Question about Flat Panel Televisions
Samsung hd tv - blacked out screen (sound no picture)
A few hours ago i was watching tv when the picture went and only the sound remained. I switched everything off and back on and i get a picture for an average of about 4 seconds before it blacks out again. I have tried the old wiggling of the cables and leaving it off for a while and nothing has worked. It is deffinately the tv as sky, dvd and terrestrial are all not working on it, but are fine on a little tv we used to test. This tv is barely a year old and i have not experienced a problem with it before. Any ideas as i am finding nothing on advice websites and forums?
  • 138 Answers
SOURCE: screen turns black after a few seconds
Check the software and if is is not BX23U- upgrade it by downloading the software from onto a USB stick. If that don't fix the issue change the small signalbaord.
Posted on Aug 19, 2008
  • 14 Answers
SOURCE: Philips 30PF9946
1 step can confirm if you can fix this. Press menu. If you can get a menu its fixable if you cant its in need of major repair.
Posted on Sep 15, 2008
  • 59 Answers
SOURCE: Toshiba 50HP66 and HDMI problem
hi the best thing to do is call toshiba and let them know your problem
Posted on Jan 10, 2009
  • 27 Answers
SOURCE: Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Posted on Apr 04, 2009
  • 47 Answers
SOURCE: Samsung 650 lcd 40" tv picture blacks out for a few seconds.
Dude, better check your cable and also your TV's power management settings. This might also happen due a issue with the HDMI output of the satellite box.
Posted on Jan 07, 2010
  • 1684 Answers
SOURCE: My Samsung LN-S2651D has sound but no picture
Check with Samsung, this model should still be under the 3 year warranty. You are having a problem with the backlight power supply. You can look on the back of the unit for the manuf. date, if its less than 3 years then go to and process the online service request form.
I hope this helps,if so please rate our solution.
Corporate Computer
Posted on May 20, 2010
Testimonial: "Your suggestion sounds about right to me, though I'm no expert. I do have experience with bad caps in other equipment and am comfortable around circuit boards and soldering, etc., so I'll have a go at it. Might these be low-esr caps? Once again, thank you."
0 characters
1 Points
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
Jan 21, 2016 | Samsung LN52A580 52 in. HD-Ready LCD TV
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
Samsung 50" led un50h6350. The TV is about 18 months old and the picture went out, the audio and back light are working. I've replaced the t-con board and that didn't fix it. Someone please help!
Samsung LED TV Screed goes blank periodically for 1 sec - Forums ... > Forums > Samsung
CNETJun 11, 2015 - Lately, my Samsung LED TV's screen will black out from 1 -2 seconds then come back. The TV has been ... The TV is about 6 months old. .... I've only notice this when I'm watching in HD. ... by Stlouib / January 13, 2012 11:18 PM PST ...Mine does the same thing - picture goes black for 1 - 2 seconds and then comes back. Samsung Series 3 (330), won't show any picture/no sound?
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
More results from
Are there still capacitor problems with Samsung TVs?
Dec 21, 2015 | Samsung Flat Panel Televisions
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
Dec 20, 2015 | LG Flat Panel Televisions
How to adjust picture setting on 23 inch samsung tv cant get to advanced settings .have direct tv no hd but the picture is not very clear at all.thanx
Samsung LCD P2370HD 230?N when I turn on the channel is switched on after a few seconds the LCD screen is black and none of the menus do not work and the state remains a solution to this problem is?
Aug 08, 2010 | Samsung P2370HD 23 in. TV
Sound but no picture
hi sir
as it is not giving the perfect picture so it might have gone wrong in the screen pixels better to check the lcd screen and me sure the pixels went wrong it can be also coz of the water vapours please keep the tv away from water or windows etc.there might be a circuit problem which may not be working .
thank you
Jun 29, 2009 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Lg 42inch plasma
Sounds like main board failure and or power board failure. You need to contact manufacturer and describe problem for tech support. Some of the parts in Samsung TVs have lifetime warranties. Change out of two board is about an hour job and service call is usually comped. Hope this helps. J
Apr 09, 2009 | Samsung HPT5054 50 in. HD-Ready Plasma...
Samsung LCD TV, no picture only sound
is the picture clear when on? if yes, does the screen go black after a few seconds. if yes, sounds like you need a back light inverter!
Sep 13, 2008 | Westinghouse LTV-30W2 Television
Samsung HDTV Oval rainbow of colors covering entire screen
Oct 04, 2007 | ViewSonic N2750w 27 in. HD-Ready LCD...
Flat Panel Televisions Logo
250 people viewed this question
Top Flat Panel Televisions Experts
Are you a Flat Panel Television Expert? Answer questions, earn points and help others
