Question about Microsoft Xbox 360 Console
Wer can u insert controller (with cable)into xbox
U can plug controller cable into front of xbox at the USB port
Posted on Sep 11, 2007
Ho w to fix x box from controller to x box is really slow how to make it normal
Learn how to connect a wireless or wired controller to your Xbox 360 console.
Connect a wireless Xbox controller
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  1. Press and release the connect button on the console.
Xbox 360 E console fbbfb609-f7ed-4e6e-bd35-7543b1c20d61.png?n=xbox360-connect-m-s.png Xbox 360 S console Original Xbox 360 console 342c6e70-9e56-43d8-bb3a-05f5411040bd.png?v=1#xbox360s-connect-m-m.png 170df81e-0a79-49be-8236-a0fb68eec37b.png?v=1#xbox360-connect-m-m.png
  1. Within 20 seconds, press and release the connect button on the controller.
  1. When the lights surrounding the power button on the console stop flashing, the controller is connected.
On the Xbox 360 S console, each connected controller is assigned to one of four positions. Each position corresponds to a lighted section around the console power button and the controller Guide button. On the 360 E console, a solid green light on the front of the console indicates that the controller is connected. To determine the player position associated with your accessory, look at the ring of light that surrounds the Guide button on the controller.
c9341988-8ed5-4217-9b87-353de50efbec.png?v=1#connect-xbox-controller-m-m.png 5e4ab6ab-8cb0-41e6-a037-b88221a430c7.png?n=connect-xbox-controller-360-m-s.png
71add0b7-ddf2-4439-b4b4-f50f156d92b7.png?v=1#controller-batteries-m-m.png If the controller does not turn on, check the batteries. Insert fresh AA batteries, making sure they are correctly positioned in the battery case.
You can also use the Xbox 360 Play & Charge Kit or the Xbox 360 Quick Charge Kit to power the controller. Learn more about Xbox controllers and chargers.
To connect additional controllers, follow these same steps again. You can connect up to four controllers to the console. Each connected controller is assigned a position that corresponds with the lighted sections that appear around the console's power button and around the Guide button located in the middle of each controller.
  • To disconnect a wireless controller, press and hold the Guide button for three seconds, and then choose to turn the controller off.
  • When you turn off the console, the controller will reconnect the next time you turn on the console.
  • The controller can be connected to only one console at a time. You can connect the controller to a different console, but the connection to the previously connected console will be lost.
Connect a wired Xbox controller
5fb17f50-7448-45d5-a294-9ea90994f55b.png?v=1#controller-wired-m-m.png Plug the Xbox 360 Wired Controller into a USB port on the Xbox 360 console. There are two USB ports on the front of the console. To disconnect the controller, pull on the connector, not the cable.
cbe46bf0-3a46-4d53-9d8c-6697aa57622a.png?v=1#controller-cable-release-m-m.png The cable on the Xbox 360 Wired Controller has an inline release. The inline release on the controller cable is a safety feature designed to reduce the chance of the Xbox 360 console falling if the cable is pulled.
Wireless controller troubleshooting
If your wireless controller disconnects or cannot connect to your console, see Xbox 360 Wireless Controller disconnects or can't connect.
If your wireless controller does not turn on or loses power, try the following solutions:
Solution 1: Replace the batteries
Insert a new set of AA alkaline batteries into the Xbox 360 Wireless Controller, and then try to turn it on.
Solution 2: Try a different battery pack
If you have another Xbox 360 Wireless Controller, take the battery pack off that controller and attach it to your controller. Then try to turn your controller on.
If your controller works with the different battery pack, your original battery pack might be defective. If your controller is under warranty, you can order a replacement battery pack from Xbox Support . See the Assistance section at the bottom of this page for more information.
If your controller is out of warranty, you can buy a new battery pack from a retail store.
Solution 3: Try a rechargeable battery packIf you or a friend has an Xbox 360 Rechargeable Battery Pack, attach that battery pack to your controller and try to use your controller. If your controller works with the rechargeable battery pack attached, you can buy a new battery pack from a retail store or order a replacement battery pack from Xbox Support. See the Assistance section at the bottom of this page for more information.
Feb 08, 2013 | Microsoft Xbox 360 Controller
How do i reactivate the wireless controller to my xbox 360
How to Configure an Xbox Controller Fotolia.com"> configure-xbox-controller-800x800.jpg Configure you Xbox controller.
The Xbox 360 utilizes two types of controllers: wired and wireless. Like most operations on a video game console, configuring a controller requires little effort. You can either plug the controller into a port on the Xbox 360, or sync a wireless controller using the console's built-in controls.
Difficulty:Easy Instructions
  1. Wired
    • 1 Connect the controller's cable to the in-line release cord. This cord prevents you from accidentally pulling the Xbox 360 along with your controller during game play.
