Video Game Consoles & Games Logo
jim benson Posted on Feb 04, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dropped my old ps2 console, model no.scph-30003 pal. it still plays, but intermittently colour changes to b/w and sometimes it flashes off and on. I dont want to scrap it, because it has its own off/on switch and it is easy to handle cause of its size.has anybody got any idea of how to fix it?
Dayton Computer
Level 3:
Master:
  • Master 669 Answers
  • Posted on Feb 04, 2018
Dayton Computer
Master
Level 3:
Master:
Answers
669
Questions
0
Helped
200076
Points
2079
There may be a fractured PC Board or intermittent short. The fix could cost more than a replacement unit, thus I would use it as is until it fails for good.
3 Related Answers
Anonymous
  • 709 Answers
  • Posted on Oct 18, 2007
SOURCE: playing a european PAL game on a canadian NTSC console
Go to a search engine like www.metacrawler.com and search for "Swap Magic".  The Emotion Engine processor that is reading the data from the game is told not to read certain Discs if the region code does not match the conoles country code. It mayl save a game to the memory card but not play the game or run the movie.
Anonymous
  • 709 Answers
  • Posted on Oct 31, 2007
SOURCE: PS2 power ribbon Help!!!!!!
Use a pair of needle nose pliers and grip the connection end of the Ribbon cable by the hard plastic piece.  Insert this cable in the second connector from the front.  The connectors are located under the right edge of the CD drive.
Anonymous
  • Posted on Oct 10, 2008
SOURCE: SCPH - 50004 Pal PS2 colour and reading problem
can you give me some cheats for dragonball z budokai tenkaichi 2
Gt4 doesn't work on my ps2
Your reading lens is probably weak or its dirty....first you should clean your PS2 lens.Here is a video that will help you in cleaning your PS2 lens....
Cleaning lens helps in most of the cases.Apart from cleaning lens here is a little trick for you, check it out it might work on your console too!
http://www.fixya.com/support/r3537760-try_play_dvd_movies_ps2_wont_play_dvd
Although its about plying DVD's but you can play heavy games like Grand Turismo 4 , God of war etc too by following the same procedure....!
Good luck! :)
2helpful
Playstation 2 won't play DVDs
if it's a fat PS2 and
model SCPH 30001, SCPH 35001
(not including the models with an 'R' after the model #.
these models need the following to play DVDs:
- PS2 DVD remote with IR unit
- PS2 DVD disc player (sold with DVD remote w/ IR unit)
- PS2 memory card
you copied the DVD disc to the memory card. you used the memory card to play DVDs.
later models didn't need the memory card to play DVDs.
hope this helps :D
I have the PS2 model # SCPH-70012. I have taken
download? you mean play, sounds like your drive is dead
1helpful
2answers
PS2 Modded Trouble Reading DVDr's
Your DVD potentiometer pot on the back of the PS2 laser lens needs to be readjusted. Some people will try to tell you it's out of alignment but if that was the case it would not read CD's. Some people will try to tell you the laser lens is bad. If that was the case it would not read CD's. On the back of the laser lens are two potentiometer pots. In english? Two lil screws that are turnable. One controls the power of the DVD laser one controls the power of the CD laser.
http://www.cyber-mag.com/station/laserV9.htm
That link will give you pretty lil pictures of what i'm talking about :)
In a nut shell the story goes like this folks. If your PS2 won't read certain game DVD's that are of a certain color or if it all of a sudden mysteriously fails to read games it once read but will play cd's just fine, the voltage of the laser for DVD's is not set correctly. (this does needs manual tweeking from time to time if you take your ps2 and move it around alot or if you take it over to friends houses etc etc. Basicly alot of movment in general can take this out of alignment. Even keeping the PS2 on it's side could theoreticly (just my opinion) based on gravitational pull, unbalance the potentiometer.
RESOLUTION:
Step 1 identify your PS2 version:
Version 1 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U1"
Version 2 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U0"
Version 3 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U2"
Version 4 - SCPH-30000, 30001, 35001, 30002, 35002, 30003, 35003, 30004, or 35004, 8 screws on bottom of case
NOTE: Version 4 has 2 varieties of motherboard: Gap/No Gap, the difference between v4 "Gap" and v4 "No Gap" is the "Gap" is there's a spot in the center of bios chip where each side lacks solder points.
Version 5 - SCPH-30000R, 30001R, 30002R, 30003R, 30004R, or 30006R. Also, some SCPH-30000, 30001, 30002, 30003, and 30004 models have a V5/V6
NOTE: Version 5 & 6 - the difference between these two versions is one of the connectors in the corner.
Version 7 - SCPH-39000, 39001, 39002, 39003, 39004, 39008 or 37000
Version 8 - Only in Japanese consoles. SCPH-39000, or, SCPH-39006 (GH-022 BIOS 090)
Version 9 - if you have SCPH-50000, 50001, 50002, 50003, 50004, 50006, or 50007 you have a v9 or v10 board.
Version 10 - SCPH-5000x, with date code "3D" to the right and below the serial number on the back of the console. (GH-026 board)
NOTE: To know if its a v9/v10 start up PS2 with no game in it ,press triangle and check dvd driver version dvd ver 3.00 = v9 & dvd ver 3.02 = v10.
If your model # is SCPH-50000, 50001, 50002, 50003 or 50004 AND if you can find a small ''a'' under the SCPH number or have DATECODE "3C" you have a V9 PS2 main board. (GH-026 board).
If your model # is SCPH-50000, 50001, 50002, 50003 or 50004 AND if you can find DATE CODE "3D" as shown below, you have a V10 PS2 main board. (GH-026 board).
Version 12 - The new slimline PS2 consoles are referred to as PSTwo here, but elsewhere they are also known as "v12" units... their numbers are SCPH-70011/SCPH-70012, and also SCPH-70004 CB (Belgium).
Step 2 use either google or the link above. If you're using google your keyword search will be something like "ps2 v12 laser lens adjustment" *replace v12 with your ps2 model.
In either case navigate to the site and follow instructions to set the pots back to their factory default settings.
3answers
You need to buy those games which says PAL on it...Usually they have those PAL indications on the top right corner of the CASE of the DVD...of course you won't be able to play those NTSC games...it's just a compatibility issue, i think...cause your PS2 is a PAL model...
Ps2 to goodmans tv
Which version of the PS2 do you have (NTSC or PAL)?
And same question about the TV?
1helpful
4answers
Sony playstation 2 slimline model scph70002
hi! i have ps2 console SCPH-70002...it plays the old games but does not play later version say wwe 2009 and other latest games of ps2 on my tv
2helpful
PS2 Locks-up during running
Maybe the TV is old or the disc is scratched
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
