Question about Vehicle Parts & Accessories
I want to remove my remote starter
I have a 95 nissa maxima and i believe my remote starter is draining my battery besides i never really need it because my security system was disabeled how do i remove the remote start kit
  • 22 Answers
Under the dash you will find the security system its a black box the size of a cigarette pak remove the red fuse and this will ensure the product can no longer drain power.The car should still start if not replace fuse and then contact me and i willl give you the rewiring tip.
Posted on Apr 23, 2009
  • Neville Hayes Apr 23, 2009
Will a starter from a 95 maxima fit into a 1993 maxima
The starter for cars with automatic transmissions are different between a 93 and a 95.
Jul 21, 2013 | Cars & Trucks
My 95 maxima was just cuttn out on me and would go dead but usually move battery cables a little and it would crank, however we changed cable ends on battery, crank it and dtove doen the road, it went dead...
Battery went dead? If this is the case you probably have a dead short.Should pull starter possibly bad solinoid, My old Maxima had caused me similar issue, if you pull starter it usually can be tested at a local Auto parts store. In a vehicle that fails to start, the common problems are the starter solenoid and the starter motor. The starter assembly can be quickly pulled from a 1995 Nissan Maxima, and then can be further separated to replace one part of the starter assembly.The process does not require any special tools, and can be done by novice mechanics
Dec 28, 2011 | 1995 Nissan Maxima
My cars Battery is 95%fuly charged charged but starter wont turn over where is the fault .starter or altenator
Not the alternator. If the battery has a sufficient charge, the start should turn regardless of the condition of the alternator. Try using a battery charger to be sure battery if at 100%.
Are your battery terminals clean, no corrosion and attached tight?
If starter still will not turn, problem could be wiring or bad starter solenoid.
Feb 06, 2011 | 1995 Nissan Maxima
MY 2004 taillights keep blowing the fuse. What could the problem be and how much?
same here replaced the control box beside the windshield fluid and then all the bulbs and then the dimmer sw for the dash and now it stays on for a couple of days but still blows think it might be the remote starter or the installation of the remote starter..
Jan 05, 2011 | 2004 Nissan Maxima
The starter isnt working
The Starter is on the right (Top Side) of the motor. The only thing you will have to remove is the breather attachments (air filter,maf sensor,etc.)
May 11, 2010 | 1995 Nissan Maxima
Need to replace starter
To find the starter, you follow the big cable the red/positive battery terminal. They are usually held in by 2 bolts and there is an electrical connection you need to unplug.
On a 94 maxima they were underneath and easy to access - but they redesigned the engine in 95. On my 2002 it was accessed from the top - had to remove the air filer box and some hoses but it was just about 6 screws and a hose clamp or two.
Dec 09, 2009 | 1995 Nissan Maxima
New battery / alternator something pulling power from battery
loseing current <<<<--- As in Battery Draining Over night? Please Help Me Help You, I need More Details, Thank You
Feb 12, 2009 | 1996 Nissan Maxima
Engine will not start
That Clicking Sound is Coming from the Starter. First check the Starter Relay. It should be in a Fuse Relay Box under the Hood. If this is good, The Problem will be the Starter and will need to be Replaced. Also Check the Tension on the Belt. If the Belt is even a little loose it will not allow the Alternator to Charge the Battery and will cause a Not Start. Let me know what you find out. Please Rate my Response, I need all the Help I can get! Thanks!
Jan 26, 2009 | 2007 Nissan Maxima 3.5 Sl Sedan
95 Nissan Maxima won't turn over
sounds like a starter motor problem, i would change that first
Dec 01, 2008 | 1995 Nissan Maxima
Vehicle Parts & Accessories Logo
422 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
