Cyberhome DVD-1600 In the settings menu I went into the A/V setup. The scanmode was switched to Progressive; however, nothing showed and after the 10 seconds it did not revert to interlace. Now I'm ge
Cyberhome DVD-1600 In the settings menu I went into the A/V setup. The scanmode was switched to Progressive; however, nothing showed and after the 10 seconds it did not revert to interlace. Now I'm getting audio but no video. How can I reset the DVD to factory default settings?
Cyberhome DVD-1600
To set the factory default settings just do the following:
  1. Get the DVD-1600 manual
  2. Open to the page which shows you how to set the player to factory default settings
  3. Switch on the TV and click to the channel that you will watch your DVDs
  4. Switch on the DVD player and make sure there is no disc in it - this ensures the DVD is not already in a menu or any other thing
  5. Follow the instructions in the manual to the 'T' although you will be unable to see anything
  6. If you follow the instructions correctly you should get back to 'interlaced mode'. By this time you will be able to see the DVD output on the screen.
Posted on Apr 13, 2009
PROGRESSIVE LIGHT WAS SET BY MISTAKE, AND IT HAS BEEN SET ON AUTO HOW CAN I SOLVE THIS PROBLEM BECAUSE THERE'S ONLY A BLACK SCREEN AND SOUNDS THAT COMES ON.
According to the operating instructions (page 97), Progressive Scan can be cancelled (or turned off) by pressing and holding PAUSE (on the main unit) continuously for 5 - 10 seconds, until the progressive indicator goes out, or turning it off in the setup menu. Your recorder should now be back to normal interlace video output. I recommend that you check your setup menu after this procedure to make sure nothing 'AUTO' is set, that shouldn't be set, and subsequently turning off any function that isn't required.
Apr 30, 2011 | Sony RDR-VX515 DVD Recorder/VCR
Turned progressive scan on, can i turn it off without being able
Try these methods for resetting the scan on your dvd."To reset the VIDEO OUTPUT, turn Off the player, turn back On, open the disc tray and press and hold the Stop button on the player for 10 seconds to reset the scan mode." The Reset procedure doesn't seem to work on all versions but you can sometimes get a usable B&W picture allowing you to get to the menu and change the settings by connecting the composite video input of your display to the Red Pr/Cr or Green Y component output jacks on the rear of the cabinet.
You can also go into the Menu and set it blind with the following key presses on the Remote:
1. With the unit Stopped, press Setup.
2. Press Enter.
3. Press the Down Arrow 3 times.
4. Press the Right Arrow Once.
5. Press Enter. Hope this helps you with your problem
Apr 14, 2009 | Cyberhome CH-DVD 300 DVD Player
Lost picture when set dvd player to progressive scan.
Hello Fearlessloki, Welcome to Fixya.
Would you mind posting some of the details on this DVD player that is having issues?
Jan 05, 2009 | Cyberhome CH-DVD 300 DVD Player
Cyberhome 1600 dvd recorder
i need an operating manual . Where can i get one pls help me
Sep 16, 2008 | Cyberhome DVR 1600 DVD Recorder
Dvd player
if dvd remote has a p. scan button, you can turn it off. otherwise you will have to go into menu
May 26, 2008 | Cyberhome CH-DVD 300 DVD Player
No Disc
I have the same model ... you can't use DVD-R or DVD-RW discs, only DVD+R or DVD+RW
Apr 26, 2008 | Cyberhome DVD Recorder - DVR1600
How to reset dvd recorder to ntsc from pal
After checking today to see no one offered any suggestions - I solved the problem the hard way - I went into settings and although the screen rolled, I was finally able to click onto the ntsc setting after about a half hour of tries and once I clicked it, my screen returned to normal -- i was then able to enter the code that made the player an all region player and was happily able to play a pal dvd I received recently. The procedure was simple -- offered by a European Cyberhome user -- the company is in bankruptcy so you cannot gt help from them. Note - my Cyberhome dvr is 1500- not 1600 as you listed it.
Feb 11, 2008 | Cyberhome DVD Recorder - DVR1600
Download manuals
Trying to find a manuel to download for my DVD Recorder Magnvox MSR 90d6
Nov 25, 2007 | Denon 3910 Progressive Scan DVD Player
Can't set the clock
try the setup menu on the remote control.
Nov 19, 2007 | Cyberhome DVR 1600 DVD Recorder
No video
If you select Progressive Scan and your television doesn?t support it, you may end up with a blank screen and be unable to view the menu in order to fix it. If that happens, fix it by turning the DVD player off then back on. Open the disc tray, then press and hold the STOP button for five seconds.
Jul 24, 2007 | Cyberhome CH-DVD 300 DVD Player
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
Electro Med Services...
