Question about Durabrand HT-3915 System
Can't get sound throught one speaker
I can't get sound from my right front speaker. I took that speaker and connected it my front left and it work fine. How do I fix the connection?
  • Anonymous Mar 14, 2014
    how do I connect speakers
Did you get the solution for your problem? I am currently facing exactly the same problem. My front right speaker is not working when connected properly, but when I change its connections to left front, it is okay suggesting that there is nothing wrong with the speaker.
Murali
Posted on Oct 25, 2007
Just installed new front (Pioneer TS G4643R) and rear (Kicker KS4100) speakers in my 1989 S-10. The left front and rear speakers work great but the right ones are not so good. At low volume they both have...
It sounds to me like your wiring is having problems. An easy way to tell would be to switch your speakers around. Take the ones on the left that you know work, and place them on the right side. If you have the same problem, then that tells you the wiring is having problems. Another problem could be that the speakers are wired out of phase. What that means is that the positive of the speaker is connected to the negative of the radio or amp, and that the negative is wired to the positive of the amp. Do you have an external amp? Try switching them around, and let me know how that works for you.
Apr 11, 2011 | Kicker KS4100 4 x 10 Coaxial Car Speaker
I have a Fisher RS-909 Surrond Sound amplifier. It has no "sub out" jack. I had the sub-woofer working in the past by wiring it as shown in the manual. The problem is that the system was in...
Alright i had a chance to look over things, this is how you are going to hook up the sub. first we'll be connecting the surround sound unit to the sub woofer.
surround sound unit sub woofer
left front: positive (+) <-----to------------->(+) left speaker level in
negative ( - )<- - -to- - - - - - ->( - ) left speaker level in
right front: positive (+) <-----to------------->(+) right speaker level in
negative ( - )<- - -to- - - - - - >( - ) right speaker level in
now that the surround sound unit is connected to the sub woofer you will need to connect the front surround sound speakers to the sub woofer.
sub woofer front surround sound speaker
left speaker level out (+)<-----to--------> (+) left front speaker
left speaker level out( - ) <- - - to- - - - ->( - ) left front speaker
right speaker level out (+)<-----to--------> (+) right front speaker
right speaker level out( - ) <- - - to- - - ->( - ) right front speaker
Alright now that the wires are all over the place and plugged in
turn everything on and see how it sounds. let me know if everything is working as it should. if you need help with anything else or if something does not seem right please feel free to contact me via e-mail or phone
Mark Woodring
Feb 13, 2011 | Audio Players & Recorders
To install 4 speakers
If your car player has got provision for front and rear there is not issues. You can connect two speakers to the front and two to the rear. However if there is no connection you can connect the front right in parallel to the rear right and also the front left to the rear left.
If you want to use a tweeter use a bipolar capacitor of about 2.2mf / 50V in series with the tweeter to tbe connected to the left and right connections.
Jun 25, 2010 | Xtreme Sound WMS230 Cassette Player
Trying to install my new home theatre
Are you sure the wire is not damaged somewhere? Are you sure that you are connecting the wire to the correct terminal on the receiver? Is the speaker OK?
To test all of this, try different combinations. With Right speaker working, disconnect the wire from speaker and connect it to the left speaker. If it doesn't work, then the left speaker is faulty.
Now disconnect the wire from receiver's right-front terminal and connect to left-front terminal. If it doesn't work, you are either connecting to wrong terminal or the terminal/receiver is faulty.
At last, try using the "left" wire to connect the rigth speaker to right terminal. If it doesn't work, the wire is faulty.
P.S. The +/- doesn't matter for testing, the sound should go either. It is just needed to have all speakers connected in the same polarity, because else the sound waves would eliminate themselves.
Oct 31, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
Surround sound speaker outlets are not working
Might be a loose connection problem. A contact cleaner is handy in cleaning the terminals. Try to swap the speaker connections if you don't have a multi-tester to check the resistance of the speakers. If the right front speaker will sound after connecting it to the left front speaker output, then it is a speaker coil problem. If not, might be an amplifier channel problem.
Jan 12, 2009 | Durabrand 5.1 Surround Sound Computer...
DVD plays partial sound
Check your speaker connections it sounds like you have a 5.1 or higher sound system. 5.1 means left front speaker, right front speaker, center speaker, right rear speaker, left rear speaker and subwoofer.
Voices in movies all get channeled to the center speaker (you can usually hear it a bit from the right and left front speakers as well). If your center speaker is disconnected or not working, you will only hear the background sounds.
Sep 20, 2008 | Compaq Presario 5000 PC Desktop
Front left speaker problem
had a similar problem with mine so took the cover off and found a dry solder joint at the back where the speaker connecters join into the amp. soldered it up and is working perfect.
hope this helps
Aug 30, 2008 | Sony DAV-S500 System
Center and surround speakers work, but front right and front left speakers do not put out any sound
I had the same problem. Set the reciever on 6 channel stereo. On this setting, you should be getting the same sound out of each speaker. Isolate which speakers aren't getting sound. Now, on your speaker switch (the A/B button), select A. If that doesn't fix it, select B. If that doesn't fix it, try A and B (if you can on your reciever).
Now, when you switch back to pro-logic, make sure your a/b channel switch is in the position that worked in 6 channel stereo. Yamaha recievers have a memory, and when you switch various modes, it makes auto adjustments based on what you had set in the past.
Hope this helps
Dec 21, 2007 | Yamaha HTR-6030 Receiver
One speaker not working and Scratchy Audio
just check is there any loose contact frm that speaker connection plug out the cable connect it again and have a check it may work...
or may be any time the speaker may be falled on ground so may be there is problem
Nov 23, 2007 | Gateway GMAX 5100 Computer Speakers
Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
May 01, 2007 | Onkyo HTR500 Receiver
Durabrand HT-3915 System Logo
130 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
