Driver dvd My desktop dvd drive is not working. It shows a code 39 when windows trys to fix
    Guru:
  • 829 Answers
Here goes:
THERE IS A RESOLUTION TO THE (CODE 39) WITHOUT having to go to the registry and everything else in God?s green earth that they are suggesting. If you are dealing with this, Please read. IT WORKED!!!!!!!!!
After a 4+ hour call with Microsoft and their VISTA Tech support team re: the very issues that everyone has been shouting about, the (code39) errors and 5.1 sound issues, to my, well not so surprised self, the problems have been easily rectified. WITHOUT all the major things that others are stating that needs to be done that not only could cause serious damage to one?s computer, but could give one many headaches and hours of needless grief. So here it goes, and this is a guarantee fix guys that anyone can accomplish.
First, if you have not dealt with this problem yet, then you have not been fortunate enough to have updated the latest update which is in ? to be causing all this problem. So, Do Not allow update for Windows VISTA (KB938194), This update supposedly has much to do with the blue-ray discs and HD issues in the drives & is causing many computers to malfunction and loose the drives all together forcing a code39. You can read more under your updates, just go in there, but don?t hit update now, just highlight and ask for more information. Then highlight the website for even more details on the update. I have decided that no updates will go through for a while with re: to VISTA until I see how it is going out there by checking online. I have checked that I authorize downloads and updates, but the computer is to check for updates still. If all is quiet for a few weeks, then I will give it a go.
This update apparently resolves some compatibility and reliability issues in Windows Vista and by applying this up date, it states you will achieve better reliability & hardware compatibility in various scenarios. It also states after you install this item, you may need to restart your computer. It states nothing about being cautious with regards to the fact that it may deactivate your drives for your CD & DVD?s. Wow, that?s nice of them. Now here comes the real kicker, they are not unaware of all of this. They in fact were not a bit surprised of my dilemma and were extremely helpful in helping to get it resolved. Of course I had several, in fact ?many? issues I was dealing with and had to go at them one by one, which was why the call was so long. But the drives were the easiest issue to resolve. This morning this update accidently came thru, however slightly changed, seems to be ok, but will be watching it all so carefully. Now my updates are changed to ?Check for updates but let me choose whether to download and install?.
Check to see if this update has been installed in your updates on your computer. Mine went in on the 31st of August, which was when my drives went out suddenly. You can do this by going to Control Panel, Check on Updates, DO NOT UPDATE THIS VISTA UPDATE. IT has shown to be the cause of CD-&DVD drive errors & Causing Code 39 errors. Even if you uninstall this it will not resolve the issue. Either way, you need to restore your computer prior to the date this all started and then begin watching every move you make and Microsoft makes in hopes it does not occur again. With them being aware of it, hopefully it will not. With you being very aware and watching, you also may find the exact cause. I also found that NERO, was causing issues and I need to buy an upgrade of that, so if anyone has NERO 7 or earlier, check it out, it can cause issues with your sound.
RESOLUTION:::
First: Back up all the work that you have done on an external drive from the date that this install occurred or at least from the date of August 30, 2007. You will loose any items that you have worked on or installed in your computer during that time. So I suggest you do this asap before you get too far into doing work on the computer.
Second: Once you have completed your backup, you then will need to restore your computer to the time and date prior to the Microsoft update. I went to Aug. 30, 2007 PM. or when you lost your drives/Code39 appeared.
Close all Programs. Start button & type restore in the Search box of the Start menu & click System Restore to start the System Restore Wizard. Choose a different Restore Point to select a previous Restore point, Click Next. Then another window opens in System restore for you to Choose a restore point. Choose the Date & Time you want the computer to restore to, such as Dec. 30 at 11:30:22 PM. It will also give you descriptions of what was done o your computer on each day, so if you see the exact point that the update was made, then go back one entry earlier to restore. Note that everything after that point will be uninstalled.
This is no different than using the Windows XP restoring points, only I don?t ever recall loosing the installed programs like I did with this. I now know to back up before I do this again and hope it saves anyone else the heartache.
I have my drives back and they are working just fine.
Even my sound seems to be working better, but not 5.1. Which Microsoft stated they are aware of the problem and they are working on it as we speak so to please be patient. They are working with several of the companies that make these specific drives and it should be resolved very soon.
If it is any consolation, and you need the surround sound quality now, I found an excellent third party, (although the point is we shouldn?t be doing this isn?t it!!) but it is: ?SRS Audio Sandbox? Surround Program, (Received ?Best Consumer Software of 2007?) check it out at http://www.srs-store.com/store-plugins/mall/sas-plugin.asp It only requires the use of two speakers, however it sounds like you have a full army of speakers. Very nice, very, very nice with absolutely no drag or skips. Was quite impressed actually and for the meantime, it is worth the $19.95 for me and no headaches. It did not interfere with my system at all and worked quite well with what I already had. VISTA compatible.
