Question about Acer Aspire 5100-3357 Notebook
Unable to reinstall or reformat my acer 5315
Hey, i have an acer 5315 windows vista.ive got a virus on the hard disc and so i tried reinstalling but i dont have the options to do so? i did the alt + F10 but still no options? Does anyone know any tricks or tips,buttons i need to press for reformatting? Even on safe mode it wont load, it just gets stuck and blue screen appears and then freezes.
If anyone could help, it would be much appreciated.
Thankyou very much.
  • amitumi
    amitumi May 11, 2010
    Here is some great source to solve any kinds of laptop's problem.
    » Hp Laptop's Solution » Compaq Laptop's Solution » Acer Laptop's Solution » Dell Laptop's Solution » Toshiba Laptop's Solution » Asus Laptop's Solution
    » Gateway Laptop's Solution » IBM Laptop's Solution
    Here is some another Great source to download any kinds of laptop Drivers.
    » Hp Driver's Download » Compaq Driver's Download » Acer Driver's Download » Dell Driver's Download » Toshiba Driver's Download » Asus Driver's Download » Gateway Driver's Download » IBM Driver's Download def-25
I want to format and reinstall windows on my aspire 5315 ive tried pressing f8 on start up and no screen that says boot from cd comes up what else can i try
Go into your BIOS and select DVD/CD rom as first boot device.
Put your System Disc in the DVD/CD rom drive and restart the laptop.
Mar 25, 2011 | Acer Aspire 5315 Notebook
I have replaced the old sata drive in an acer 5315 and now it will not boot the vista disc from the external disc drive
You have to format your hard drive with special software from acer before you can reinstall the operating system. I had the same exact problem one time.
Mar 14, 2011 | Computers & Internet
Acer aspire wont boot up only goes to blue acer aspire page ive tried f8 and start in safe mode a load of data scrolls for a second then stops and stays like that for ever any help!????????plssssss
you might need to reformat and reinstall the OS for this one... if you want, you can try repairing the OS first using the windows operating system disc and if it doesnt fix it then reformat and reinstall OS...
Nov 08, 2009 | Acer Aspire 1800 Notebook
How to reformat the hard disk of laptop w/o recovery dics?
Reformatting will wipe the drive clean and you will need to reinstall windows, either from the rescue CD or from other media. You may be able to contact Acer and order a replacement CD and install it using the OEM license originally sold with your machine.
If it is merely a problem that programs are not running correctly or that something has corrupted the computer, see if there is a good restore point that you can use from "System Restore." This may allow you to fix the problem and remove the offending program without having to go through the trouble of reformatting and finding the replacement disk.
Finally, since you say that it is Vista, it should be a relatively new machine and it may have a restore partition instead of a rescue disk. If this is the case, there should be a utility in your programs from acer that will allow you to restore the computer to its original form. This will typically reboot the computer and handle the format / reinstall for you. It's possible your friend can't find the disk because he didn't have one.
Just a heads up, typically you can not use a rescue disk from another machine (different make or model) as it will check the hardware configuration before installing the software to make sure it matches the machine the disk shipped with. It is not serial number specific though.
Hope this helps!
May 27, 2009 | Acer Aspire 4520 Notebook PC
Needing to Reinstall Empowering Technology software on my Acer Asire 4720z after reinstalling Windows Vista. The software is still on my hard drive as I didn't reformat the drive, I just don't know w
If its on your hard drive then all you have to do is look for either an icon that says setup or .exe click and your"re good to go
Good Luck =)
May 20, 2009 | Acer Aspire 5315 Notebook
Acer aspire 5315 shuts down
pls check the the power cable and battry states and after thye are working .ok fine next setp
formatted the laptop usenig a win xp cd .............and check it same times vista need high configartion .......ok
Apr 01, 2009 | Acer Aspire 5315 Notebook
Acer Aspire 5315 - Logon process failure.... Failure-Security Opt
hey i believe u got some problems somewhere with ur windows think est thing to do is take it bk if that is not possible to get it replaced for another 1 then simply reinstall windows vista think they are around 86.00 on sale at pc world if u can get that place disc in drive u will need boot laptop from disc by changing settions in bios then click install now u will see a bit where u can format the partition ur windows is already on format that then reinstall ur new windows on that partition mate
Dec 27, 2008 | Acer Aspire 5315 Notebook
Restore factory settings for a acer aspire 5315 laptop
acer dont have a restore, you are prompted when you first boot it up when purchased to make a back up set of discs, i assume you didn't, you will need to lend somebodies XP or Vista Disc , but use your own product code on the underside of your notebook to reformat and reinstall windows.
Aug 21, 2008 | Computers & Internet
Unable to Access Any Operating System
i would try to reinstall xp on the first and largest hard drive and go from there, reformat, and start from the begining. there should be no problem if you do this as long as you have a legit copy of xp and reformat.
May 11, 2008 | ASUS M2N-SLI Deluxe Motherboard
Acer Aspire 5100-3357 Notebook Logo
144 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
