Question about Garden
Grinding wheels for model LR 36941 Type FL6 sharper
Looking for a source for the above grinding wheels.
    Problem Solver:
  • 3 Answers
How do I stop the grinding when starting 2000 Astro Van
Hello Anonymous...
To inspect the teeth on the ring gear requires the inspection to check the full 360 degrees of the ring gear. Looking past the inspection cover to examine a small portion of the ring gear may reveal no issues, but only for that section. Eventually the ring gear will end up positioned above the starter drive gear which will skip across the bad teeth creating your grinding noise when you try and start the Astro,.
Apr 26, 2017 | 2000 Chevrolet Astro
2004 dodge 1500 2x2-sparadic grinding noise when
it sounds like a wheel bearing also make sure the tire is not rubbing the fender wall to
Mar 07, 2010 | 2004 Dodge Ram 1500
Maytag neptune tl makes grinding sound and stops at 33 minutes in normal mode and at 24 minutes in quick wash mode
Hello djlampl,
With the lowest spin cycle setting I enter spin cycle in Quick Wash around the 21 minute mark. But first question is do you hear the grinding noise with the tumblers rotating during the wash/agitate cycle?
If you start a spin only cycle do you hear the grinding noise?
Does the washer error code out with an error code to the display? Codes such as dC, uC, Lr?, I assume the machine type is a FAV6800AW is that correct?
Any additional info will help in troubleshooting…..Rich
Assuming the machine type is a FAV6800A/FAV9800A here are some handy links;
The Service Manual for reference. Sears Parts Direct for reference.
Nov 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My two year old flymo self prop. rotary mower is now making a grinding and screaching noise coming from the drive box how do i get the rear wheels off , this model is the large rear wheel type model...
Have you tried looking at www.flymo.com. Select the country you are in. Looks like you are going to need to find a different model number to find whatt you are looking for. But maybe this site will get you headed in the right direction.
Good Day.
Sep 10, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Manual for Efco FL6 Chain Sharpener
The chain saw chain sharpener is an "efco Industries" chain sharpener that was made in Italy. Type # 136 & LR# 36941 have a good day please rate bama46, thanks
Aug 22, 2009 | Garden
04 cavalier makes grinding noise in front end turn the wheel to the right grinding gets worse turn the wheel to the left grinding stops. it sounds worse at 40mph and above. what would cause this?
3 things to check:
Worn disc brake pads, grinding against the rotor.
Wheel bearing
cv joint.
You posted grinding gets worse turning to the right, the problem is the driver side wheel, but it would be best to have both wheeles checked.
Jun 19, 2009 | 2004 Chevrolet Cavalier
Grinding while turning
shuddering while driving means you should have the front wheels rebalanced. as for the grinding that could be a wheel bearing or ball joint going bad
Jun 10, 2009 | 1998 Jeep Grand Cherokee
Grinding noise in front of car
You have shattered the wheel bearing.New one required
Mar 31, 2009 | 2004 Jaguar X-Type
Garden Logo
196 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
