Question about Acer Aspire 5720 Notebook
Resolution resets after reboot
I have an Acer Aspire 5720 with an Intel 965 GMA which I have just switched from Vista to XP SP3.
The only thing that isn't working is that when I boot the computer the resolution starts at 640X480, then if i try to change it through windows display settings nothing happens, and only through the intel GMA icon in the tray can i alter the resolution, but after reboot it reverts back to the lowest setting.
I have tried the drivers from the acer and intel sites, installing both in and out of safe mode, tried a registry alteration to remember settings from "kelly's korner" which is listed as a solution in many other sites.
I cannot figure out what is wrong, nor can most of the internet it seems, I would greatly appreciate some help.
Έ χ ω ASPIRE 5720 η μ ?????? ο υ σ τ & # 945 ? μ ά τ η σ ε...
looks like you don't know why your here... me too.. my job is to find and seek your mind out... post the info here... with real info..
Jul 02, 2010 | Acer Aspire 5720 6497 Laptop
How can I change the resolution from 1280 x 800? This is the highest possible according to the display setttings. I have removed the generic pNp monitor. I am running Vista Business. The display adapter is...
Graphics Unable to use the native resolution, such as 1920x1080, 1680x1050 and 1440x900 circuit388.gif Symptom(s):
On some displays, users may be unable to use the native resolution when using Intel® chipset graphics. Resolutions such as 1920x1080, 1680x1050, and 1440x900 are not available in graphics properties.
Cause:
The display's EDID is not read properly when connected to some digital flat panel displays. Display devices describe its capabilities by sending EDID (Extended Display Information Data) to the computer.
Solution:
Intel has released a graphics driver to specifically address this issue; however, there may be side effects to this solution such as longer than normal resume times from standby. This solution will only work with external displays such as DFP displays connected to the computer's VGA port. This driver is not designed to address issues with a notebook's built-in display (Local Flat Panel) or with TV’s connected to the system. This driver is provided as is. Intel has not tested, and does not guarantee, the operation of the driver for this purpose.
For the desktop and Mobile Intel® 945 Express Chipset Families:
If you have a computer that has the Intel® 945G or 945GV Express Chipset or the Mobile Intel® 940GML, 943MGL, 945GM, or 945GMS Express Chipset, click here for drivers that resolve this issue.
For the Intel® 3 Series Express Chipset Families and the Mobile Intel® 965 Express Chipset Family:
If you have a computer that has the Intel® G31, G33, G35, Q33, Q35 Express Chipset or the Mobile Intel® 965 Express Chipset, click here for drivers that resolve this issue.
For the Intel® 4 Series Express Chipset Families:
If you have a computer that has the Intel® G41, G43, or G45 Express Chipset or the Mobile Intel® GL40, GM45, or GS45 Express Chipset, click here for drivers that resolve this issue.
For the desktop Intel® 946 and 965 Express Chipset Families:
If you have a computer that has the Intel® 946GZ, G965, Q963, or Q965 Express Chipset, click here for drivers that resolve this issue.
How to identify your Intel® graphics controller
How to install the graphics driver
I cannot select a larger display mode (resolution, refresh rate, or color settings). How do I resolve this issue?
Error: "The driver being installed is not validated for this computer..."
Operating System:
Windows XP Professional x64 Edition*, Windows Vista 64*, Windows Vista*, Windows Vista 32*, Windows 7*, Windows 7, 32-bit*, Windows 7, 64-bit*, Windows 7 Enterprise, 32-bit version*, Windows 7 Enterprise, 64-bit version*, Windows 7 Home Basic, 32-bit version*, Windows 7 Home Basic, 64-bit version*, Windows 7 Home Premium, 32-bit version*, Windows 7 Home Premium, 64-bit version*, Windows 7 Professional, 32-bit version*, Windows 7 Professional, 64-bit version*, Windows 7 Ultimate, 32-bit version*, Windows 7 Ultimate, 64-bit version*, Windows XP Professional*, Windows XP Home Edition*, Windows XP Tablet PC Edition*, Windows XP Media Center Edition*
This applies to: Intel® 3 Series Chipsets
Intel® 4 Series Chipset
Intel® 82945G Express Chipset
Intel® 82946GZ Graphics Controller
Intel® 82G965 Graphics and Memory Controller Hub (GMCH)
Intel® 82Q963 Graphics and Memory Controller Hub (GMCH)
Intel® 82Q965 Graphics and Memory Controller Hub (GMCH)
Intel® 945 Express Chipset Family
Intel® 946 Express Chipset Family
Intel® G31 Express Chipset
Intel® G33 Express Chipset
Intel® G35 Express Chipset
Intel® G41 Express Chipset
Intel® G43 Express Chipset
Intel® G45 Express Chipset
Intel® Q33 Express Chipset
Intel® Q35 Express Chipset
Intel® Q43 Express Chipset
Intel® Q45 Express Chipset
Mobile Intel® 4 Series Express Chipset Family
Mobile Intel® 945 Express Chipset Family
Mobile Intel® 945GM Express Chipset Family
Dec 06, 2009 | Acer TravelMate 5730-6204 Notebook
Display of acer aspire 7720 Z 17 inch display
Please resetting your LCD resolution ratio to 1024*768.
