Question about Garden
Mower will not stay running unless primer button continuouly pushed. Gas seems to not be independently flowing, requires manual priming to stay running. As soon as primer gas used, will stop running.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 109 Answers
The tube in the bottom of the carb. is probably clogged. Remove the carb, and bowl and try spraying WD-40 through the tube, it should spray into the venturi if it doesn't try using a tip cleaner to unclog the tube.
Posted on Apr 16, 2009
Yes, carb is plugged...take off the air cleaner. prime and start...before it stalls prime it again a couple times to keep it going, place hand to seal air intake into carb...this will cause a vacuum to be created POSSIBLY clearing the clog....do it SEVERAL times until it keeps running on it's own
Posted on Jul 26, 2012
Will not prime with primer bulb , can squirt gas in carb and get running then while running you push the primer button it chokes down the engine .
Does it stay running after you squirt fuel in the carb opening? If yes, then there may be a pin hole leak in the hose going from the fuel tank to the primer bulb and it is adding air to your carb.
Thanks
May 01, 2015 | Craftsman 675 Torque 190cc 21" Briggs ...
Craftsman tiller won't start unless I manually prime cylinder with gas. There is no primer bulb. Can I retrofit a primer bulb in the gas line?
Hi
You can insert a primer system into your fuel system
Just follow the fuel flow below
Please take time to rate me
Bud
Oct 23, 2012 | Craftsman Garden
Engine runs for a short time then dies, replaced plugs, air filter, in line gas filter, and rebuilt fuel pump
I had a B&S lawn mower engine that did this unless I kept pushing on the prime button and I found I had a Cracked primer rubber bulb. Maybe you have something similar or another type or carb problem.
Jul 28, 2011 | Briggs & Stratton Tools & Hardware -...
KEEP GOING ONLY IF YOU KEEP PUSHING THE PRIMER BUTTON
You have a clog in the gas flowing into the carburetor. Get some carb cleaner (the spray kind is fine). Drain or siphon the gas out of your mower and discard. Put a little fresh gas and a little carb cleaner in the tank. Run it through. Do this a few times if necessary. When you get new gas, add a gas stabilizer like Sea Foam.
May 05, 2010 | Mtd 22" Yard Machine Push Mower
Lawn mower starts and stops right away
take bowl off bottom of carb....clean and reassemble
Nov 16, 2009 | Garden
Wont stay running without pushing primer
Hi... I have a Poulan PRO Quantum xnp 6.75. Garage kept, unused approximately 2 yrs. Added fuel, primed & mower started but then shut down immediately. Then fuel began leaking from the primer button. I'm a single mom & CANNOT afford to have anyone fix this. However I am attempting to repair myself. PLEASE.... If you have any suggestions &/or solutions I would LOVE to know.
Apr 12, 2009 | Garden
Lawn mower
i dont understand the pulling the button - do you mean push the primer button - if you mean primer button it sounds like the high speed jet in the carb is dirty and needs service- you can attempt to start and once engine fires have someone continually push primer to keep running it ma clear the blockage - did You check the fuel tank for any water ?
Oct 19, 2008 | Mtd 22" Yard Machine Push Mower
Garden Logo
1,012 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
