SOURCE: KX-DT333 - Flexible Button (programmed
It probably means the phone is in Do Not Disturb. There's a programming option to make it not do that. Check out the installation manual for your phone system.
Carl
SOURCE: How to change thie ringtone on a panasonic
Press PROGRAM and the button twice (intercom or CO) then dial a number 01-30 or use the Navigator bar if you have one. The tones will change. 01 is the default, 21-30 or so are tunes.
Carl
SOURCE: I want to change me
What happens when you dial 500 on the intercom?
Panasonic has 2 voice mail systems that operate on the TDA/TDE/NCP system. By default, the voice mail extension is 500. If you dial it, the system will answer and you can follow the prompts to record and change the greeting.
If your voice mail is embedded, then you have some oher codes like *382 to play it back and *381 to record a greeting.
Carl
SOURCE: Cant' change Date/Time on my
It's unlikely that the 321 is connected to extension 101 so there's not much you can do about the time from it.
Go to the 343 or 363 phone at ext 101 and press PROG and dial **1234 000. It's the time set command. Use your FWD button to get to the proper time and the ENTER command to save it.
Carl
SOURCE: I am having trouble setting
What's the statlus of your FWD key? Try dialing on the intercom *7105 xxx Where xxx is the number you use to call voice mail (either 500 or 165 normally).
Carl
