Question about Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
My hoomelite chainsaw bogs down when i go to cut wood - I have to let off the chainsaw and let engine get back up to speed -why
  • 571 Answers
Would check sprocket teeth as sprocket is probably worn out. Causing drag of chain.
Posted on Apr 12, 2009
When go to cut engine is runnig but chain stops when touch the tree
Hi Pam:
Using chain saws takes a bit of getting used to, and it can be DANGEROUS.
- The chain must be sharp to be able to cut properly, and a sharp chain "bites" into the wood.
- Before you touch the chain into the wood, you have to speed up the engine. This takes some getting used to.
- Try this technique: With the chain about an inch above where you want to cut, squeeze the throttle about half way so the chain is spinning. Touch the chain to the wood and increase the engine speed as the chain starts to cut. The harder you cut, the more power you need to apply.
After a while it gets to be second nature.
Work Safe, and get an experienced friend to help with some "hands on" coaching.
Cheers.
Nov 26, 2015 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chainsaw problems
You are running it too lean and running too hard. doubt if it will last anytime at all before the piston freezes up. Dont forget to mix oil with the gas at the proper mixture, take to the saw shop and have them adjust it as I see you don't have it adjusted properly. The high and low jets need adjusting. Turn the high speed jet counterclockwise until it starts to cackle when it is running at top speed. Then when idling give it full throttle for an instant. Does it instantly have power or does it go blah. If it goes blah and does not engage quickly with power then turn the low speed jet on the carburetor to the left as you keep trying this. Only turn it a fraction at a time like say 1/8 of a turn at a time then try it again. Once you have full power when you engage the throttle, I mean it has to be instant then turn the low speed 1/8 turn more. Recheck the high speed jet by giving throttle for full speed. Do not let it scream, you must adjust the high speed jet til it starts to cackle. That way it stays in control and will not scream unless you are in wood cutting under a load. By the way the low speed jet should also be adjusted to give you more power when you are cutting as you first hit the throttle and not bog down. Do not get confused with the chain stopping and hung up so it wont turn, I am talking about the engine and it powering the chain when it is free to move in the wood when cutting. Anyhow don't run your saw to the point of a red muffler. If you want to use your saw again. It's not good!
Dec 23, 2013 | Garden
42cc 18 inch craftsman chainsaw model 358-351910-18. Saw runs great at idle or while not cutting wood, when starting to cut wood just after the entire bar gets into the wood engine bogs down and chain...
Generally this is a fuel / air ratio problem. Usually it can be solved by a carb adjustment. On the carb there are usually two screws, one marked low or L , the other marked high or H. Low is your adjustment for idle mixture, high is for mixture at full throttle. The saw should Always be adjusted to run well during the cut. Make adjustments a little at a time, then try The saw. Continue small adjustments untill the saw is performing well at full throttle while Cutting.
Aug 09, 2011 | Poulan Pro Chain Saw 46cc 20"
When the router is at slower speeds, I can stop the motor when pushing wood through a bit. when I back off, the motor starts up again. Is this normal or do I have a problem with the router.
Is it a variable speed? Routers only cut at high speed, wood anyway, if it is variable speed, They must think you will be cutting something soft, I don't know, But they are like a dentist's drill, when they slow down, they don't cut, Keep that thing on high and make some dust, it should not bog down, If it does, check the brushes, if it still does, it has lost it's power and is basically shot. get a new one. Hope this helps.
Feb 27, 2011 | Porter Cable 3 1/4 Hp Bb Router
While cutting the chainsaw bogs down and stops
Check the air filter and the muffler if either are plugged up it will not run smooth. Carb hi and low screws are very sensitive so if you change them, only move them a little at a time.
Jan 02, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
I am borrowing my friends brand new Husqvarna 142 which has never been used and she cannot find her owner's manual. What is the oil to gas ratio?
That should be a 50:1 gas to oil ratio. Just make should the measurements are concise, and that your fuel mixture is well mixed. If anything you,d prefer to err on the side of a little tto much oil rather than not enough.
If it is brand new, I'd suggest runninit at about half speed for a minute or three, then moving on up to about 3/4 for another minute.
When you go to cut, rev the engine up to a fairly high speed before putting the saw to the wood. In most cases, you want to let the weight of the saw do most of the cutting, versus bearing down on the sae. Yhat puts undue strain on it, sepecially for a used saw. Try not to allow the saw to "bog" down, so the engine speed drops considerably while cutting.
Sirwriter
May 17, 2009 | Husqvarna Garden
Loses power when trying to cut wood
Check the muffler screens first. Then the spark plug. If not the case, then adjust the High setting on your carb. Prolly starving for fuel under engine load. If it is still a problem, Pull the carb and clean it.
Apr 27, 2009 | Homelite ZR10926 16" Chain Saw
My 345 chainsaw bogs down when it hits wood
There are two idle screws one high, and one low. Your high adjustment idle screw needs to be adjusted.
Jan 18, 2009 | Husqvarna Forest & Garden No.967012396 345...
Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
733 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
