Question about Indesit WA 115 Front Load Washer
Wil163 3 lights flash mid wash
I have the model wil163 half way through te wash the 2 lights next to the power light an the power light all start to flash and it just keeps taking water and draining at the same time
    New Friend:
My machine starts filling with water, then the power button and the two next to it start to flash, and the water starts to drain from the machine.
Posted on May 25, 2011
  • 82 Answers
Is the drum turning?
At a guess it's not and i guess the motor has failed!
Hope this helps
Posted on Jun 25, 2009
SOURCE:
Why is heated dry blinking?
FIXED Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry ...
www.applianceblog.com/.../40588-Kenmore-dishwasher-lights-flashing-...
Aug 26, 2013 - 10 posts - ‎3 authors
Thread: Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry" ... A few months ago, we had a brief power outage and the next morning, noticed the "Hi Temp" and "Heat Dry" lights were flashing. ... Well since then, the dishwasher intermittently stops mid-cycle and these same lights ... Thread: GE Eterna QuietPower 2 Normal and Heated Dry ...
Feb 24, 2012
Kenmore Elist 665 dishwasher Smart Wash red light ...
Dec 23, 2011
Heated dry blinking +17 times - ApplianceBlog
Nov 14, 2010
Heated Dry light blinking
Nov 7, 2010
More results from www.applianceblog.com
Why won't my dishwasher start and why does the "Heated Dry"
www.shopyourway.com > Manage My Life > Questions
Nov 16, 2009 - When I hold down the Heated Dry button to turn the control lock on it ...my dishwasher start and why does the "Heated Dry" light keep blinking ...
Dec 01, 2015 | Dishwashers
Washer stopped in mid wash. Clean light came on and flashes 7 times. Pressed clear went to 2 and finished. Pressed start light flashed 3 times won't start.
remove the bottom kick panel,you'll see a tech sheet there in the plastic bag,it will tell you how to check to see if the heater or board is bad,the light will flash 7 times,it's an error code telling you that there's a heat problem.
Feb 20, 2015 | Dishwashers
Indesit wib111
Hello!
This machine got also 2 hidden led's on the control panel, you must remove the top plate and see, there should lit up one or two led's on the control panel, but they are masked by the front panel, if you look down from top should see them. let us know which one is flashing in addition to door lock light. Usually gona flash the mid one, indicating an F08 error which means stucked heater relay / pressostat, but in reality in most cases means insulation problem of the heating element,
Feb 24, 2018 | Washing Machines
Whirlpool duet is stopping mid cycle and beeping
F3E2 error, Wash light flashes 3 times then 2.
Took off front lower cover, Found Manual!!!
Unscrewed filter and was so full of trash, clean and reassymbled and now works just like new. Simple fix no parts at all needed.
Jan 03, 2013 | Whirlpool Washing Machines
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
Door locked light flashing when door is closed
push on the door where the lock is... it may not be fully locked.
Feb 22, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Two Green Lights Flash Mid Cycle.
It's possible that there's a fault in the drying heater coil, but I couldn't tell you for sure without looking up your machine. If you could locate the model number tag on your machine and write down the exact model number and serial number, then I could likely give you a more informative answer. ;)
Aug 08, 2007 | Kenmore 24 in. 15252 / 15254 / 15259...
Indesit WA 115 Front Load Washer Logo
803 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
