Question about Garden
WAP 7400 PROFi. Foot operated on/of switch will
WAP 7400 PROFi. Foot operated on/of switch will not stay in on position without leaving foot on rubber foot switch. Can I get a new on off switch and how much and from whom?
  • Anonymous Mar 24, 2014
    require copy of operating / instruction manual for WAP 7400 Profi high pressure cleaner
  • 195 Answers
Are you sur this is not safty feature, just a suggestion..so dont hate me...can not find a swith on internet
Please rate
Posted on Apr 14, 2009
When trying to use the zipper foot the needle will not stay positioned to the side and keeps returning to center hitting the center of the zipper foot and machine stops
set the machine to straight stitching which should keep the needle in the center position
a zipper foot is a normal foot with 1/2 missing
It it still wanders , take it in for a service
Dec 31, 2015 | Sewing Machines
The pto won't stay running with switch in run position
Are you still sitting on the seat?do you have the footbrake on?mowers will not run without someone sitting on them or if the foot rake is off whilst starting.
Jun 07, 2015 | Garden
Needle won't stay in left position when using zip foot - bernina 1530
Is it possible you're using a later foot with the sensor lenses on it ... your machine has the optical sensor for the automatic buttonhole foot and I'm wondering if you're getting it confused by using a foot that is not designed to go with that machine ?
Nov 04, 2011 | Bernina 1008
Husqvarna rose tried to run it and the pressure foot light comes flashing on and will not run. yes the presser foot is in the down position
There is a safety switch underneath the presser foot lever, its tucked away in the body cavity and its tough to see. The switch is operated by a metal spring that turns the switch off and on according to the presser foot lifter position. the spring, which kinda looks like a fork, gets compressed each time you lift the presser foot. It wears and works intermitantly. A dealer is the only solution, the back needs to come of, and its a dang tough job to replace without damaging the replacement spring.
The other thing it could be is a jammed check spring inside the tension assembly, again its a tough job as the auto tension assembly must be removed, along with the winder and loosening of the main board.
derek
Jan 15, 2011 | Husqvarna Rose
I parked my jimmy last night went to drive it today and it will not leave from the park possition. any ideas? matt
check and see if you have brake lights if not check the fuses for the brake lites .if ok go to the bulbs .whats is happening is that the shift release mechanism is not releasing .you may be able to override the mechanism by turning the key to the first position and try to move the shifter.
Jan 10, 2011 | GMC Jimmy Cars & Trucks
The sewing machine works when switched on, the foot pedalhas no c
there is a clutch operated by foot pedal. if the clutch is continuously engaged then it will run own its own. so adjust clutch lever.
Nov 23, 2009 | Janome Sewing Machines
Viking Designer 1 presser foot will not stay down
The foot should come up slightly above the fabric when in embroidery mode. If not, the fabric could not move.
The foot should come up the same distance that it would if you were to put the foot in the pivot position while sewing. If it is coming up more than that, then you have a problem and will need to see and authorized technician.
Apr 19, 2009 | Husqvarna Designer I
My Viking 5710 starts to sew without any pressure on foot pedal
Mine does the exact same thing. I think the problem might lie in the cord to the foot pedal. The cord packs into the foot pedal for storage, which forces the cord to to remain bent during storage. I believe the wires in mind became damaged and broken so I took it apart and reconnected the wires at the spot where the connector meets with the wires. But I still don't leave it plugged in if I'm not using it, it could be a fire hazard.
Mar 14, 2009 | Husqvarna Viking 1
Garden Logo
970 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
