Windows XP 'writemaster' not recognised
The PC is new to me and I have been 'fiddling' so I may have cause the problem. The operating system is Windows XP service pack 3.
The writemaster dvd flashes its little green light on start up and the dvd drawer will open and close BUT the device is not recognised under 'My Computer'.
Looking in 'Device Manager' I have 'DVD/CD-ROM drives' and under that 'MagicISO Virtual DVD-ROM0000' and 'TSSTcorp CD/DVDW SH-S182D'. I gather the first is something my son installed for game playing. They both have a yellow circle beside them with an exclamation mark. I have uninstalled both and the 'DVD/CD-ROM drives' entry disappears. I then shut down the PC and started it again. Plug and play recognises new hardware and re-instates everything as it was and I am back at square one.
Any clues?
There were more problems and I needed a solution fairly quickly. The solution I used was to wipe the hard drive, re-install windows xp and start again. A bit drastic but the problem did not re-occur.
Posted on Apr 13, 2009
Tip
File Searching in XP
Windows XP typically does not allow your system to search for file types that Windows does not recognise.
For most users this really doesn't pose a problem as they will rarely, if ever, need to search for unusual file types. If you are a software developer, however, you may find that your code routinely uses files that have an extension that Windows simply doesn't recognise.
This is easily rectified by adjusting the following registry key, using regedit set:
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\ContentIndex\FilterFilesWithUnknownExtensions] = 1
Note: Using the registry improperly can impare the use of your PC, so it is advisable to make an export of your registry before making any changes.
on Nov 18, 2008 | Microsoft Windows XP Professional
The emachine model KAWE0 is with operating system windows xp sp1 doesnot recognise any usb device.
Good day sir, hi, usually its one or two ports that does not recorgnise a usb device, but if all ports does not recognise the usb device, check the CMOS setup. check this out;
  • one or two ports does not recognise the usb device, this is a local fault, try to check the CMOS setup, this could also be the port itself is the faulty one having loose connection.
  • all ports does not recognise the usb device, this is a system fault, check again the CMOS setup if the USB port is enabled, check the USB device itself also. to make sure use another pc to test the usb device.
A computer virus can also cause the usb port to malfunction, run an anti virus software, if possible you can reinstall the XP and test the USB port afterward.
If all else fails, you can buy a USB card and plug it on the expansion slot on your PC.
Nov 04, 2009 | E-Machines eMachines Desktop PC
I want to load Xp in a PC preloaded with Vista. I dont have the disks for vista- only the recovery disks are available. I am not an expert and cant fiddle with the boot thing Pl Help
If the PC was "designed for Vista", there will *NOT* be device-drivers for many components, i.e., no audio-drivers, no network-drivers, no video-drivers. In short, XP will *NOT* be a _good_ experience for you.
Stick with Vista, or upgrade to Windows 7.
Oct 27, 2009 | Microsoft Windows XP Professional With...
WHEN I TRY TO START UP WINDOWS XP PROF IT SEEMS AS THOUGH IT HAS GONE BACK TO AN EARLIER DATE AS IT ISNT RECOGNISING MY KEYBOARD ,THEREFORE I CAN T LOG ON
your files is safe and put up a backup files and
your pc in new window xp profit programmis in
instiolation and working pc ok
Sep 12, 2009 | Microsoft Windows XP Professional
Not recognising in computers
download and install the firmware for your mp3 player on your windows xp operating system and then it should work fine heres the link to get the firmware
Jun 02, 2009 | Sony NWZB133F MP3 Player
You need to have Windows Media Player 11 instaled or else it won't recognise it.
Mar 25, 2009 | Sony NWZB133F MP3 Player
Scond slot memory not recognised by my pc.
i thing second slort memory is not properley insert in the motherboard
Mar 04, 2009 | Microsoft Windows XP Professional With...
2 hd
Leave the other drive in; no the other windows will not cause problems cos its not set as boot 'C' drive, you can deletewindoes off the drive or format it within windows.
I don't think that the drivers you installed are the cause of the boot problem it may be the other drive, remove old drive and try again, but make sure in the bios (F2 or Del on boot up) it is correctly recognising the new drive.
delete this path:
multi(0)disk(0)rdisk(1)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Aug 29, 2008 | Microsoft Windows XP Professional With...
Computers & Internet Logo
205 people viewed this question
David Payne
David Payne
