Question about Homelite Garden
What type of spark plug do I need for my Mightylite 17in gas trimmer? and what should the gap be?
  • 571 Answers
RCJ6Y
Posted on Apr 13, 2009
What is the spark plug gap for 18cc weed eater?
search
What is the correct spark plug gap?
The spark plug gap on all products is .025-inch.
What type of spark plug does the unit take?
The size of the plug varies from unit to unit. On trimmers, blowers and hedge trimmers is RCJ-8Y or RCJ-6Y. Follow the spark plug recommendation and replacement procedures in the operator's manual if you are doing the work yourself.
Jun 07, 2015 | Weed Eater Featherlite 18cc 2 Speed Gas...
No spark - coil ???
Could very well be the magnito (coil). You may also want to check the kill switch. If the switch failed in the off position... = no spark. Plug failure could also be the cause, although not likley. Good luck!
Sep 25, 2011 | Homelite Factory Reconditioned 26cc...
No spark. I changed plug and still no spark
First check to see that the (on-off) switch is working properly, if switch checks out, you need to replace coil.
Nov 07, 2010 | Homelite Factory Reconditioned 26cc...
25" /1.5 cu.in. 2-cycle 17" cutting
Easy way to test plug is to remove it from cylinder head, then ground its hex base to side of engine..reattatch plug wire and pull starter cord...Do this is dim light...need to see a nice blue spark. So, do that...check the plug gap and plug condition (even if new)...if it's NOT firing...try another plug...if same...you will need to pull the engine covers off and check the "air gap" of the flywheel magnets to the pickup legs on the ignition coil module. You can gap it the thickness of a regular business card (.010"-.014"). The gap has to be present for the spark plug to produce a spark.
Jul 16, 2010 | Craftsman 25cc Gas Line Trimmer
No spark on UTO 8580 A back pak blower
You could have a bad spark plug or ignition module.
I would find your receipt and find a warranty service center. Reconditioned unit only have a one year warranty on them. If it is in this time frame they will fix it for free.
Dec 18, 2009 | Homelite Factory Reconditioned 26cc...
Homelite trimmer zr40502
Do you have fresh gas? If so is the mix right? If you can get to the carb easy spray some carb and choke cleaner in it. Check the gap on the new spark plug. The gap should be located somewhere in the manual. The big problem is making sure that the mix is right. To much oil in gas will foul plug smoke like crazy and foul the plug and hard to start. Not enough oil and you can seize it up.
Good luck let me know if this helps.
roundo4
Aug 16, 2009 | Homelite ZR40502 Factory-Reconditioned...
Engine runs but blade doesnot
The clutch is not engaging or the linkage to the eccentric that moves the blade is not connected.
May 26, 2009 | Homelite Factory Reconditioned 26cc...
Mightylite 26cs Gas Trimmer
sounds to me like dirt in gas tank dirty or plugged filter screen on fuel line inside gas tank or plugged pinched or obstucted fuel line . also check for the following pin hole in primer bulb bad spark plug dirty or rusty coil or flywheel magnet.or simply dirty or missadjusted carb if i can be of further assistance let me know i would start with the fuel hoses and make sure they are in good shape first ...do the easiest and cheapest things first good luck hope this gets you up and running good mrdmburns@cableone,net
May 01, 2009 | Homelite Mighty Lite Lawn Trimmer
I need a manual for a Homelite Mightylite 17 inch Curved Gas Trimmer with EZ wind Bump Feed UT 21907 Ser #642287
Go to homelite.com then click on service and support, then click order parts then click launch homelite parts catalog, Agree to terms then click continue under model no type in mightylite then find you trimmer in list.
Apr 12, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
91 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
