Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Continuous reloading of programs, cpu use up to 100%
Help! My computer starts up fine, then when I move a cursor it begins to load whatever program I glide over first without clicking anything. I have managed to try add/remove, registry cleaner, tweak, anything! It first started when I tried to run a panda antivirus scan which I have done many times successfully in the past. It shows about 50 or more viruses detected, then froze up and I had to turn off manually.
    Sergeant:
  • 457 Answers
Have you heard about Spybot its free and kicks Ar...... Trully try it its here: http://www.spybot.com
Posted on Sep 11, 2007
  • 41 Answers
Hi, does the mouse move around the screen rapdily, while you are just using it normally? if so, it could be a driver fault for the mouse or something similar. this has happened to me before, and the way i solved it was updating the driver for the mouse. try doing that and see if it works.
Computer slow to start,open files, load web pages, slow shutting off.
try to delete large file or free space your disk , you can see your CPU proccess in task manager if your cpu work 100 % ,that makes your laptop become slow , try to disable program on start up windows->run->msconfig disable program and then try to maintain your laptop performance with utilities like advance system care or tune up utilities , defrag your harddisk , if your laptop still slow , try to reinstall your OS if this happen , then your hardware have trouble
Feb 17, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Tip
Computer CPU/Processor maxed 100%
Is your computer experiencing a CPU that is running at 100% Is your computer experiencing slow performance?
You can view your CPU utilization and other performance stats using Windows Task Manager. Press Ctrl + Alt + Delete and bring up Task Manager. Go to the performance tab.
The top of this screen should show your CPU stats.
In Linux you can use the TOP command,
Type the top command:
$ top
A CPU that is running at 100% utilization is not necessarily a problem. When the computer is booting up, or coming out of sleep mode, it may max out the CPU which is normal. The CPU will be utilized fully in order to bring the computer up as fast as possible. Some computers will even utilize the CPU while it is idle, to complete background task such as disk cleanup and file reallocation.
A problem will occur if the CPU stays maxed out. If it stays at 100% for more than a couple of minutes, you may be experiencing degraded computer performance.
Steps to reduce performance degradation.
-In a limited number of cases, software bugs can cause CPU utilization to spike. You will know this is the case if you are using a computer program(that is not hardware intensive like photo/video editors) and notice degraded computer performance. Check your CPU stats while running the program. If this is the case, check online for solutions and possible upgrades which resolve bugs in the software.
-You can reduce Windows start up programs, which will speed up the boot/wakeup process. You can do this from the MSCONFIG window. Go to Start > and in the run box type "msconfig". Go to the "startup" tab and you can uncheck which programs you do not want to start with Windows.
-A majority of the time a computer will get to a point were the hardware will need to be upgraded in order to handle the work you are doing. Common computer upgrades are memory, cpu, motherboard and hard drive.
-G33k
on May 15, 2011 | Computers & Internet
Why does my windows 7 max out all four of my quad-cores cpu when coming out of sleep mode? I've already replaced a power supply. Any suggestions.
Hello there,
There are probably multiple programs that run on start up that is causing your system to work hard. To resolve this issue, click on the start button and search for "msconfig." Open up Msconfig.exe and head over to the Startup tab. Uncheck anything that you do not immediately need and restart the computer. This should resolve the issue. I hope this helps! Thumbs up are much appreciated.
May 04, 2011 | Microsoft Windows 7 Ultimate for PC
Very difficult to move the cursor around. It seems to be stuck and does not allow me to easily navigate. When I am inside my email browser it moves just fine.
Turn your computer off. Unplug the mouse or the wireless transmitter if it is wireless. Start the computer and wait for all programs to load. When they are all loaded plug the mouse in and wait for the drivers to be loaded. It should work fine now.
Mar 06, 2011 | Computers & Internet
My word processing software continues to move the cursor at the wrong time. When typing the cursor will move to the beginning of the previous word. I tried slowing the pointer speed problem still appears....
First uninstall world processing software then reinstall from disk. You can uninstall it from start menu->control panel->add remove programs you can also repair it from there. Also speedup the computer wit below method. Remove temp files from computer. Press windows key + R then you can see type in run "%tmp%" without "" then press enter then remove all temp files.Type in run "prefetch" without "' then press enter remove all prefetch files. Type in run "chkdsk /r" then press enter then press "y" then restart computer then it fix errors on harddrive. Scan computer updated antivirus it is best antivirus. Download it's free version from below link. Click here Download and install then update it from internet. Then scan computer in boot time avast scanner. Then check.
