Haier HD656E Dehumidifier
Problem for Haier HD656E Dehumidifier
Dehumidifier Brand haier HD456E does not pull
By funcrgirl on Apr 12, 2009
Dehumidifier Brand haier HD456E does not pull water and the tank is empty, after 24 hours of running with water on wood floor. Can't find manual or online info for this model.
Same Problem
May 24, 2009
-   I have the same problem. It does not pull water out of the air.-   Fabfitz4
May 16, 2009
-   Exact same problem....runs, but not water being pulled. Help!?-   DBADMIN
May 06, 2009
-   Mine worked fine for almost 3 months then it just isn't pulling water out of the air. No water at all accumulating in bucket?????Help-   Guest
Best Solution
posted on May 20, 2009
Helpful)
goldenwheel
Rank: Apprentice
Rating: 94%, 8 votes
I have 3 HD656E Haier Dehumidifier with the same problem runs but no water in bucket. How many did the Haier company make with this problem?
Was this helpful?
Yes
No
6 people thought this was helpful
Solution #2
posted on Aug 28, 2009
Not Rated)
DCheck
Rank: Apprentice
Rating: 0%, 0 votes
I just received a unit with the same problem. Seems to be a lot of them out there like it. The problem is the compressor or a refrigerant leak. The compressor runs and feels warm/hot but no refrigerant is being pumped through the fin coils so they don't condense any moisture on them.
The unit has a one year parts and labor warranty. If it's still under warranty, make arrangements to get it repaired or replaced by calling the "Haier Customer Satisfaction Center" at 1-877-337-3639. The compressor and refrigeration system has an additional four years of warranty on it, but you have to pay for the labor to repait/replace it. Not worth the trouble.
If it's past the one year mark, recycle it and go out and buy a different brand. This one apparently sucks.
Was this helpful?
Yes
No
Popular Solutions for Haier HD656E Dehumidifier
Questions and Unsolved Problems for Haier HD656E Dehumidifier
Do you recommend Haier HD656E Dehumidifier?
Answer
Answer
My hd656e comes on put the display will show low then the machine shuts down. I have moved the... (More)
Answer
The motor runs but it doesn't pull moisture. What should I do?
Answer
The power is on but the fan or motor is not turn on. I switched tempature so it'll click on auto but... (More)
Answer
my haier dehum blows fuse I believe its uin switch reasds short
Answer
It stopped working. The only light that is on displays E1. The dehumidifer does not run. Tried... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Haier HD656E Dehumidifier:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
