The premium replacement part for this is about $22.00. I would expect labor to be around 3 hours estimated in their magic book of hours. You can expect this to cost somewhere around 300.00 to 350.00. If you are handy at all and have tools you can do this for a few swear words and about 3 to 4 hours for about 100.00. I say 100.00 because there will be minor things that come up besides the part itself.
I replaced the left front bearings and seals a couple of months back. It is not a problem but be careful as you dismantle the system and of course the reassembly of same. Be sure to replace all bearings and seals as you probably don't want to do this job twice at the cost of parts. No special tricks and relatively easy job.
What are going to do to repair the axle? There really is no axle on front drive cars, the wheel assembly is connected to a hub that is mounted to the frame through swing arms. And, you would not take your car to a autobody shop for mechanical work. The cost of repairs depends on what is being done.
Usually once the boot is torn, dirt goes in, and all of the lubricant goes out. If you have been driving it this way, it will damage things faster. Normally you hear a "click" when turning out of a bad cv joint.It is a safer solution to just replace both, but of coarse, not cheaper.
Neal, it may not be the right front axle. I thought I had the same problem with 97 4Runner but it turned out to be the right rear axle bearing. Even the technican thought the niose was coming from the right front axle when he test drove it with me. Seems those rear bearings go out if you do a lot of towing with the truck. Cost about $ 400.00 to replace make sure they replace the ABS sensor collar and replace the axle breather tube vent ( they get plugged and when they replace the bearing , they have to replace the seal in the axle also and mine leaked after because of a plugged axle vent.
