Question about Compaq Presario s4020wm (DK214AR#ABA) PC Desktop
Wont start up.
I am on the wii right now so typing this is brutal. Ok, so i try to boot the pc up. At first the fan kicks on and the orange light blinks (instead of green). Then the disc drive light blinks about ten times farely fast. Then they both happen again. This whole time the moniter is on but nothing comes on screen. The reason im pretty sure its not the moniter is because this has happened before. Ive tried unplugin everything then pluging it back and nothing works. Please help me!
  • pwninator Sep 11, 2007
    Yes its xp. But even when i try to go into safe mode nothing at all is on the screen.
  • Anonymous Mar 28, 2014
    wont boot up with different moniter
    im trying to boot up with different monitor
    but it starts loading files never does anything else
    Sergeant:
  • 457 Answers
What OS are you running is it Windows XP if so press f8 to get into safe mode if this happens its a software problem if nothing goes again then the problem must be the motherboard??????
Posted on Sep 11, 2007
SOURCE:
M1160n wont boot windows xp nor two internal fans
Step 1:
Lets try this...
Unplug the cpu
Step 2:
remove the battery from on the mainboard
Step 3:
press and hold the power button for 30 seconds
Step 4:
release it
Step 5:
put the battery back in, plug in and turn on , it should work fine..
Step 6:
If that fails replace the power supply..
Dec 28, 2012 | HP Media Center m1080n (PC099A#ABA) PC...
Dimension 3100 turns on the power button has a steady orange light there is also an orange light on motherboard cpu and power suplly fans working but wont bot up
Blinking amber (orange) indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this could indicate a problem with the power connections for the CPU on the system board (see "Power Problems" in your Owner's Manual).
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
Have a HP m7470n. The green power light in the back is constantly on. The power button flashes blue and orange (~3 seconds each). The computer wont turn on. When I unplug the cord and plug it back in, the...
In my case it turned out to be a weak power supply. It would work sometimes and not others. If stone cold, it would not boot. If I unplugged 1 thing, like the hard drive or the CD Roms, it would boot. Tested the old power suppy and it seemed to pass. But once I connected a new power supply, the computer has worked fine ever since.
Jan 08, 2011 | HP Pavilion m7470n (ER883AA) PC Desktop
My HP nc6000 wont start when I press power button. Fan starts for a few seconds an then the orange led turns on, after that everythig turns off. AC an the battery is ok. Any idea? Thak you.
Hi,these particular brand of Hp series is very problematic,try checking the Ram out,its usually underneath the keyboard,so if you have two installed try using one at a time to boot system,if problem persist have an I.T Technician look at it.
Dec 31, 2010 | HP Compaq nc6000 Notebook
Optiplex GX280 - loud fan at start up and amber power light - does not boot and no light at the back
Apply pressure on the heat sink fan right before you press the power button and continue applying pressure. Watch your screen if you see it boot this means its a problem with your processor clamp that applies pressure to the processor. Try to remove the top part of the clamp. Shouldn't be too hard with some needle nose pliers. Then just replace the heat sink and fan with out that clamp.
May 27, 2010 | Dell OptiPlex GX280 PC Desktop
Inspiron 1521 won't boot up. fan kicks in then shuts down nothing comes on screen
to fix this all you have to do is if you have a air compressor blow out the dust dont get the air chuck to close to the back, once the dust has been blown out your laptop should load up.. the reason it wont load is a safety thing once dust is out the fan wont over run and there for your laptop should start right up
Mar 14, 2010 | Dell Inspiron 1521 Notebook
Wont start
first check upc which is next to battery. check block plugs for water and corrosion if there is you will need to change etc check fuses on battery positive terminal.if these are all ok. you will need to check wiring for corrosion from upc to ecu. normally orange wire in loom is 5v wire to power up ecu.
Feb 19, 2010 | 2004 Renault Sportwagon
Computer wont power up. Light stay amber and fan come on
Hi. No I think mobo is ok as you've got power to fan and lights. Are the drives kicking in? if yes then I think its your memory. Also if the drives are kicking in then your cpu is also ok. So that leaves the memory and graphics card. Good luck
Mar 31, 2009 | Dell Dimension 3100 PC Desktop
Flashing Orange light, computer wont boot
Below is the link to the NoPower, No POST, No Video troubleshooting.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?c=us&l=en&s=gen&journalid=&treeid=011360B8243248349C306481A954B356&Query=&SystemID=&ServiceTag=&contenttype=&os=&component=&lang=&doclang=en&toggle=&dl=falseFollow all the steps without skipping any and if there is no hardware failure,this should definitely resolve your issue.
Hope this helps. Please rateyour feedback!
Thanks,
VJ
Mar 26, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
No display and wont boot
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Power supply is easier and cheaper to replace.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 12, 2008 | Dell Dimension 4700 PC Desktop
Compaq Presario s4020wm (DK214AR#ABA) PC Desktop Logo
114 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
