Question about Ariston Technologies Ariston AWD12 Front Load Washer/Dryer
Leaky pump Had a plumber look at my machine (Margarita A1244C) And he cured a leak caused by an ill-fitting front filter, but he found a another small leak caused he thought, by the pump, which he said was now not available. He said that, providing that I didn't mind the small puddles it would be OK to use. But I would prefer to have it put right. I appreciate, that by todays standards that it is getting on a bit. but as there is only me and EVERYThING gets bunged in, whites and all! So of course, it only gets used at most, once a week. So I don't feel, even if I could afford it, to shell out for a new one! HELP!! Ken
    Brigadier General:
  • 3,917 Answers
Hi ,
Please verify the model number as there is no model found in the catalogue Margarita A1244C. Also is it a dish washer or washing machine.
Thanks
Posted on Apr 13, 2009
Water leaking in front load washing machine
In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Replacing Door seal: http://www.espares.co.uk/advice/washing-machines/a/7/1464/how-to-replace-the-door-seal-on-a-washing-mac.html
Mar 20, 2013 | Washing Machines
Leaky washing machine LG
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Check for tips on the link below to identify parts and removal:
Jan 16, 2013 | LG Washing Machines
Water from vent
Dec 30, 2012 | Kenmore Elite 45986 Front Load Washer
Maytag washer sav205daww leaking water from bottom of washer when runinning
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.Also check on this link : http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Jul 02, 2012 | Maytag Washing Machines
Washer leakes from front
Good Afternoon, Jataw42:
A leak from the front means a problem at the pump, or in the attached hoses.  A large leak means a hose has to be replaced, and a small leak means the pump has to be replaced.
Both are simple fixes, and these guys have everything you need.  Here are the parts:
#904568 for the drain hose from the pump  and #1304058 from the tub to the pump.
These are here:  http://www.repairclinic.com/Kenmore-Washing-Machine-Hose-Tube-Or-Fittings-Parts?s=b6a11c23p
The pump can be found here:
http://www.repairclinic.com/Kenmore-Washing-Machine-Pump-Parts
and the video instructions are great.
Good Luck to you!
Chr
Jan 22, 2011 | Kenmore 22422 Top Load Washer
Leak from filter pump on Whirlpool AWM6111
If it is just leaking from the filter front, then you can replace the filter and seal as a seperate item.
If this does not cure it, then the only solution would be to replace the complete pump assy.
Mar 21, 2010 | Whirlpool Washing Machines
Bosch2401 water leaking from a lower part towards
It is either the pump that is leaking, or the filter.
I would start by fitting a new filter, and if that does not cure the leak, then you are going to have to fit a new pump.
Jan 23, 2010 | Bosch WFK 2401
Smells like rotten eggs
The smell of rotten eggs normally means you have some water that has been sitting arround awhile and has gone bad. You may have to unplug your machine and remove the front cover to take a look arround the inside of your machine to see if any water has leaked out and has puddled up. You may also have something caught in the drain pump's filter, which may have gone rotten from sitting around too long. This filter is easy to unscrew and gain access to once you have the front cover off. Make sure you have lots of towels or a wet vac handy when you unscrew the filter cover.
Jul 26, 2009 | Kenmore Elite 45986 Front Load Washer
KHWS01PWH0 Front Loading Automatic Washer Leaking
out the bottom of door?? no through the bottom panel???. check the rubber door seal for rips or tears pull it back and look around entire circumference. smalll rip in very front of seal where door should close against will cause leak for sure
Mar 07, 2008 | KitchenAid KHWS02RMT 3.7 Cu. Ft. Ensemble...
Ariston Technologies Ariston AWD12 Front Load Washer/Dryer Logo
Top Ariston Technologies Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
