Question about HP Pavilion dv6000z Notebook
Hp laptop screen blinks during use
My Hp dv6245 laptop screen blinks. Sometimes it goes completely blank even though the laptop is running. I have to tilt the screen to bring it back to display. This problem occurs more when i'm running on battery. it occurs occasionally when i coonect it to AC supply. what can i do?
  • HP Master
  • 32,281 Answers
You could have a faulty inverter but
You most likely have a defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Apr 13, 2009
How to increase cpu or ram speed on hp dv6245
OPEN RUN TYPE %TEMP% ENTER
DELETE ALL THE FILES IN THIS TEMP FOLDER.
Dec 08, 2012 | HEWLETT-PACKARD Pavilion DV6245 Series...
Toshiba a135 laptop screen goes blank during battery use. Only way to recover is to put the laptop to sleep blinking orange and then restart. This action keeps the screen on. Could this be a bios problem?...
It's probably not a BIOS problem.
You should go to Control Panel --> Hardware and Sound --> Power Options --> Change plan settings --> change advanced plan settings.
Try configuring the setting for "Plugged in" and "On Battery" to be the same. That way your laptop won't go through wierd configurations when you unplug.
Try cleaning your computer with compressed air too.
May 10, 2010 | Toshiba Satellite A135-S2276 Notebook
Compaq Presario CQ45 screen remains blank... help
Open the Notebook from the back side and locate the RAM. Now remove the RAM and place it again and check, you can even try inserting the RAM in different slot if any used slot is available.
Check out.
Feb 12, 2010 | Compaq Presario Notebook
My laptop screen just goes completely blank while still running.i tried to restart but still didnt work.
Have You solved Your problem yet? If no, try this: turn on the laptop and see if hdd blinks orange. If so-cpu is faulty. If not-try to reseat ram memory modules. then remove hdd and see if laptop boots to bios. if so-hdd is faulty. these are most common faults with this model. Regards, Daniel
Oct 17, 2009 | HP Compaq 6735s Notebook
HP L1706- screen is blank when I switch on
First if you have a extra monitor try to plug it in and see if it works. If not then check your video card. or get into the computer and try and remove and reseat the memory. Sometimes by just doing that can solve the problems
Feb 06, 2009 | HP L1706 17" LCD Monitor
Display Problems
your gpu has failed - thats graphics processing unit. new m/board required
Jul 12, 2008 | HP OmniBook XE3 Notebook
HP Pavilion dv6000z Notebook Logo
991 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
