Question about Sony PS-LX250H Turntable
Turntable won't turn when turn it on, but after about 10 minutes it starts to turn. It is a BSR 25CX Mcdonald
  • 33 Answers
Hi, try to check the switch maybe or change it if possible..
Posted on Jul 09, 2009
2 Suggested Answers
Grubhead
  • 5158 Answers
SOURCE: 1960s stereogram.bsr turntable turning to do fast.
If I can understand you right, the turntable is running fast. I don't think you need a new motor, generally the deck will run slow if the motor is knackered (or not at all). What you need to do is remove the platter, you will find a horseshoe bracket holding it on at the spindle (it may be covered up so you wil have to remove the cover part often a silver disc). The most likely cause will be the rubber idler tyre being worn damaged etc or out of place. There could be grease dirt or something else causing the problem.
Posted on Mar 26, 2010
Testimonial: "excellent thanks"
Hey there, After a power outage the motor that drives the platter "BSR turntable" does not function. Is there a fuse or some other likely suspect?
If the motor is directly connected to a mains supply then the chances are that when power was restored it burnt out or damaged the motor itself. Following the mains lead into the unit should answer where the power goes. If it goes to a transformer and it's associated power supply the problem will be found there.
Nov 07, 2016 | Audio Players & Recorders
When I push start button turntable doesn't rotate
Technics SL-QD33 doesn't turn - Vinyl Engine
www.vinylengine.com/turntable_forum/viewtopic.php?t=28381
Jun 3, 2010 - 15 posts - ‎3 authors
It powers up, lights come on but the platter won't spin. ... However when I press "start", nothing happens and the platter won't spin when ... the arm towards the record without pressing the "start" button. ... SL 7, SL-10... and / or any of the fully automatic Technics turntables using optical record detection......etc Marantz 6300 question...
Nov 21, 2009
Dual CS505 turntable won't auto-start
Aug 16, 2009
More results from www.vinylengine.com
Help!! My Turntable won't spin - AVS Forum ' Home Theater ...
www.avsforum.com/.../1316271-help-my-turntable-won-t-spin.html
18 posts - ‎7 authors
Dec 21, 2015 | Audio Players & Recorders
I need a service manual for the BSR McDonald CA 50 turntable
BSR tended to make old style turntables, ones with a 78rpm speed on. I don't the model in question, but if it is a one of these, there's not much to them. Basically a rubber tyre runs inside the rim of the platter, while the tyre is pushed on a mains powered motor, in at least 3 different positions (depending on the speed). The tyre moves up and down depending which speed is selected.
Speed faults are caused by either a bad motor, or muck, oil, or grease in it.
A faulty tyre that is worn and doesn't push on the motor or platter anymore or not hard enough. Plus of course tyre height setting wrong.
Nov 08, 2015 | Audio Players & Recorders
My bsr McDonald 6500 turn table was completely seized then I applied some wd40. I also removed the spindle and c clip. It moves now if I use some force not a smooth spin at all and I still can't get it off...
Im wondering if you can look underneath there may be cat hair or string wrapped around the shaft, that would prevent it from turning smoothly.
When you take the bottom off, I suggest you take a picture of it.. that way you will know how it goes back together easier.
Jul 11, 2014 | Audio Players & Recorders
Bsr McDonald 25cx turntable sounds terrible when I try to play a record.
Hard to say, but could be either a faulty cartridge or the wires connected are wrong or off.
Oct 20, 2013 | Audio Players & Recorders
Bsr mcdonald
REPLACE THE NEEDLE.
I have an old Sony Stereo Music System HP - 169 with a BSR Precision Crafted in Gt. Britain turntable ... everything works except the turntable won't do a thing. Table won't go around on its own .... when...
SEYLEVITT@JUNO.COM.
THERE IS A 3/4 CLIP THAT HOLDS THE TURNTABLE, SO IT DOES NOT COME OFF OF THE CHANGER. THAT CAN BE FROZEN TO THE LOWER SECTION.
(1) CAN YOU SPIN THE TURNTABLE WITH YOUR FINGER? (YES) (NO)
(2) DO YOU HAVE TO FORCE IT TO MAKE A 360 DEGREE REVOLUTION????? (YES) (N0)
(3) IF IT TURNS FREELY, AND YOU PUT THE
LEAVER IN ==MANUAL== 33 1/3 DOES THE TURNTABLE SPIN, BUT WILL NOT PLAY RECORD AT THE 33 1/3 SPEED., IT TURNS SLOW.
(4) REPLY TO SEYLEVITT@JU8NO.COM
I HAVE NOT KEPT THE E-MAIL THAT YOU ARE READING. ANSWER WITH MY QUESTION, BY THE NUMBERS.
SEYLEVITT@JUNO.COM
SEYMOUR LEVITT
Jun 25, 2009 | Audio Players & Recorders
Turntable does not rotate when switched 'on'.
K, I'm not familiar with that particular stereo unit but there were a lot of stereos from years gone past that used a turntable made by BSR. When you activate the switch to start the turntable listen closely to the record platter for a hum or possibly the sound of a motor turning (they're quite quiet). Is the switch lever you pull rectangular made of black plastic, you pull it towards you one click to start the record and pull it one step further (spring loaded) to make the tone arm lift from the record automatically? Just want to make sure I'm talking about the right turntable before we continue.
Oct 10, 2008 | Audio Players & Recorders
Sony PS-LX250H Turntable Logo
351 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
