Question about Epson Perfection V500 Flatbed Scanner
Can not install driver missing file es7c.inf
I have an Epson Prefection 500 scanner.I can not load the driver. It says file is missing es7c.inf
    Problem Solver:
  • 12 Answers
Any chance of a driver for Epson Perfection 1200 scanner with windows 7 64bit
RapidShare is dead.
I used this link today 7-24-2012 and it worked like a charm.
http://www.box.net/shared/5rxsn87mqr
A huge THANK YOU to the person who did the work that Epson
should be doing.
Without the scanner turned on, I downloaded the file, unziped it
and extracted the files. I then ran the .exe
After that I turned on the scanner and let Win 7 install the device.
Simple as pie.
Dec 15, 2009 | Epson Perfection 1200 Photo Flatbed...
Cannot install downloaded driver. Windows XP looks for a .inf extension which doesn't exist in the driver files
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokl-16
Aug 16, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I have a toshiba satellite a105-s4114. Did a fresh install and can't get the SD card reader to show up. I have gone to the Toshiba website and installed what should be the correct drivers. For the Texas...
INF error usually occurs if the inf file is missing or the auto run .inf extension file is missing. INF is used to load the auto run of the application that made it possible to be used to any specified application that serves its purpose. So therefore your SD card reader won't show up due to the face that its INF file that is responsible in loading it application is missing. So i recommend that you have to reinstall completely the driver of SD Card reader in order to be able to use the application.
Thanks
Aug 06, 2009 | Toshiba Satellite A105 Notebook
Vista driver for 1200S scanner
Install on Vista and Windows 7 using driver files from a XP installation. Copy the following driver files from XP: umax.inf, layout.inf, sti.inf, scsiscan.sys, sti.dll, umaxscan.dll, umaxud32.dll, umax.pnf (this may be more files than you need, but it works). Edit the umax.inf file to remove all by the 1200s/SCSI related sections (or copy it from below). Perform a manual installation of the 1200s and select the umax.inf installation file that you copied and edited. This worked perfectly. My Umax 1200s is recognized and works great in Windows 7.
Umax.inf:
; UMAX.INF -- Windows Still Image Setup File
; Copyright (c) 2000 Microsoft Corporation
; Manufacturer: UMAX DATA SYSTEMS INC.
[Version]
LayoutFile=Layout.inf
Signature="$CHICAGO$"
Class=Image
ClassGUID={6bdd1fc6-810f-11d0-bec7-08002be2092f}
Provider=%Msft%
DriverVer=07/01/2001,5.1.2600.0
[ControlFlags]
ExcludeFromSelect=*
[DestinationDirs]
DefaultDestDir=11 ; LDID_SYS
[Manufacturer]
%Mfg%=Models
[Models]
;no button will be supported on inbox UMAX driver.
%SCSI\UMAX____ASTRA_1200S_____V.DeviceDesc% = SCSI.Scanner, UMAX____ASTRA_1200S_____V
; Device section
; All SCSI scanner (600S, 610S, 1200S, 1220S, 2400S, 2200-SCSI)
[SCSI.Scanner]
Include=sti.inf
Needs=STI.SCSISection
SubClass=StillImage
DeviceType=1
Capabilities=0x30
DeviceData=Scanner.DeviceData
AddReg=Scanner.AddReg, SCSI.Scanner.AddReg
CopyFiles=Scanner.DriverFiles,Scsi.Scanner.CopySys32Files
DelFiles=SCSI.Scanner.DelSysFiles
ICMProfiles="sRGB Color Space Profile.icm"
UninstallSection=SCSI.Scanner.Uninstall
[Device.Events]
; These are events that this device supports - uncomment the events
; supported by this scanner and provide a description for the
; event and the name of the application to launch. The name of the
; application is the name which the application uses to register itself
; with the STI.
Event1=%EVENT_1%,{2DA39CE1-4F33-11d3-9859-00104BF5E7FA},%APP_TO_LAUNCH_1%
Event2=%EVENT_2%,{2DA39CE2-4F33-11d3-9859-00104BF5E7FA},%APP_TO_LAUNCH_2%
Event3=%EVENT_3%,{2DA39CE3-4F33-11d3-9859-00104BF5E7FA},%APP_TO_LAUNCH_3%
; Services (no meaning on Win9x)
[SCSI.Scanner.Services]
Include= sti.inf
Needs= STI.SCSISection.Services
; DeviceData
[Scanner.DeviceData]
TwainDS="WIA-UMAX TWAIN DS"
Server=local
UI DLL=sti.dll
UI Class ID={4DB1AD10-3391-11D2-9A33-00C04FA36145}
[Device.DeviceData]
Server=local
UI DLL=sti.dll
; Flags which indicate which events should be recognized by the minidriver
; To recognize an event set the value of its mask to 1 to turn off an
; event set its eventmask to 0.
EventMask1=0
EventMask2=0
EventMask3=0
; The time interval between two subsequent activations of the event
; button on the scanner - If the time between activations is less than this
; then the event will be ignored. This value has to be specfied in milliseconds
; it must be larger than half a second and not more than 10 seconds.
