Question about Jensen's VM9312 Car DVD Player
Emergency brake wire connection
Jensen vm9312 car disc player emergency brake wire connection
    New Friend:
  • 73 Answers
Here's a Bypass to solve that. Turn your 9312 on and set to radio then Using your remote enter 543210 and make sure you hear a beep each time, a new menu screen will pop up, click the hammer and screwdriver on the upper left side,Next press the menu line for brake override, a sub menu will appear, select ON,Press the X at the lower left of the screen and you're done enjoy and be safe.
Posted on May 15, 2009
Can i run my pink wire on my jensen vm9312 to the ground
yes, that will bypass the safty feature and allow you to play a DVD while the car is in motion.
Note ; you can also just enguage the park brake ONE CLICK and achiev the same.
Nov 01, 2011 | Jensen's VM9312 Car DVD Player
Where does the pink wire on a vm9312 hook up to on a 2000 dodge durango
the pink wire is the parking brake wire... so should be hooked up to the paqrking brake...
OR , you can put a switch on it to bypass the safty feature.
Oct 07, 2011 | Jensen's VM9312 Car DVD Player
Since I do to visualize a dvd
CONNECT YOUR BRAKE SENSING WIRE TO THE PARKING BREAK WIRE ON THE LIL SWITCH RIGHT ON THE EMERGENCY BRAKE PEDAL
May 27, 2011 | Jensen's VM9312 Car DVD Player
How to by past the brakes wire for the dvd to play
According to the owner's manual, the pink wire is your parking brake wire and it has a label 'PRK SW' on it. It requires a negative signal to show that the parking brake is engaged. If it is currently hooked to your parking brake, you will need to trace it to where it is connected and remove it first. Be sure not to leave any wires exposed that can short out. Then connect the wire to a source of ground. this can be the black wire coming from the head unit, or a convenient screw nearby that is mounted to the vehicle chassis.
The manual can be found here:
http://www.crutchfield.com/S-x3LxzvPnGLv/p_110VM9312/Jensen-VM9312.html
Please note that it is likely illegal to have video playing where the driver is in view of it. Check your local laws before considering making this modification.
Feb 16, 2010 | Jensen's VM9312 Car DVD Player
Where do I hook up the pink wire in a 95 Toyota
if the pink wire mark to brake just connect to a straight ground or to a switch to a ground in put to switch
Sep 15, 2009 | Jensen's VM9312 Car DVD Player
My radio is installed but the sound only works when I step on the break pedal. What did I do wrong???
It shows up in the post on my PC.... how about this?
But it sounds as if we are on the same page - so far - anyways.
Next is to verify the subject of this post is - in fact - your radio.
You have listed the Jensen VM9312.
Is this correct??
Mar 26, 2009 | Jensen's VM9312 Car DVD Player
What is the color of the memory wire to a jensen vm9312?
jensen vw9312 manual
in the manual the YELLOW wire would be connected to a full time (unswitched) battery positive connection to retain memory .
J5
Jan 21, 2009 | Jensen's VM9312 Car DVD Player
How do i bypass the emergency brake wire on a dual xdvd700
Its illegal to do but i have done it! You have to connect the brake wire to either the pos or neg wire! You need to find out which one it is thou, so attatch it to the negative first so you dont cause any damage if it doesnt work then connect it to the pos wire and it should work a treat for ya! I stress connect to neg first!!!!!!!!!!
Jun 13, 2008 | Jensen's VM9312 Car DVD Player
Jensen VM9312 Bypass Code
trust me that works i just installed this deck in my truck today. And no you dont have to do anything with the ebrake wire at all just cut it off. Make sure you hear the beep sound when you hit 543210 you should hear it each time.
Apr 16, 2008 | Jensen's VM9312 Car DVD Player
JENSEN VM9312 CAR DVD PLAYER HOW
go to am/fm
then open the settings screen
next on your remote type 5,4,3,2,1,0 listening for each beep
a new screen should come up
after that look for brake override
Mar 19, 2008 | Jensen's VM9312 Car DVD Player
Jensen's VM9312 Car DVD Player Logo
362 people viewed this question
Top Jensen's Car Audio & Video Experts
Richard Foster
Richard Foster
afairman1927
Jose Velazquez
Jose Velazquez
Are you a Jensen's Car Audio and Video Expert? Answer questions, earn points and help others
