Question about Toshiba Satellite P100 Notebook
Toshiba satilite P100...wont turn of
I was on My laptop, worked fine. Set it down(running) for 5 minutes,went to use it again and power was off...when I tried to reboot it nothing happens, not even a battery light....absolutely dead. (the battery was full charged and plugged into charger when it happened)
  • michellehard Apr 12, 2009
    I have tried all the above...there is a light on the ac adapter that does come on..but thats it.....computer is completely dead, no lights...I did try taking out the battery and starting from just the adapter...nothing....put battery back in...nothing. Held "start button" for 15 seconds..nothing.
    yes, I have tried all the above....still completely dead. (and thank you so much for Your assistance with this, its been quite a pain)
    Scholar:
  • 58 Answers
Try these:
1. Can you plug something else besides your laptop into the outlet...verify you have power?
2. Is there a light on your AC adapter...when you plug it in?
3. Try removing your battery and plugging it in, and verify that your AC adapter is working (somehow, if it has no indicator light)
4. Then unplug it, put the battery back in and see if it will start.
Let us know what happens after you try these.
Posted on Apr 12, 2009
  • M Nelson
    M Nelson Apr 12, 2009
    3. Try removing your battery and plugging it (THE LAPTOP) in, and verify that your
    4. Then unplug it (THE LAPTOP) , put the battery back in and see if it will start.
    I reread my solution and I want to be more clear.
    good luck
  • M Nelson
    I'm thinking...there has got to be something else to try before taking the laptop apart...Any ideas anyone?
How to check out or look for problems with the lcd monitor on toshiba satellite p100
The internal screen is faulty. Check the inverter first. (under the display).
Jan 20, 2013 | Toshiba Satellite P100-102 P100-103...
Runs fine untill i plug lcd in ,then shuts down
Might have a bad Inverter module Cab be replaced by computer repair store.
Jan 19, 2013 | Toshiba Satellite P100 Series / Satellite...
Toshiba laptop P100-ST9612 majors problems--NOT fixed by Toshiba.
oooo man that ones a doozy, if its the one with the go9700 video card its a pretty bad model. the card brand new is 700+ from toshiba. i have run into that problem quite a bit.
Nov 30, 2009 | Toshiba Satellite A105 Notebook
My computer starts to load windows, then loses all power,
Does the same thing happen when you try to load the BIOS. (press keep pressing F2 when you turn on the computer). If it happens while the computer is in the BIOS window then its your power supply that is fried.
It does sound like the power supply is fried though. In which case the laptop will need to be taken in for service.
Oct 03, 2009 | Toshiba Satellite P100 Notebook
Power light is on, and nothing happens.
The RAM may have been "jammed up" when it was put to sleep. You said you powered down completely and then started up again. How long did you leave it before turning it back on? Try it again, but this time, unplug the adapter from it and also take out the battery so there is absolutly no power going to it. Leave it like that for about 5/10 minutes and then try it again.
Hopefully that will help you out
Sep 23, 2009 | Toshiba Satellite A60 Notebook
The three inputs/outputs on the front of mt satilite p100 toshiba ,whats the third one for??
Toshibas have an output for using an tv through composite output. It requires a special cable with a mini jack on one end and three rca male ends on the other. The yellow one for video and the red and white ones for audio.
Jan 16, 2009 | Toshiba Satellite P100 Notebook
Laptop works fine until the screen turns complete black...
Well you can look if you pluged cable into GeForce not into motherplate second you can try it on another laptop if it works well you must repair your computer
Dec 31, 2008 | Toshiba Satellite P100 Notebook
Laptop
Hi, according to what I understand his equipment it operates well, only that the screen appears in black, does not show anything on the screen, though the equipment operates well, it is possible that the fault this one in the FL Inverter, that is the inverter of current of the screen, which gives the take-off of the lamp of back light, the same one is in the low part of the screen behind of wave mask of the screen
Crash
These are processor intensive tasks that generate alot of heat from the cpu. The motherboard is designed to turn off immediately when a certain heat threshhold is reached. Sometimes the cut off point can be set in the BIOS, sometimes not.
Check your vent holes for clogging. Listen specifically to be sure the fans are coming on. Also feel the top and bottom of the laptop right after it cuts off. If it is heat related, you might have to partially disassemble to clear the lint and dust from the heatsink itself.
Dec 30, 2008 | Toshiba Satellite P100 Notebook
My toshiba satellite p200-140 laptop will not start up. the power button lights up but nothing else happens. it was working fine last night
My laptop had a similar problem. I left my laptop running and some time later when I went back to my laptop, it would not startup. The power light seemed to be on but the laptop would not function. I tried several things like pressing on the power key for some time without any success and also tried all sorts of alternate buttons and sequences.
I resolved the problem by first disconnecting the power cord then by removing the battery for 5 minutes. I then re-installed the battery then connected the power adapter.
As soon as I turned the power button 'ON', the laptop booted up again.
Hope this works out for you.
Regards,
Rick
Sep 28, 2008 | Computers & Internet
Open Questions:
Toshiba Satellite P100 Notebook Logo
203 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
