Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Cannot get my tv out of 480
How do I get My xbox 360 to display in 1080 on my tv, i have hi def cables
  • molleson Sep 10, 2007
    the problem is i can't get the tv settings to change, i got the xbox to
    President:
  • 2,961 Answers
You have to go into the xbox 360 settings and change the output screen resolution to 1080i and also check your tv settings input to receive 1080i also.
Posted on Sep 10, 2007
6ya staff
SOURCE:
How to I change tv to 1080i from 480i?
this should automatically be done by the tv. If you input to a standard def input (ie yellow plug) or are using standard def cable it will be 480. If u change to a HD input or an HD channel it should automatically switch to 1080. The input displayed on the tv that says 480i or 1080i is just a result of what is being played, not a setting to be changed.
May 11, 2010 | Vizio VX37L Television
When i turned my tv on to play my xbox 360 with component cables, my tv says ''not supported''?
Some after arket component cables only support high def, if your tv is standard def it won't work. I'm not sure if this is your problem, but it's worth looking into.
Mar 03, 2010 | Microsoft Xbox 360 Pro System Console
Tv will not pick up 720 and hold, reverts back to 480, why?
480/720/1080 is a function of the XBOX not the TV. The TV cannot change the resolution. The resolution indication that shows on the TV is only what it is recieving, not what it is showing, You need to check the XBox or whatever you are using.
The Green Line on the other hand is a defect and if the TV is in warranty you should make them fix it!!! That is unless this green line only appears with a single source....it should show ALL the time.
Jan 06, 2009 | JVC LT-42E488 Television
Change from 480 pixles to 1080 how do you do it ????
Do you have the HDMI out in your Xbox??
The input is auto switching for the resolution.
Oct 09, 2008 | Hitachi P50H401 50 in. Plasma HDTV
Screen resolution
From the Console Settings screen in the System area of the Xbox Dashboard, you can configure the video output of your Xbox 360 console.
Change your display output settings from this screen. Display settings include screen resolution and screen dimension (or aspect ratio, either standard or widescreen).
In some cases you can select an "Optimal Resolution" button, which appears only when Xbox supports the native resolution of the TV or monitor and automatically applies the best setting but that might not work with your tv.
If you are using VGA you must choose from among the following output resolutions: 640 x 480, 848 x 480, 1204 x 720, 1280 x 720, 1280 x 768, 1280 x 1024, 1360 x 768, and 1920 x 1080.  Much like a PC you would want to select a lower resolution (640X480).  That will make your fonts larger.
Screen Format: The default setting is Normal (a standard 4:3 aspect ratio); select Widescreen to change the output aspect ratio to 16:9 if you have a widescreen TV or monitor.  You should select normal and not widescreen for a standard tv.
Hope this helps,
Bob
Dec 26, 2007 | Microsoft Xbox 360 Console
Can't get my TV to go to 1080i
Your tv is either 1080p or not 1080 compliant. Try 720p or you may be forced to keep it at 480
Dec 25, 2007 | Mitsubishi WS-55315 55" Rear Projection...
Toshiba mo# 20AF44/xbox360 ISSUE
Just because a TV has RGB component inputs does not mean
HI-Def will work......Component range = 480 to 720 to 1080....
You can download owners manual off web..Toshiba.com..
click on HDTV then click customer support....owners manual.
............................................................................T.
Dec 25, 2007 | Toshiba 20AF44 20" TV
TV projects a pink/green shadow
Logically proceed one source at a time = disconnect all,
then hook-up one at a time or hook-up seperately.FYI, the
RF coax , composite and s-video inputs all share the same
circuitry, whereas component is a whole seperate video
processing circuit, with another difference between 480P and
1080 I . Sounds like you have a 1080 I problem, which might
be a little sister board..............................T.
Let me know..............Thanks.
Oct 07, 2007 | Akai PT5598HD 55" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
137 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