    • 2 Insert the in-line release cord's USB plug into the USB port on the front of the console.
    • 3 Turn on the console to activate the controller automatically.
    Wireless
    • 1 Insert batteries in your wireless controller, if necessary.
    • 2 Hold down the "Guide" button on the controller.
    • 3 Push the Xbox 360's "Connect" button, located on the front of the console.
    • 4 Push the controller's "Connect" button to sync it with the Xbox 360.
Read more: How to Configure an Xbox Controller ' eHow.com http://www.ehow.com/how_7780486_configure-xbox-controller.html#ixzz1PRsAYmUA
here is a video on how to sync your wireless controller to your xbox360 console
http://www.youtube.com/watch?v=GpV-b1de2lM&feature=related
if you think this help please rate me sir thank you so much!!!
Jun 16, 2011 | Microsoft Xbox 360 Console
I dont know how to set up my xbox live with an eathernet cable can you help?
Hi there
Turn off the Xbox 360 by pressing the power button on the front of the console. Afterward, shut off your modem by unplugging its power cord.
  • 2 Insert one end of the Ethernet cable into the Ethernet port located at the back of your Xbox 360 console. After that, insert the other end of the cable into your modem.
  • 3 Replug the power cord into your modem to turn it back on. Once it is active, press the power button on your Xbox 360 to turn it on.
  • 4 Navigate to "My Xbox" then "System Settings." Afterwards, select "Network Settings" then "Test Xbox LIVE Connection." You will be notified on-screen if the connection is successful.
  • Read more: How to Set Up Xbox LIVE with an Ethernet Cable | eHow.com http://www.ehow.com/how_6714462_set-xbox-live-ethernet-cable.html#ixzz0xBK8Zctz
    GOODLUCK!!
    Aug 20, 2010 | Microsoft Xbox 360 Console
    My xbox360 dosent show any lights on power button
    This could be that your hdmi cable is not inserted correctly, make sure that it is pushed fully into the console and the tv.
    let us know if this helped.
    Jan 18, 2010 | Microsoft Xbox 360 Console
    Xbox 360 With One Red Light.
    Hello Sir
    1) Remove your hard drive and/or memory units.
    2) Run "Initial Setup" under the system blade.
    3) Decline inserting HDD or memory unit when prompted.
    4) Sync your controller and pop in a game.
    Fix-shad0w
    Nov 25, 2009 | Microsoft Xbox 360 Console
    I have a old xbox system and my wireless controllers by pelican brand pl-2050 one will not link up to the xbox what to do!!
    Check to verify that your batteries are installed correctly.
    - Check to verify that the power is on. Check to verify that the signal LED is blinking
    If this does not solve the problem, do the following:
    1. Make sure your Xbox is turned off.
    2. Remove the battery lid and place 2 AA batteries into the Blade 2.4 Street Wireless Controller. Make sure the batteries are inserted as shown in the battery compartment.
    3. Insert the receiver into your Xbox controller slot of your choice and power up the controller FIRST, then your Xbox.
    4. Press the Connect button on the receiver once. Your signal LED light will begin to flash slowly.
    5. Press the Back button on your controller. This will program the receiver to connect to the controller each time it is uses.
    6. Turn on your Xbox and insert a game.
    Aug 06, 2009 | Pelican PL-2050 XBOX EDGE 2.4 GHZ WIRELESS...
    The connection from my controller to my standard xbox wont work!
    you may have a shortage in your controller cord and may need to buy another one
    Jul 31, 2009 | Video Game Consoles & Games
    Wired X-box controler problems
    bend the cable and have a game playing so that you know when you hit a dead spot.mark the spot that is makeing it pause.go about 3cm above and below it.take a pair of scissors and cut at the points.strip the wires and twist them together.color goes with each other color green goes with green red goes with red.i used hot glue to keep them from falling apart.just have a little come out of the nozzle then stick the wire in the nozzle.rap it in electrical tape and test it out again for bad spots.if you want to you can take a old camera usb cable and strip both ends ad attach it to the xbox controller to make a xtended cable.if you make the extender cable don't worry about the yellow wire just leabe it out///trust me this works for i have did the usb mod to my xbox and cut of the original connector and put a regular usb on the end.i now use the controller to play halo on my comp. if you got any questions please email me at gamecrazy944@yahoo.com
    Jul 13, 2009 | Microsoft Xbox Console
    Usb drivers
    The drivers can be easily found on Motorola's website just type your phone's model in search bar to get assistance. Don't forget to vote me. Thanks
    Mar 26, 2008 | LG RD2030
    Xbox
    dvd rom on the way out m8
    Nov 09, 2007 | Microsoft Xbox 360 Console
    Microsoft Xbox 360 Console Logo
    18 people viewed this question
    Top Microsoft Video Game Consoles & Games Experts
    Martin Murray
    Stu Morris K
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
