Question about AB Soft Jasc Paint Shop Pro 8 for PC
No default printer???
I have Paint Shop Pro 8. When I use Print it works fine. When I try to use Print Layout it tells me I don't have a default printer installed. I do! I have a HP Deskjet 6940 and it is the default printer. I'm running Windows XP SP 2. Have 1 gig ram, AMD Athlon 64 processor 3800+ 2.41 ghz. Thanks for any help.
Try re-installing Paint Shop Pro V8. You will have to uninstall it first. Because that is the way I have found that it reloads the program correctly. I have just had this problem today with my copy. I hope this works for you.
Posted on Jul 21, 2010
When I load paint shoppro x2 it closes worked fine
try to clean your registry or try to reinstall the software it may have some corrupted files
May 06, 2010 | Corel Paint Shop Pro Photo X2 Full Version...
Can't change printer in Corel Paintshop Pro
It sounds like this is a laptop because you mention different networks. If so, this is not a bug in the program. If you are completing a file on one network, choose the printer before you start. If you are changing networks, you need to remember to change the printer when you open a file. Use Print Preview to see if any adjustments are necessary.
This extra step is needed to have the flexibility of working with different printers,
Jul 29, 2009 | Corel Paint Shop Pro 9
HP Printer C4280 says "USB not connected"
Install software that is twain compliant.
Maybe the HP bundle that came with the printer.
Also Paint Shop Pro,Adobe Acrobat.Photoshop etc.
Use the usb cable after the install of the HP drivers then you may change the default location of where scans are saved.
Jul 21, 2009 | HP Photosmart C4280 Aio Printer
Corel Paint Shop Pro X will not respond or open
Please inform corel from the internet and tell them that you purchased the 2007 version of paint shop Pro. tell them that you needed to install back unaccessed software.
Thanks.
Jul 09, 2009 | Corel Paint Shop Pro® X Full Version for...
Change printers problem in Paint Shop Pro 9
probably the best solution is to set your windows default printer to the one you want to use.. then when/if you print in windows select the other printer.. just a quick thought
May 19, 2009 | Corel Paint Shop Pro 9
Paint Shop Pro 9 Printer Selection (no options available)
There is a workaround which will be suitable for those who use Print Layout in PSP instead of just Print.
With your image open in PSP, goto >File >Print Layout.
Now in the Print Layout screen, goto >File >Print Setup (or just click the Printer / Page Setup Icon).
The Print Setup window will now appear with just your default printer displayed. There should be a Print Setup button next to the Properties button, but it never appears in Vista. You can, however, still access it.
Just press 'Alt-P' and the small print setup dialog box appears, allowing you to choose a different printer!!! happy.gif
Jan 08, 2009 | Corel Paint Shop Pro 9
PSP X2 Ultimate Not Responding
Hi, I got a fabulous response from Corel and it fixed my same problem! Here is what they sent me. The first step did not work alone, but may have been necessary for the second step to work properly. Good luck!
We are working on a permanent fix for this issue. Use the following workaround to allow launching of Paint Shop Pro Photo versions X1 or X2:
Delete or rename the Paint Shop Pro Photo XI database file: ImageDB.db.
Database file locations
On Windows XP: C:\Documents and Settings\<username>\Application Data\Corel On Windows Vista: C:\Users\<username>/AppData/Roaming/Corel Here are instructions to easily delete the ImageDB.db file.
  1. On XP systems, Go to Start | Run. On Vista systems, Click on Start button and then highlight the "Start Search" field.
  2. Type %appdata% and click Ok (or push Enter on keyboard on Vista systems).
  3. Double-click on the Corel folder.
  4. Delete* the ImageDB.db file and then close this window.
You should now be able to successfully run Paint Shop Pro Photo. *NOTE: if you receive a message that the file cannot be deleted or is in use, Restart the computer, then immediately try deleting the file. It should delete fine after a restart.
If Paint Shop Pro Photo X2 still hangs or is slow responding, try the following: Do the following to delete the Paint Shop Pro Photo X2 Database files. The program will recreate the files upon next launch. First Close Paint Shop Pro Photo X2 if is it running.
  1. Go to Start | Run, Type %temp% and click Ok. (on Vista, click Start button, then highlight Start Search. Type %temp% and then push enter on keyboard)
  2. On the Windows® Explorer Tool bar, Click the Up Folder button. The Up Folder button looks like a folder with a green arrow pointing up. If you don’t see it, Click View | Go to | Up one level. (On Vista, click Organize | Layout | Menu bar. Once displayed, go to View | Go to | Up one level).
  3. Double click on the Application data folder. NOTE: The Application Data folder is a hidden folder. Make sure you have enabled viewing of Hidden files and folders to see this folder. We have included instructions* below for enabling this view.
  4. Double-click on the Corel folder.
  5. Delete all content in the Corel Folder and then close this window
  6. Try running Paint Shop Pro Photo X2 again and note how it functions.
* To enable viewing hidden files and folders do the following:
  1. Go to Tools | Folder Options.
  2. Click on View tab.
  3. In the large white area marked Advanced settings, check the "Show Hidden Files and folders" radio button.
  4. Click OK to accept this setting. You should now see the Application data folder as described above.
Dec 02, 2008 | Corel Paint Shop Pro Photo X2 Full Version...
AB Soft Jasc Paint Shop Pro 8  for PC  Logo
1,153 people viewed this question
Top AB Soft Computers & Internet Experts
David Payne
David Payne
Are you an AB Soft Computer and Internet Expert? Answer questions, earn points and help others
