Question about Stoves Kitchen Ranges
Model "au40d"? Atlanta stove just started smelling really strong (rich) while operating. Possibly 1994 model. No manual. Lp. any ideas?
5 Suggested Answers
SOURCE: when we lite up the
the chimney pipe most be the same sides all the way out , it can not begin big and then small as it goes out. that's the problem with, your wood burning stove. it can be small and then big but not the other way around.
Posted on Dec 10, 2008
TheMobilian
  • 8220 Answers
SOURCE: Convert natural gas stove to LP
Nothing is imposible but this stove was not made to be converted. It is a not a classic crank down and flip model. Your best bet would be to get your LP gas supplier to do it.
Posted on Dec 15, 2008
  • 6 Answers
SOURCE: oven produces soot when running, broiler ok, stove top ok
Al, you need to seat the needle valve on the bake. Remove the bottom drawer, right below the bake burner you will see the nut just below the air shutter adjustment. Turn this nut clockwise a few times, it might seem hard but just do it. Then try the bake again, you should have a nice bluel flame. Tenbears.
Posted on Dec 20, 2008
TheMobilian
  • 8220 Answers
SOURCE: converting a stove from natural gas to lp
Crank down the orifices and flip the regular nut.
Posted on Jan 05, 2009
I am looking for a manual for an Atlanta Stove Works Homesteader Model 340ADG wood/coal stove that has been installed in a house I just moved into but has never been used.
Hello John,
Here is a manual for your stove, you can also call the phone number # 340ADG Here's a bit of history about your stove; Atlanta Stove Works there's even a PDF about a slightly different stove on this site.
Good Luck!
Rich Lilja
Jan 10, 2017 | Home
Model #26GCAB Atlanta Stove Works Franklin fireplace
Looking for specifications on Atlanta Stove Works wood stove burner model #2757
Aug 13, 2012 | Stoves Heating & Cooling
My 1994 egle vision is running rich. gasoline smells strong.Is it the fuel sensor?
There are several things that can cause it to run rich. You need to find out if there are any codes in the computer system, Turn the key on and off three times and on there third time leave it on and start counting the flashes that the check engine light flashes. One flash then twwo. Ignore that code wait till the next code starts flashing. Once you have that code you should be able to find out what sensor is acting up, Auto zone should have a book on your car that tells you the codes plus help you read the codes better. Hope this helps leave comment.
Feb 10, 2011 | 1994 Eagle Vision
Can fix Gas leak smell in GE Eterna stove: Model EGR3000EH1BB
If it was used with LP and you are using it with natural, did you change everthing back over to natural gas settings? Orfices, regulator cap, and oven orfice?
It could be a pressure issue.
Please let me know if I can assist you further.
Vic
May 30, 2009 | Kitchen Ranges
2000 Audi s4 has strong smell of gasoline
Pop the hood and check all the fueling lines, then check your gas tank and see if you just spilled some. Then check your exhaust pipes because you are probably running rich. You may need to change your spark plugs, or possibly a mass air flow sensor, or oxygen sensors. you should get either a vagcom to scan it or an OBD-II scanner.
Nov 16, 2008 | 2000 Audi S4
Smelling gas at when stove is in prelight then going away
Welcome tkrogers,
You said,smelling gas at when stove is in Pre-light then going away.
In some stoves this is normal as long as it is a slight smell and it goes away when the stove or oven ignites.
You know gas really has no smell, but this smell is added for our safety!!
What is the Make,year ,and Model number of your range?
The gas must start somewhere until the flame ignites it.
So we smell a slight smell of gas until it burns.
Thanks,
Huuum
Please remember to lave a solved rating before you leave.
Oct 11, 2008 | Frigidaire Kitchen Ranges
Idle low then hi, and gas smell, and bad gas mileage
This should show up easily on the ECU diagnostics computer at a mercedes dealership. Basically your fuel mixture is way too rich causing your car to be heavy on gas, have a raw gasoline smell, and not run right. Something like this can be caused by a defective oxygen sensor (but that usually produces a check engine light) or it might even be a defective ECU. There is really not way of knowing for sure until you do a proper diagnostics where they hook up your exhaust at the same time and do an emmission test. In most cases it's some sensor that needs replacing.
Aug 28, 2008 | 2006 Scion tC
Kitchen Ranges Logo
67 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Tony Houde
Tony Houde
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
