Question about Asko W6021 Front Load Washer
Asko W6021 power is on, hear start click, but won't fill
Washer was working fine but on last wash, programme was finished but door would not open. Followed instructions to manually open door and successfully did so, but on trying to start next load of washing, it would not fill: the power is on and you can hear the click after pressing the start button, but you do not hear it starting to fill.......
  • 3 more comments
  • axelsen Apr 12, 2009
    Thanks. We have had no problems in the last 6 yrs.....I have also since read other problems which sound similar and the responses are fairly consistently to replace/check the carbon brushes. What are your thoughts on this and can you pls help to priotise the check list.
    (We already checked and there is no problem with the water supply/inlet.)
    How do you get to the tube/pressure switch and carbon brushes?
    We live in a remote area and parts will take a while to get.....
  • axelsen Apr 15, 2009
    Service-engineer has found the circuit-board to be the problem.
  • axelsen Apr 19, 2009
    hmmmm..The Service Eng said it was the connection between the circuit board and the drainage pump....he applied his connectors and there was no current flow though that part of th cicuit Board there appeared to be a burnt look too. ....(unfortunatley he prtomised to give us a list of parts before he left on holiday ,....FOR 2 WKS!! - but didn't) How much is this to replace - is it expensive enough to warrant replacing a 6 yr old washer? Where can you order the parts?
    Forgot to mention - we had already checked the inlet valve etc. We cleaned the screen, checked the water pressure etc
  • axelsen May 07, 2009
    The link to www.repairclinic.com was great, the replacement circuit-board cost $300 plus $150 shipping and duty to Bermuda, plus $150 for the service-engineer to install, total $600 and we got a brand new Asko W6022 machine for $800! The old machine gave us 8 years of fantastic, fault free service :)
    Novelist:
  • 151 Answers
Yes.the circuit board is faulty.and the service technician gave you the proper advise.the cost of new circuit board is near to 30% of the cost of new machine.
so if the machine is too old.think twice before ordering the new board.
you can get the new board at
please do rate the solution.thank you for using fixya.keep updated.thanks.
Posted on May 04, 2009
  • 297 Answers
Which country you live in ?
Posted on Apr 19, 2009
    Genius:
  • 1,847 Answers
If it doesn’t fill, the water inlet screens may be blocked, as you hear the click that mean the magnetic valve is opening, but something is blocking the water to come in. I dont think it is the control panel.
This is issue with :-
  • Water mixing valve
  • Water mixing valve filters
  • Water temperature switch
  • Water level switch
Let me know if you need further assistance.. Thanks
Kevin
Posted on Apr 15, 2009
  • 916 Answers
Replacing the carbon brushes is the way to go.
In order to get to them you will have to remove the motor from the machine and then you will have easy access to them. They are situated in the motor under the outer drum these are held in by 2 star screws and are covered in a plastic casing if under 8ml in length. Once you replace them you should be up and running.
Thank you for using FixYa! Please Rate!
Posted on Apr 12, 2009
  • machadojr_fe Apr 13, 2009
    Let me know if this does not solve your problem
  • 190 Answers
Dear customer,                              When a washer doesnt fill with water then i recommend you do the follwoing checks..
  1. Check that the water supply valves are turned on
  2. Inspect the water supply hoses for kinks
  3. Check the filter screens
  4. Test the water level switch
  5. Test the water temperature switch
  6. Test the timer control
  7. Test the water inlet valve
for details on how to check the components jus click on the "blue" colored words or please refer to the following link
http://www.acmehowto.com/howto/appliance/washer/washer.php
Your queries are most welcome. Thank you..
Asko w6021 started to fill with water and then shorted out the power any suggestions?
not much help sorry but is possibly the motor shorting, try turn the drum a little before you reconnect and see if it still shorts. I have had an element rupture and therefore be soaked in water and thus causing the short. Sorry I cant help more
Mar 04, 2013 | Asko W6021 Front Load Washer
My ASko washer machine will not start up, all I hear is a short humm when I press the start button. I took the cover off and noticed the control board has a burned chip on it. There is also a resistor with...
Sounds like the control board is fried. If you have gotten it open here is a link for a new board:
http://www.superiorapplianceparts.com/shop/asko-washer-control-board/?q=/shop/category/washer/asko/
Good luck! And make sure the thing is unplugged before you work on it!
Joseph
Apr 04, 2011 | Asko W6021 Front Load Washer
WASHING MACHINE WILL NOT START
check motor it may need cleaned and oiled, or it might be bad.
Apr 04, 2010 | Asko W6021 Front Load Washer
Asko washer w6021 doesn't work. I've checked
See whether water is flowing into the wash machine. Then the door close switch.
Mar 28, 2010 | Asko W6021 Front Load Washer
After a power serge caused by the local power authority we can not open the door to our ASKO W6021 - we have washing locked in the machine and want to take it out before the machine is taken away to be...
prise open the samll square door at the bottom left using the divider in the soap drawer. Once open extract the red loped handle and pull on it ot manually open the door.
Apr 03, 2009 | Asko W6021 Front Load Washer
Can't open door of front load Asko washer 12225
Open the little door on the lower left corner of the front of the machine, and pull on the red tab in there. door will pop.
Oct 16, 2008 | Asko W6021 Front Load Washer
Asko W6021 won't start
change the carbons theres nothing wrong with the board
Jul 30, 2008 | Asko W6021 Front Load Washer
Asko W6021 Front Loader Washer Problem
the carbon brushs in the motor need replacing,on the w6021 the fault you get is a clicking sound when you press the start button.
Nov 01, 2007 | Asko W6021 Front Load Washer
Asko W6021 Front Load Washer Logo
163 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
