Question about Olympus FE-140 Digital Camera
No flash The flash on my camera refuses to work, Even when I set it for mandated flash it doesn't work. The camera works fine in every way. Could the flash element have burned out??
    Problem Solver:
  • 8 Answers
Yes the flash element could have burned out, or if you droped the camera it could have been damaged depending on the way it hit the ground. Sorry but I do not know how you would go about fixing it. Good Luck! I hope you get it fixed!!
Posted on Sep 10, 2007
SOURCE:
Pilot light not lighting on 420ex speedlite canon flash
This may seem dumb to ask but have you made sure all batteries are fresh (even new ones can be bad), they\'re inserted correctly observing polarity and the contacts are clean in the flash? (You can clean them using a clean, dry pencil eraser and a Q-Tip dipped lightly in alcohol.)
Also, try mounting the flash on your camera, turn both on and reset your camera to factory default settings through your camera menu settings.
Feb 28, 2013 | Canon Speedlite 420EX TTL Flash
My Pentax Optio M90's Flash has stopped working.. it doesn't matter if I have selected the flash to be on or off it still won't work. Even when setting are set at auto it still won't work...
Hi kerritm,
This indicated that it's time you need to replace your flash , therefore you can get it done via a service center,
The camera's flash has a certain life and you can't expect it to be ok for many years together ,
In unfortunate cases , it stops working due to hard ware failure.
Therefore , Please get the flash replaced and you would be able to use it.
Hope this helps..:)
Jun 19, 2011 | Pentax Optio M90 Digital Camera
FUJIFILM FinePix S2500HD bought two months ago. Flash is now refusing to work. Please help!
Same problem with mine - bought in February, (now May!) flash doesn't fire. Indicator light flashes orange which the manual says means "flash charging" but still no response despite waiting for that to complete.
Hope this isn't a bug in this model... Fujifilm, where are you?
Nov 07, 2010 | FUJIFILM FinePix S2500HD / S2600HD Digital...
Samsung G600 works fine but the flash is out
Hello!
I suggets you get the camera changed there is a possiilty of it being faulty
ie damaged .
good luck
Oct 27, 2009 | Samsung SGH-D600 Cellular Phone
My flash does not work on my fuji finepix f50fd , i have fully charged my camera and still does not work, i have had camera for about 6 months, and flash was working fine up till now?
Are you sure you don't have the flash suppressed? Somewhere on the menu it should have a flash setting. It can get set to suppress so that it does not flash even in flash conditions.
Aug 11, 2009 | Fuji Finepix F50FD Digital Camera
I have three new Metz 58 AF-1N's, and a Nikon
take a silver paper and put in front of the slave censer when you take the photo flash on camera as master should go on silver paper OR used slaveunit
Jun 30, 2009 | Metz 58 AF-1 FLASH f/NIKON TTL Flash
Built-in flash not working
Please shoot in P mode. In P mode it will use the flash if you pop it up and not use it if it is down.
The flash uses LOTS of battery power. If you battery is weak the flash may take a long time to recycle (charge).
The Flash must be popped up and READY before you can use it. The flash is charged or READY when the RED light is on.
I hope this helps.
Apr 03, 2017 | Nikon D60 Digital Camera with 18-55mm lens
Olympus 1030 sw -Flash doesn´t work anymore
Have you tried to reset the camera to the factory defaults? To do this: have the camera in shooting mode - go to Menu - left arrow to reset - press ok - Highlight Yes and press ok. This will reset the camera to factory settings. See if flash works now.
Feb 11, 2009 | Olympus Mju 725 SW Digital Camera
Flash not working
pop up the flash and you can select flash mode by pressing the arrow like button press right to select the flash mode....
Jun 16, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
Olympus FE-140 Digital Camera Logo
87 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