Posted on Apr 12, 2009
How to fix code 39 error
To fix this issue. click on the below link.
http://www.fixya.com/support/r3579304-how_to_fix_cddvd_rom_error_code_39
Feb 16, 2010 | Computers & Internet
The DVD RW/CD-RW'S DRIVER is not working
CHeck the Device Manager. Does the CD/DVD Drive show up in Device manager, and when you right click it and choose properties, does it give any error code, like Error code 39?
Normally the CD drives use the default Windows drivers. Try right clicking the HL-DT-ST DVDRAM GSA T50N ATA Device in Device Manager and choose uninstall. Then reboot the computer and Windows will find the device and re-install drivers automatically.
If you are still getting the error, it may be an update or some other program that added data to the DVD's driver data in the registry. Try this:
1) Close all open programs
2) Click on Start, Run, and type "regedit" (without the quotations) and press Enter. Back up (File > Export) the registry before you make any changes)
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • Left Click and Highlight: {4D36E965-E325-11CE-BFC1-08002BE10318} **Make sure you choose this exact key**
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed on the right hand side, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Apr 11, 2009 | HP Compaq Presario SR1420nx...
Drive not showing in WinXP (error code 39)Liteon Combo SOHC-5236v
After loading the Windows, the DVD/CD-ROM drives work properly, but we can not see the drives in “My Computer” (System can not recognize the drives.). When try to run the drives, it shows up a notice “Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code39).” Before solving this error, check the drives connection correctly, then follow the steps below:
Delete Device Manager. Most people will firstly think of Windows “Find New Hardware” when drives missed, but it does not always work out. To fix the problem: open “My Computer”’ “Control Panel” ’“System”’“Device Manager”’ “HDC(Hard Disk Controller) ”, then click “Delete”. Follow the note to reboot computer. After rebooting, the computer will find the Primary IDE Controller and Secondary IDE Controller again and install the drivers. Restart the computer again while the installation is completed. In this, we can get back our CD/DVD-ROM Drives.
The other way is by editing the registry to return the missed CD/DVD-ROM drives (Code 39 error.). Obviously, it is too risky to edit the registry if you are not familiar with it. To fix the error from the registry, carry out the following steps:
Exit and close all applications currently running on your PC.
Step1. Click Start > Run and type in Regedit, press Enter.
Step2. Look for the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\ {4D36E965-E325-11CE-BFC1-08002BE10318}
Delete any of the following registry entries under this key directory:
LowerFilters
LowerFilters.bak
UpperFilters
UpperFilters.bak
Step3. Reboot your PC and open My Computer to check that the CD-ROM drive is visible.
Also, have a look at the Device Manager to see if the yellow exclamation mark and the error code 39 are gone.
System errors are not welcome guests that bring up unhappy computing experience. Registry Easy (www.registryeasy.com) is a professional troubleshooting system maintenance tool that can help you to solve this error and many more.
Article Source: How to fix DVD/CD-ROM drives (Code 39 error) in Windows XP or Vista
Posted on 2 January '09 by , under TECH NEWS.
This worked for me.
Feb 12, 2009 | Lite On (SOHC5236V) CD-RW/DVD-ROM Combo...
GMA 4082n device driver not working properly code 39
First go into Setup (usually F1,F2 or del) at start-up. See if your drives show up there. With Windows running, right click My Computer, left click Properties, left click Hardware, left click Device Manager, left click DVD/CD-ROM drives. Also check IDE ATA/ATAPI controllers. Do the drives show up there? If they do right click on drive and left click Update Driver. If they are not there go back to System Properties and left click on Add Hardware Wizard. This will search for devices. It may ask you to insert Windows CD which of course you can not do because the drives don't work. Try a different drive. When you cleaned out your computer did you delete or uninstall Office? That may be what caused this problem. None of this may work but it is a starting point.
Jan 06, 2009 | Dell Dimension 4600 PC Desktop
Samsung Internal DVD drive and cd-rw drive not reconised
call dell they will help you get the necessary drivers
Nov 26, 2008 | Computers & Internet
Pioneer dvd-rw dvr-k17a
I fixed it my self, redownloaded my Windows and repaired it.
Sep 08, 2008 | Pioneer DVR-107D DVD±RW Burner
Computers & Internet Logo
David Payne
David Payne