DebounceTime=5000
; Enable polling for buttons event if 1
POLLING=0
; Enable Set Remote Wakeup (for LM9832/3, or LM9831 with updated EEPROM)
REMOTEWAKEUP=0
; AddReg
[Scanner.AddReg]
HKR,,HardwareConfig,1,2
[SCSI.Scanner.AddReg]
HKR,,USDClass,,"{92bf9f20-ca15-11d0-8350-bc0a6bbd28e3}"
HKCR,CLSID\{92bf9f20-ca15-11d0-8350-bc0a6bbd28e3},,,"UMAX WIA"
HKCR,CLSID\{92bf9f20-ca15-11d0-8350-bc0a6bbd28e3}\InProcServer32,,,%11%\umaxscan.dll
HKCR,CLSID\{92bf9f20-ca15-11d0-8350-bc0a6bbd28e3}\InProcServer32,ThreadingModel,,"Both"
; Copy files
[Scanner.DriverFiles]
umaxscan.dll
umaxud32.dll
[SCSI.Scanner.CopySys32Files]
;scsiscan.sys
;scsimap.sys
[SCSI.Scanner.DelSysFiles]
[SCSI.Scanner.Uninstall]
Jan 12, 2009 | Umax Astra 1200S Flatbed Scanner
Language
Hi-
Try uninstalling and reinstalling the driver and that should default it back to english. keep me posted for any progress and pls rate solution if it helps. Thanks!
Jul 16, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson stylus dx7450
Windows uses a foreign language information file when installing a printer driver via USB. This then installs the associated foreign printer driver and utility files.
This can be corrected with a full uninstall of the printer driver. The standard uninstall will not remove the original foreign language files. Please follow the steps below to install the English version of the printer driver:
Step One:
Switch off and disconnect the printer. Go to Add/Remove Programs in Control Panel, and remove EPSON PRINTER SOFTWARE (this may be named in a foreign language like 'EPSON DRUCKER SOFTWARE' - when you are at this stage and have selected to 'change/remove' this item, a window will appear titled 'EPSON Printer Utility' - above the icons of each of your EPSON printers will be a 'Printer Model' tab and 'Utility' tab (Note, if there is no Utility Tab then just continue). Please click on one of the printers so it is highlighted, then select 'Utility' - please tick every box listed in the 'Utility' section and select 'OK'. Answer positively to all questions and once the uninstall is complete, you will need to follow the same procedure to remove the other EPSON printer drivers by clicking on 'EPSON PRINTER SOFTWARE' again and 'CHANGE/REMOVE'.
Step Two:
Open up Windows Explorer or My Computer, and navigate to the drive (usually C) where windows is installed. Browse to the folders called windows/inf on XP, or winnt/inf on 2000. If you can not locate the INF folder please go into the START MENU and select RUN. If there is any text within this box please remove and type C:\windows\inf and press enter. Please be advised that 'C' represents the hard drive on your PC. If your hard drive is a different letter please amend as necessary.
Find the files labelled OEMxx.inf or OEMxx, where xx is a number from 00, 01, 02 etc upwards. You will need to double click on each INF file in turn, and if it says “SEIKO EPSON” or “EPSON” within the first few lines, then you need to close the file, and then delete it. Please also can you delete the corresponding PNF. Repeat this until all EPSON INF files are removed.
Note: You cannot open a PNF file.
Step Three:
Staying in Explorer or My Computer, stay within the windows folder (winnt folder on 2000) and navigate to system32/spool/drivers, and go into the folder named "w32x86". Delete any folders that begin with "epson", and then restart. Once rebooted, empty the recycle bin, and attempt reinstallation of printer, using the instructions below.
Step Four:
MAKE SURE YOUR PRINTER IS STILL SWITCHED OFF AND DISCONNECTED AT THIS POINT. Insert your driver CD. Double Left Click on My Computer and select your CD drive by right clicking on the CD icon and select open. When you first open/browse the CD-Rom then you should see various folders. Please browse to the Common Folder. Within here select the Printer Driver Folder then choose the WinVISTA/XP_2k folder. Run the Setup.exe file and complete the installation as normal making sure you only connect the printer when requested to do so.
Step Five:
Once this has completed installing, please remove the CD from the CD drive and reboot the PC. The foreign language tabs will now appear in English.
Mar 16, 2008 | Office Equipment & Supplies
Epson GT5500 Flatbed scanner
unfortunately Epson has not made a driver for this scanner that is compatible with Vista and from the looks of it, they don't seem to have any plans on making one!
Sorry
Jan 29, 2008 | Epson GT 5500 Flatbed Scanner
Installing software
Hi, It sounds like your install cd is faulty. if you follow this link you can download the latest drivers for your pc: http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=nKGrQtfEm6nLfXnUdNyU002F55WY1si6WXTVtEbxOEARShwU003D&tc=6#7 Make sure you install your drivers BEFORE you plug the printer into your pc. Let me know how you get on
Aug 22, 2007 | Epson RX620 All-In-One InkJet Photo...
Epson Perfection V500 Flatbed Scanner Logo
342 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
