Question about Kenmore 24032\24036 Top Load Washer
WHIRLPOOL KENMORE WASHER DRAINS BUT WON'T SPIN UNTIL POWER IS TURNED OFF AND THEN TURNED BACK ON
  • Anonymous Apr 22, 2009
    Drains but won't spin out...
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
My kenmore washer won't drain or spin. I took out all the water & it still won't spin. I hear the lid "click" and I hear a "hum" when I turn the knob to spin, but nothing else...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Jan 27, 2011 | Kenmore 24032\24036 Top Load Washer
I have a kenmore washer 70 series it wont drain or spin it did work until it got to the drain cycle and then quit
Nov 07, 2010 | Kenmore 22422 Top Load Washer
Kenmore heavy duty extra large capacity washer will not drain or spin. model #13212200
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.13212200&pathTaken=partSearch
If it neither drains nor spins, the first thing to check is the Lid Switch. This prevents the machine from draining and spinning if the lid is open.
I assume that you cannot hear the motor trying to turn.
See the following for how to access the console and Lid Switch connection.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=6f8112b458c05fcc8f6d1a4139b9a723
Following is a Whirlpool installation and maintenance PDF on top load, direct drive washers. It has a description of how to by-pass the switch.
To bypass the switch, you only have to disconnect the power to the washer, remove the two plastic clips from the console,
remove the two screws under the clips, tilt the console back, unplug the switch and using an short piece of insulated wire,
If it works, the Lid Switch is a relatively inexpensive part.
Apr 25, 2010 | Kenmore Washing Machines
Wont run cycles. fills up but wont spin or drain
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
To bypass the switch, you only have to disconnect the power to the washer, remove the two plastic clips from the console, remove the two screws under the clips, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Apr 17, 2010 | Kenmore 23822 Top Load Washer
Won't agitate
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.92596100&pathTaken=partSearch
If it neither agitates,drains nor spins, the first thing to check is the Lid Switch. This prevents the machine from draining and spinning if the lid is open.
Apr 17, 2010 | Kenmore Washing Machines
Kenmore topload washing machine that wont switch to drain
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Then, see the Whirlpool / Kenmore Service Manual for top load, direct drive washers.
Normally, this would appear to be a Lid Switch or Neutral Drain problem BUT since it is re-filling , it sounds like a Timer problem.
See the Service Manual for how to test / replace the timer.
Apr 16, 2010 | Kenmore Washing Machines
My kenmore washing machine series 90 model 20902 does not drain, what can i do?
Apr 05, 2010 | Kenmore 24032\24036 Top Load Washer
My Kenmore washing machine will not move past rinse to spin and drain. What do I do to fix this? Thanks, Matt Tills mtills@wsteele.com
Mar 27, 2010 | Kenmore Washing Machines
My Kenmore 90 series washer won't spin or drain
Mar 25, 2010 | Kenmore 24032\24036 Top Load Washer
Wont spin
Nov 24, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
79 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
