Question about LG DLE2532W Electric Dryer
NO HEAT HEATER IS NOT WORKING, LINT LIGHT WAS ON , CLEANED IT AND LIGHT WENT OUT. STILL NO HEAT??? HELP
  • 641 Answers
It could be a defective heating element or thermostat. Open the service panel and check for 115/220V on the heating element tags. If you can read the 115/220V, you should replae the element. In case you can't read it - the thermostat should be replaced. Good luck!
Posted on Sep 12, 2007
  • 21 Answers
You should check the thermal fuse - my guess would be a lint blockage elevated the temperature and activated the thermal cut out fuse. You can locate it and short circuit it to confirm that it is the problem and if it is replace it
Posted on Sep 13, 2007
SOURCE:
Dryer wont heat up
Small 3oo f fuse mounted on the heater element is probo blown from over heat due to vent blockage.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 30, 2015 | Roper REX3614KW Electric Dryer
Flashing clean and heat light?
Sounds like you might have lint build up. Clean out lint trap and remove the back and clean out all lint. The lint build up could be causing a over heating problem. And this is a fire hazard.
Aug 08, 2015 | Whirlpool Dishwashers
My Bosch Nexxt 500 dryer keeps tripping the hi-limit cut out.
Try checking your exhaust vent pipe for excessive bends and kinks, make sure there is good strong airflow coming out the exhaust where it exits the building.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Dec 12, 2013 | Bosch Nexxt 500 Dryer
Hi there, I'm hoping somebody can help me out? I have a washer/dryer and the dryer is not working. The drum rotates but does not heat up and the clothes are still very damp/wet Whilst the washer...
There are several reasons why a dryer would not heat up the clothes.
  1. The vent is plugged with lint or the blower set-screw is loose (blower slips on the motor shaft instead of spinning full speed). If you do not have good airflow at the outside exhaust when the dryer is running, you'll need to check the ductwork all the way back to the lint trap. If the lint trap is torn, repair or replace it.
  2. The heaters are not working due to a bad contact in the timer or one of the two thermostats. Check for continuity in the heater circuit with the dryer unplugged.
  3. The heaters are burned out. Note the plural - most dryers have two heaters, one for low heat, the other for medium, and both for high. Try a different heat setting and see if you get warm air. If you do, the heater you normally use is the problem.
Jul 03, 2011 | Hoover Washing Machines
Makes a noise when turned on.. sounds like fan or fan motor.
I would make sure the heater is unplugged then remove backscreen and foam filter. Carefully clean firter with warm water and alittle dish soap. Rinse thouroughly and air dry it. I would clean any hair lint or other debris from fan blades,motor and heating elements. You can use a tooth brush to clean heating elements.You can also use a drop or two of light grade machine oil or WD-40 on blower shaft where it enters the motor. Wipe off any excess oil and when you're sure filter is dry reassemble and try it. Hope this helps you.Thanks
Nov 16, 2010 | Pelonis Disc Furnace Heater
Dryer does not start
Check the fuse on the blower housing.
To get to the heating element on most of these dryers you remove the back dust cover: whirlpool%20dryer.jpg 1. Hi Limit (small limit upper right hand side of this pic) the most frequent problem if dryer RUNS but no heat. 2. Heater assembly. 7. Control thermostat(s). 5. Fuse(350F), if blown(open) the dryer will NOT run. 4. Heater element.
Sep 13, 2009 | Dryers
LG DLE2512W Will not heat even after replacing Heating element.
there are a couple of thermal fuses also that could be blown inside the back check these also
Aug 25, 2009 | LG DLE2512W Electric Dryer
Amana electric dryer will not heat/ LEA60AW Everything works fine but no heat...have cleaned all lint from inside the dryer by taking front panel off. What else should I check.... I noticed it wouild come...
Check for 220 Volt at the heater entrance to the heater box (accessible from picking up the top on most models). If you have 220v there the heater element is out. If you don't have 220v on the terminals of the heater the problem is in the controls. The fuse link, the timer contacts, the centrifugal switch on the motor, and the heater safety thermostat and operating (s), are all suspect and have to be eliminated 1 by 1. Hope this helps. With any luck all you need is a new element. Clean the duct out while replacing the heater if so because the main thing that causes heater element burn out is low air flow a kinked Dryer vent hose, lint, and plugged up fan on the motor are the 3 main causes of low air flow. If yours has little holes in the inside cabinet these can get clogged with lint also and cause a problem. Hope this helps and please rate me accordingly Thank you and good luck.
Feb 23, 2009 | Amana ALE643RB Electric Dryer
Hi the my filter light keeps flashing and iv got no heat!
My guess is that the heater element has gone out. There could also be a lint clog in the exhaust vent...it takes air out through the filter...across the heater element....and back through the tumbler to heat the clothes. This is usually what causes heat elements to go out is the excess lint that gets on them and causes them to overheat and burn out!
Dec 14, 2008 | Whirlpool LEQ8000JQ Electric Dryer
Whirlpool Duet Dryer - Working but no heat
it sounds like your heating element is gone bad. there is no heat if they burn out or get corroded
Jun 28, 2008 | Whirlpool GEW9250 Electric Dryer
LG DLE2532W Electric Dryer Logo
208 people viewed this question
Top LG Dryers Experts
jimorris77
Craig Butler
Craig Butler
Marvin
Marvin
Are you a LG Dryer Expert? Answer questions, earn points and help others