Let me know if you need further assistance. Thanks for using FixYa.
Aug 14, 2010 | Computers & Internet
My desktop pc hangs frequently. the cursor just doesnt move.help
if your PC hangs continously that means your CPU utilization is above 100%.... try to minimize the services of your computer..... you can disable service through Run command and type msconfig
here uncheck all unneccesary program in start up and services....restart the system
Mar 30, 2009 | HP T5730 1GB/1GB + L1750 17" Monitor PC...
Emachines Keyboard Model No. KB0511
Here you go:
Enter
The computer brings the cursor to the beginning of the next line. This key can also be pressed
to open a program after you have HILIGHTED* it. It will execute a command.
Shift ▲ Hold the shift key down and press the letter key you want to make a CAPITAL letter.
This key is also used to type the charters at the
top of some keys. Eg: Shift + 1 = ! or Shift + 2 = @
Caps Lock
Makes all letters CAPITAL letters. When the Caps Lock key is pushed, a light will
show up on the upper right corner of your keyboard
next to the capital “A”. When caps lock is turned on it remains on until you press the Caps Lock key
again. When you press the Shift key when
Caps Lock is on, a lower case letter will be produced.
Space This key places one space every time it is pressed. (The long, unlabeled key at the
bottom center of your keyboard).
←Backspace Deletes the character to the left of the cursor each time you press it. (If you hold it
down it will continue to delete so be careful).
Delete Deletes the character to the right of the cursor each time you press it.
Home Brings you to the beginning of the line the cursor is on.
End Brings you to the end of the line the cursor is on.
Esc Located in the upper right corner of your keyboard. Cancels an incomplete command;
it will also close an open menu.
Moves the cursor to the left one space each time it is pushed; does not delete the
character.
Moves the cursor up one line each time it is pushed; does not delete the character.
Moves the cursor to the right one space each time it is pushed; does not delete the
character.
Moves the cursor down one line each time it is pushed; does not delete the character.
Insert Deletes the character to the right of the cursor and replaces it with whatever is typed on
the keyboard.
↔Tab Moves the cursor to the tab marks and between columns.
Shift + print screen Prints what is on your computer screen.
Highlight (to select) To make the item stand out. To choose or select it.
? *When an icon is highlighted (left click the mouse button one time while the cursor is pointing at
the icon), the program has been chosen and the name of the icon will change color. When this has
happened, you may press the Enter key to open the program.
? *To highlight a character or characters, move the cursor, using your mouse or the arrow keys, to
the left of the item you wish to select. Press the left mouse button and hold it down while you
move the mouse to the right. Let go of the left mouse button and your item(s) should be
highlighted. Then you can choose what you want to do to the selected item(s) e.g. bold, underline,
delete, italicize, etc.
“Drag and drop” Move the cursor to the item, click the left mouse button and hold it down.
Move the mouse, while holding down the left
mouse button, to the location you want to move the item. Let go of the left
mouse button.
Cursor - The arrow on your screen. The mouse is used to move the cursor.
Let me know if this helped
Jan 02, 2009 | E-Machines eMachines Desktop PC
I have an acer netbook and occasionally i get a weird symbol when i move my cursor. it's almost like a bullseye. it pauses my cursor until it goes away and then in can continue. what is this?
This is a custom cursor that has been setup by either:
A program on your computer
A custom cursor program like free cursors or something.
Check you computer for programs like "smiley cursors" or check the windows control panel and open Mouse settings to see if you have any custom pointers.
It is possible that.. instead of an hourglass.. somebody, or a program has set a custom pointer for your mouse.
The pointer changes to an hourglass in any windows setup by default when it wants you to wait for something that is happening in the background to finish processing.
Check for spyware and viruses as well.. customer cursor websites are great at getting people to install them and you get infected sometimes.
www.techvisitor.com
Oct 31, 2008 | Computers & Internet
My computer continuously restart
ok....first off
1. Is your computer a laptop or desktop
2. Which operating system are you running
3. When did this start happening and what were you doing last?
Please let me know so that I can further help you..
Thanks
~~Jasta~~
Mar 21, 2008 | Computers & Internet
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
41 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