Jul 06, 2009 | Acer Computers & Internet
Laptop stuck at 800x600
Odd problem. To solve, best bet is too reboot computer, press F2 to enter system settings. Go to visual performance and set a terminal networked computer default. May reset all other setting as well though.
Jul 06, 2009 | Dell LATITUDE XFR D630 Intel Core 2 Duo...
The RAM module/s may be faulty or needs reseating because the video card grabs some of the system RAM. If you got two RAM modules then swap them around in the DIMM slots.
Try deleting/disable the video driver or change it to standard VGA.
If you can uninstall the video driver then OK.
Reboot the laptop and reinstall the video driver and it usually requires a reboot for the driver to take effect.
Also try connecting an external monitor to the laptop's external video port, power up the monitor first then the laptop. The video should automatically divert to the external monitor. Then try and change the screen resolution. If this doesn't work then there is a possibility the Video card might be faulty.
As a last resort reinstall Windows it may fix your problem.
I've run out of further ideas, good luck.
Apr 12, 2009 | Dell Latitude D620 Notebook
Purchase a laptop
Acer AS2930Z-343G32Mn
Intel Pentium Dual Core T3400 Processor,
Intel GL40 Express Chipset,
3GB DDR2 Memory,
320GB Hard Drive,
Intel GMA 4500M Graphics, 12.1" Acer "CrystalBrite" LCD,
Super Multi DVD Dual Layer Drive,
2.1kgs.,
Windows Vista Home Basic,
Modem,
Gigabit LAN,
Wi-Fi,
Bluetooth,
Card Reader,
Acer Crystal Eye Webcam
Mar 21, 2009 | Acer Aspire 5720 6497 Laptop
Video Card Problems
You need to run the recovery and allow Windows Vista to rule the roost. If you do not want to do that then you need to get a different hard drive,(preferrably a new one) And load XP on to it. Your laptop is designed to run Vista and the drive is coded to do so. After so many updates on XP it will pick up on your recovery partition because of SP3 update. No way around it unless you switch drives. I don't think you have permissions to delete the partition with Recovery on it. Get a different hard drive.
Jun 16, 2008 | Acer Aspire 5315 Notebook
How to downgrade acer aspire 5720 vista to xp
I just got my 5720-4126 so once I had to test the Factory re-install (ALT-F10 at the ACER screen) and knew I could get back to where I started (Vista), tried to install XP from CD. It couldn't even see the disk drive :-(
Jan 20, 2008 | Acer Aspire 5500 5570-2609 Laptop
ACER Aspire 5720
Hi All,
We are a workshop in Spain & I have had several problems with "Down grading" to XP. There is essentially one problem which causes an issue with the XP installation & that is if the the BIOS has a "Fixed" sata configuration. By that I mean you cannot change it to some sort of IDE or P-ATA (Symantics). Our current problems are with an Acer 5720 & an HP Pavilion DV9700. The Acer solution is exactly as "kraken3000" had mentioned before:
1. On POST (Powerup). enter BIOS by pressing F2
2. Tab along to the second option "Main"
3. Goto last option "SATA mode" & press enter.
4. From the small selection display select "IDE mode"
5. Save & exit the BIOS. This will then set the SATA mode for XP to be recognise.
DONOT set this back to SATA Mode after you install the XP as it will NOT boot. This setting must be kept untill you "Upgrade" (If ever) to Vista. The HP is another story...
Visit the Acer Panam site & download & install the XP drivers & your good to go...
I hope that this was of help...& good luck folks
Nov 23, 2007 | Computers & Internet
Acer Aspire 5720 Notebook Logo
110 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
