Cable input"
** than just switch to respective mode on
AVR-3300 RECEIVER corresponding your RCA or Optic connection...
There you go..Your TV sound is on the
AVR-3300
Receiver..By this means whatever you watch on the TV (tuner, satellite , Xbox ) ,it's sound will come thru your stereo..
  • Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Mar 28, 2011 | Denon AVR-3300 Receiver
No sound from new sony bravia to denon avr 1610
TV's are not your best source of audio. Get the TV-related audio digitally from the source, NOT the TV.
Jun 25, 2010 | Denon AVR-3300 Receiver
Denon AVR-3300 component channel switch burnout?
hi there, i don't have a solution unfortuantely, but i may have the same problem. I have a denon 2802 av receiver, i bought it second hand and I can't seem to get the component video in / out working. Are you supposed to just plug it in and it works? Because I can't find any buttons or settings to select component in / out as my input / output sources?
Nov 12, 2009 | Denon AVR-3300 Receiver
Denon receiver AVR-3300: Unstable source selection
Go over here: http://denon.custhelp.com/cgi-bin/denon.cfg/php/enduser/std_alp.php?p_sid=1NlVrsDj
I have some Denon components myself and had some problems. Ask them here, and within a day you should have solution for this problem.
Probably you have to reset the device to factory settings.
Jul 22, 2009 | Denon AVR-3300 Receiver
Harman Kardon AVR 325 randomly switching inputs
Step one would be to ascertain exactly what the failure mode is - which input(s) aggravate it, what kind of connection, etc. Narrow the scope a bit.
The clicking and fickering sound like it's struggling with an intermittent source connection. When it starts flickering see if you can change the problem by wiggling the cables one at a time.
Do any of your video sources have multiple attachment types connected at the same time, say, hdmi and component, but to different assigned inputs?
Apr 30, 2009 | Harman Kardon AVR 325 Receiver
Denon AVR-3300 Receiver Logo
302 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
