Monitor does not work I suspect power adapter
My philips briliance 151 AX monitor does not work I suspect problem with power adapter what is the output voltage of adapter going into monitor? thanks john
  • johnk1957 Apr 23, 2009
    thanks great advice!!!!!
  • 449 Answers
Hello, the ouput voltage varies, depending on the type of monitor and size. if it is Hp product is 18Volts.but since it is philips i suggest you look at the body of the adapter where you will see the Dc ratings and other Voltage ratings. and you can go along with the adapter to the store you are buying a new one.
Posted on Apr 12, 2009
Reset forgotten bios password on a pavilion ze5600 laptop
click start type cmd press enter
At command prompt type debug
you will get a - prompt where you can type the following (<enter> means press enter, not type enter*)
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
<ENTER> just hit enter on this line
G <ENTER>
Q <ENTER>
Basic BIOS password - works 9.9 times out of ten hope it helps
Aug 31, 2012 | HEWLETT-PACKARD Pavilion Ze5600...
Power cord for 15MF400T
Looks like Amazon sells them for $2.62+$6.99 shipping.
http://www.amazon.com/Adapter-Charger-Philips-Magnavox-15MF400T/dp/B006YJGKQO
Feb 17, 2012 | Philips Magnavox Computers & Internet
My samsung sync master 151 -s screen is completely black, The rest of the pc opereates fine. The screen was working fine, then left to idle for a few hours now it appears really dark.
Try turning off the power to the monitor and the computer, check all the cables and power it all back up again. If the monitor is still black, try plugging it into another computer or into a laptop and see if it works there. If it does work, then the problem is the video card in the computer. If it is built into the mother board, then you can disable it in the bios setup and buy a PCI or AGP video card on eBay to plug into *********** board.
Nov 18, 2010 | Samsung SyncMaster 151 N 15" LCD Monitor
Lcd monitor problem
The inverter board can be in the power supply inverter board combination,.you should check the power supply for bad capacitors first.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 25, 2009 | Philips Brilliance 150P4CG (Beige) 15" LCD...
Philips 150S4 does not switch on every time the PC is switched on - suspect it is powersupply problem. Thanks Louis
You check the cable that's used to connect the cpu and that monitor, and the cable that's connected to the power supply. You unplug and plug it. You may have a loose connection on plugs. It works for me. Hope this helps.
Nov 08, 2009 | Philips 150S4FG (White) 15" LCD Monitor
Power failure issues
The specs for this monitor is a 60 Watt, 12 Volt, 5 Amp power adapter. The voltage must be the same. You can always get an adapter with a higher Amperage rating, but never get one with less, as this can overheat the adapter and damage it. I was not able to locate specs on whether the voltage to the monitor is DC or AC... most are DC. If this is the case, the observe the polarity at the monitor. Power adapters have a positive and a negative... center and outer contact, Make sure that the power adapter matches that of the monitor, else it will not work.
Sep 26, 2009 | Balance CM2017 17" Monitor
104s philips monitor
Why do you suspect the horizontal or vert curcuits? I would suspect the HV curcuit since no display at all. Gary(Honkity Hank)
Sep 18, 2007 | Philips Standard 104SLE 14 in. CRT Monitor
Computers & Internet Logo
David Payne
David Payne
