Question about IBM 4610 TG4 Thermal Label Printer
IBM 4610 TG4
I need the service manual for this printer i am trying to fix two of them one of them is not cutting the paper the second the thermal printing and cut asm is totaly apart for problem of tha courier company y i dont the part number i need to buy and put it togheder. thanks in advance
  • 2 more comments
  • WilsonCheung Jan 09, 2008
    I am having the same problem.
    My printer cannot cut paper.
    But it is only occasionally happened.
    Can anyone give me some advice on how to fix this issue?
    thanks in advance.
    thanks in advance.
  • Anonymous Feb 19, 2008
    hi,
    im using a IBM 4610 TF6 docket printer for my point of sale. when i send a test page to the printer, it doesn't stop printing...i have to manually switch the printer off to stop the printing. aslo, when i try to print sales docket from the point of sale software, the printer prints some kind of codes and doesnt stop printing. please help
  • Anonymous Aug 07, 2008
    have a 4610 printer hooked to a 4840 register giving me error on the screen
Jacsmar,
The 4610 has several common routines. One of these common routines is CR.BUFFER.GUILOTINE This routine buffers the guillotine cuts written to the receipt station.  I believe you need to be sure that this routine is inserted in the printing program in order for the guilllotine mechanism to cut.
The routine should have the following defination:
SUB CR.BUFFER.GUILLOTINE PUBLIC  The other routine is:
DO.GUILLOTINE.CUT
Also simply listen to hear if the knife mechanism is trying to activate after printing a receipt.
Hope this helps,
G. Kiely
Posted on Oct 24, 2007
SOURCE:
Problem printing with IBM 4610 TF6
It can be a connection problem, since the printer and the computer are not communicating, probably the cable is bad, so if you have a different cable that we can try that will be better so we can check if its only a cable problem ...
Hope that helps......
Aug 28, 2008 | IBM 4610 TG4 Thermal Label Printer
IBM POS and QuickBooks POS
wow...let's see what's up with this...so, you need drivers for that printer..what windows version you on?
Mar 17, 2008 | Computers & Internet
Suremark 4610 on Sure POS system/ Laptop T23
We specialize in these products.
Capital Computer Group
2425 Enterprise Dr.
#200
Mendota Heights MN, 55120
[email protected]
651-405-8293
We Buy, Sell, Repair, and Refurbish both new and used POS Systems, NCR, IBM... We also offer structured cabling as well as Video Surveillance Equipment.
Give us a call and we can trouble shoot it with you!
Jan 14, 2009 | IBM 4610 TG4 Thermal Label Printer
IBM 4610 TG4 offline.
if it printing trash more than likely you have a driver problem, where are you getting the driver for your printer?
try to look for another driver and test by going to ibm's website:
http://www.ibm.com/products/finder/us/finders?Ne=5000000&tmpl=%2Fproducts%2Ffinder%2Fus%2Fen%2Ffinders&finderN=1000188&pg=ddfinder&lc=en&cm_re=other-_-suprcn-_-download&collectionN=0&sid=304421691223506248263&cc=us&C1=5001220
good luck!
Oct 08, 2008 | IBM 4610 TG4 Thermal Label Printer
IBM 4610 suremark receipt printer
Hello all,
had the same problem and my solution was to install the latest driver available at the IBM service/driver website. Then unistall it with another IBM driver cleaning tool, then repeat both processes a couple of times, until the printer responded. There is some bug on these latest drivers an older Windows versions, so only after some installations and repairs on the first install, windows gets it right. VERY STRANGE but it worked in 2 machines, both IBM terminal and 4610-tf6 IBM printer.
By the way; RS232 ibm cable...I believe its a null modem 9 pin...not a regular serial cable.
Dip pin config: my printers have 4 so; 1ON 2ON 3OFF 4OFF which means
1 size of paper you are using 80mm
2 if you use an IBM software or other:other
3 if xon/off or DTR/DSR:hardware
4 com speed: 9600baud or 19200baud, 9600
That's what I igured out. If you need any more info: mail
[email protected]
FredP
Sep 28, 2008 | IBM SureMark Printer TF6 Thermal Label
IBM 4610 TG4 Printer configurations from windows
Hi
you onli need send commands by excel is ASCII CODE its easy
Apr 10, 2008 | IBM 4610 TG4 Thermal Label Printer
IBM 4610 TG4 Thermal Label Printer Logo
825 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
