Question about Dell F3534 Touchpad
Disable dell 5721 touchpad - Dell F3534 Touchpad
3 Suggested Answers
SOURCE:
jell587
  • 447 Answers
SOURCE: Dell Touchpad
You should be able to disable the touchpad from within the mouse properties in the control panel. Uncheck the enable touchpad option in the devices section.
Posted on Feb 22, 2009
  • 16 Answers
SOURCE: must disable touchpad
Is the problem being caused by your palm hitting the surface of the touchpad? This happens with many people. There is a setting for the touchpad which will let you set how sensitive the touchpad is, thereby eliminating your problem.
Posted on May 20, 2009
How do I disable the touchpad on a Dell Inspiron 1510?
Anonymous,
You can click the link below for information on disabling your laptop touchpad.
Disabling or Enabling the Touchpad On a Dell Notebook
http://dell.to/1BN3fzX
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Feb 24, 2015 | Dell Computers & Internet
Can't disable mousepad on dell vostro
ONE VERY EASY SOULTION THAT I HAVE SEEN MANY TIMES IS TO SIMPLY COVER UP THE TOUCHPAD WITH A PIECE OF THIN CARBOARD AND LIGHTLY TAPE IT. I HAVE SEEN THIS METHOD IN A FEW OFFICES. GOOD LUCK. AND ALSO
Feb 24, 2014 | Dell Vostro 1550 USB Docking Station...
Disable dell e6410 touchpad when mouse is connected
Hi, you can do this by going into the control panel> Mouse> Touchpad settings> disable touchpad when other external usb pointing device is connected.
Nov 13, 2017 | Dell Latitude E6410 Laptop
Cursor problem
Disabling the touchpad on a Dell Inspiron can be useful when typing for long periods of time, or using an external mouse. Bumping or tapping the touchpad while typing can cause cursor jumping and unwanted results. Use the touchpad software to enable or disable touchpad controls. Download the driver for your touchpad at the Dell Support website.
Click on the "Touchpad" icon in the task bar. If the icon doesn't appear, you can download and install the driver for the touchpad from the Dell website, or choose "Start" and "Control Panel." Choose "Device Select" on the touchpad menu, or choose "Mouse" in the "Control Panel" menu and "Device Select." Click "Disable" under "Touchpad" to turn off the touchpad, or click "Disable Touchpad/Pointing Stick When a USB Mouse is Connected."
h
Feb 28, 2013 | Computers & Internet
My touchpad has been disabled on my dell inspiron m5030
Hi c_louise_moo,
You can find some instructions on disabling the touchpad here:
http://www.labnol.org/software/disable-touchpad-on-laptop/14052/and this link has a piece of freeware called TouchPad Pal which allows you to disable the touchpad while you're typing (which should be the only time it gets in the way really) http://download.cnet.com/TouchpadPal/3000-2084_4-11143760.html
Hope it helps.
Thank You for using Fixya.
Sep 09, 2011 | Dell Inspiron M5030 Laptop
How to disable my touchpad on Dell Inspiron M5030 (only) when my Logitech external mouse is connected? Thanks.
You can find some instructions on disabling the touchpad herehttp://www.labnol.org/software/disable-touchpad-on-laptop/14052/
Hope this helps!
May 19, 2011 | Dell Inspiron M5030 Laptop
I can not disable touchpad of INSPIRON 1545 of DELL Computers There is no option for disabling touch pad in the MOUSE option of Control Panel
Go to the Control Panel. Under the 'Hardware and Sound' options, click 'Mouse'immortal4u.png
Since you have a Dell laptop, you'll have a special tab called 'Dell touchpad' in the window that pops up. Click on the touchpad picture in the window.
In the new window that appears, click 'Device Select'
Click on the 'Disable' radio button to disable the touchpad completely. If you want to disable the touchpad of your Dell laptop only when an external device like a mouse is attached, check the last option that says 'Disable Touchpad/Pointing Stick when external USB mouse is present'
That's it. You've disabled your laptop's touchpad for good. If you don't find an option to manage your touchpad in Mouse settings, you have to install Synaptics drivers from here. Similar options can be found in other laptops as well.
Good luck ! if your problem is solved don't forget to rate
Dec 30, 2010 | Computers & Internet
Must disable touchpad
May 07, 2009 | Dell Inspiron 1525 Laptop Jet Black
Dell Touchpad
Feb 22, 2009 | Dell Inspiron 6400 Notebook
Touchpad/mouse problem
Same thing here, I can not find out how to diable the touch paid. I spent an hour chatting on-line with Dell Tech support and they did nothing to help!! I am starting to think it can not be done on this machine. Please someone tell use how to do this?
Jul 10, 2008 | Dell F3534 Touchpad
Computers & Internet Logo
65 people viewed this question
Clive
Clive
Alun Cox
