Question about Cameras
My brand new Nikon Coolpix S9500 will not charge and will not turn on. I plugged it in to charge after using it for one week on vacation and the battery drained instead of charged. When I got home the battery was dead, so I plugged it in and the light flashed and then after 4 hours, it still hadn't charged. Now, despite either leaving it unplugged or plugging it in (in the order as instructed in the manual), the camera neither turns on nor charges and now the green light doesn't flash either. HELP!!
I had this problem, and like a dunce just needed to read the directions more clearly. manual indicates that the cable needs to be plugged in by a certain order. see page 14 of the manual. can't believe that was all that was necessary to clear all my frustration!
http://www.nikonusa.com/pdf/manuals/coolpix/S9500S9400RM_EN.pdf
hope that helps!
Posted on Jan 24, 2014
SOURCE:
SOURCE: Battery Dont Charge
jpierre's solution (in another thread) was right on the money. Touch the positive (+)end of the 9v battery to the positive (+) end of the camera battery.Leave them touching for a few seconds (10 seconds should be more thansufficient). Seems these lithium-ion batteries are subject to a'digital memory.' Subjecting it to a volt surge almost three timeshigher seems to clear it.
http://www.batteryuniversity.com/parttwo-34.htm
In short, it works like a charm.
Posted on Oct 01, 2008
byron21
  • 151 Answers
SOURCE: Kodak EASYSHARE M1063 won't turn on
For this problem try doing the following:
  • remove the battery and the memory card
  • clean the metal copper on the battery
  • power on the camera without the memory card
If problem persist call the 18002356325 for technical support for KODAK Digital cameras
Thanks
Hope this will help
Posted on Sep 23, 2009
  • 7 Answers
SOURCE: Battery will not charge
I found this while searching to find an answer to solve my problem. It worked! Some say that it took them about 20 times... it took me about 7. Be patient and just keep trying! Hope this helps!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
Posted on Aug 05, 2009
SOURCE: when i plugged it in for the first time to
I faced the same problem too. But I realised that after plugging in the adapter and connecting it to the camera, you would need to press the power button but not turn it on.
Posted on Jul 02, 2010
giggleboxgir
SOURCE: s3100 will not charge using
Did the new battery work? I'm having the same problem.
Posted on Jan 02, 2012
Nikon coolpix s9500 no power and not charging battery is new
Step 1) plug Charger adapter into mains. Step 2) Plug cable into camera. If you have the cable plugged into the camera and then plug it into mains it will not charge.
Sep 27, 2016 | Nikon Inc Nikon Coolpix S9500 - digital...
Nikon coolpix no power even a new batteriy
New batteries still require a FULL charge. (unless they are not rechargeable)
Nikon COOLPIX S5200 will not charge or come on.....almost new!!! :(
You need to return it for a replacement while it is new. Try returning it to the store for a replacement first. If they won't replace it, contact Nikon. Never try to fix a brand new item. It will void the warranty.
Oct 01, 2014 | Nikon Coolpix S5200 16 Megapixel Digital...
Cannot select the wi-fi network on
The Wi-Fi connection requires installing a Wireless Mobile Utility to the smart device prior to use. And the Utility must be On.
Compatible OSs: iOS 6.0 or later, Android 2.3 or later
The Wi-Fi connection will be disabled if:
  • The battery charge is low
  • A memory card is not inserted
  • An Eye-Fi card is inserted
You can consult the user manual for further troubleshooting at:
Nikon COOLPIX S9400 S9500 Reference manual Nikon Knowledgebase
Aug 30, 2014 | Nikon COOLPIX S9500 Digital Camera Deluxe...
Will not charge
Sounds like you have a bad battery. Check your users manual for how to change it.
May 01, 2017 | Nikon COOLPIX S9500 Digital Camera Black
Flash won't retract
There is nothing you can do to fix this, it should not affect daytime photo taking.
May 03, 2017 | Nikon COOLPIX S9500 Digital Camera Black
Flash won't retract
Page 27 of the user manual says:
Lower the flash by gently pushing it down. When not taking pictures, lower the flash.
The manual is online with Nikon USA. but here is the picture of that page. See bottom of the page.
Jan 11, 2014 | Nikon COOLPIX S9500 Digital Camera Black
Memory contains images
You're in playback mode and haven't taken any pictures. Put the camera in photo mode or video mode.
Jul 25, 2013 | Nikon Inc Nikon Coolpix S9500 - digital...
Nikon Coolpix won't charge no matter what
The internal battery, which is kept charged by the removable battery, has probably run down. Take it to a repair facility.
Apr 25, 2017 | Nikon CoolPix S4150
Nikon Coolpix S8100 battery won't charge
I have had mine for over 3 years and this just started happening. I bought a new battery and it seemed to fix the problem for about a week but is doing it again. It seems like it won't fully charge now like it formerly did!
Apr 24, 2012 | Nikon Coolpix S8100 Black Digital...
Cameras Logo
3,768 people viewed this question
Top Cameras Experts
Damen Wong
Damen Wong
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
