Question about Pioneer Audio Players & Recorders
I own a Pioneer stereo double cassette deck (CT-W820R). I put a tape in Deck 1 and it is stuck in there and I can't open the door. The counter lights for both decks are flashing. I've turned the power off and back on, tried to press the stop button and nothing happens. Nothing seems to be responding.
  • Pioneer Master
  • 19,396 Answers
The cassette tape is probably wrapped around the traction wheels inside the deck.
Also the cassette may have gone out of the deck door guides on the sides, this may prevent the door from opening.
You need to push the cassette inside with door partially open using a screwdriver, and re fit the cassette inside the two guides at the sides of the door.
If this does not work you may need to take apart the deck to remove the tape.
Posted on Apr 12, 2009
Pioneer CT-W208r won't eject tape.
These dual cassette decks were throw away units in most cases. The belt inside and the grease in the cam mechanism is in bad shape and the deck can not cycle through the steps it need to so as to reach stop. Only stop mode will allow the door block to release. The tape can safely be extracted by a Technician. The deck need work. Dual cassette decks are not always worn the repair cost.
Dec 23, 2013 | Pioneer CT-W208R Single Cassette Deck
Where can I buy Pioneer CT-W701R Stereo Double Cassette Tape Deck Riemen Belt
If the methods listed in the manual won't open the door, then the tape is not inserted properly. Insert a golf tee in one of the two small holes below the tape door and slightly adjust the position of the tape up, down, or sideways. Then press the eject button and it should open. This will only work if the belt is OK.
Apr 26, 2012 | Pioneer Audio Players & Recorders
Pioneer Stereo double cassette deck Ct-W302R - is it repairable?
They might be repairable but usually at a cost that exceeds it value. Who wants to pay $150 to fix what was known as a throw away tape deck? Not many. It might even exceed $150 as they are complicated to repair bot being designed to be repaired.
Mar 22, 2012 | Pioneer Audio Players & Recorders
I need a complet set of belts for my Pioneer CT-W103 Double Cassette Deck.
Just measure the diameter of each belt (in mm) and then search with Google. Belts are generally not maker specfic.
Aug 15, 2010 | Pioneer CT-W103 Single Cassette Deck
PIONEER CT 670 user manual ,in need,thanx a lott
You can try to download the manual from the following site.
http://www.fulldownloadshare.com/finder/PIONEER+CT+670+tape+deck+manual.html
I am not sure how big it is, but you can at least look at it if you don't want to print it out.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Feb 08, 2010 | Pioneer Audio Players & Recorders
I have a Stereo Double Cassette Deck; Pioneer CT-W404R. I've set the REV MODE switch; I've pressed the record button; I press playback and the tape for recording begins moving, but not the other tape. If I...
I was following instructions for "Recording." On the next page were instructions for "Tape Copying," though the first page began with, "Load a tape for recording in Deck II." That sounded like what I wanted. Anyway, that was my error.
Oct 11, 2008 | Pioneer Audio Players & Recorders
CT-W602R Dual Cassette Deck- door won't open
Dear etu7diante,
The another way to release the cassette from the deck is by moving the flywheel manualy after opening the cover of the system. The system should be disconnected from the power supply. If you are able to to do this please let me know .later I can guide you to do the job.
ramesh22
Jun 09, 2008 | Audio Players & Recorders
Problem with deck B on Pioneer CT-W205R
Better tape decks, like Pioneer, may use a different mechanism for record/play than FF & REW. So it sounds like a belt or mechanical link for the REC/PLAY has failed.
Dec 20, 2007 | Pioneer CT-W205R Single Dual Cassette Deck
90 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
