Question about iRobot Roomba 560 Robotic Vacuum
Irobot roomba 560
Will only run for a few minutes and says please remove and clean brushes...also makes a thumping noice...funny how exactly 1 year after purchase this occurred. bought new brushes...they sent wrong ones...got new brushes....same problem...well after inspecting it closer...and hand spinning as this site suggested...the squeegy (?) brush was popping out...thus the thumping noice...i took off that....seems to be running fine with out it. nothing was rubbing it. so i cant understand why it keeps popping out...any other suggestions would be appreciated.
Ah ha!!! After cleaning the brushes umpteen times I worked out that you have to remove the very small yellow pieces (not the other ones which sit on the end) but the ones right on the end and look for hair that is caught on the spindle. No more clicking noise either!
Posted on May 11, 2009
If you have pets, unscrew the side panel to the cage that holds the brushes. Inside there are many gears. Mine was completely at a stand still because there was so much dog hair. If this is unclogged, it will run like clockwork. Take out brush cage, unscrew the panel on the right side, clean gears.
Posted on Mar 07, 2011
I had exactly the same problem and picklers is 100% correct!!!!
Posted on Jul 01, 2010
Makes clicking noise and runs for a couple of minutes and then says error 2 open roomba and clean brush cage-do that and the same thing happens 2 minutes later
Pet hair often gets sucked into the gear box that drives the brushes and can clog it enough to generate this error. you need to remove the CHM (cleaning head module) and open the gear box on it to clean it out... you can also visit iRobots site and buy a new one that has been redesigned to avoid this issue.
Cheers, immorion
ps check out robotreviews.com for super detailed walkthrough of this process.
Nov 27, 2010 | iRobot Roomba 560 Robotic Vacuum
My roomba brushes have packed up
pull roller brushes out of bottom.pull off funny looking yellow ends on roller brushes.clean out hair ect. reinstall also good idea to pop out front wheel and clean
Aug 04, 2010 | iRobot Roomba 560 Robotic Vacuum
Roomba 530 makes a thumping noise every secondand stops with a message to clean he brushes. I have cleaned the brushes and filter but to no availe the thumping continues.
You also need to pull off the yellow bearings from the end of the brushes (one on the brush one and one on the rubber one) and remove hair from the axle there.
May 20, 2010 | iRobot Roomba 560 Robotic Vacuum
IRobot 560 Roomba making thumping/light clicking noise.
under warranty take it in for warranty repair or exchange
you try to fix it and the warranty is voided
just tip it upside down and check for threads wrapped around brushes and rollers / wheels
Nov 22, 2017 | iRobot Roomba 4210 Bagless Robotic Vacuum
Irobot stops after a few minutes and says plaes
soooo, what is not understood here ?
turn it over, open brushes cage, take each brush out and clean it.
In addition, also clean the sides from any dirt/hair that may stuck in its pivots.
good luck
Avi
Apr 07, 2010 | iRobot Roomba 560 Robotic Vacuum
Runs for awhile then says error 2 please remove and clean roomba's brushes i do then runs for awhile and says same thing no dirt on brushes?
I had the same problem. You must clean this parts and inside this parts:
Remove hair with cleaning tool
Remove Roomba's brush bearings
Clean Roomba's brush bearings with cleaning tool
Dec 29, 2009 | iRobot Roomba 560 Robotic Vacuum
New Roomba 560 beep twice, ask to clean brushes, but no dirt
your roomba is thinking that you need to clean the brushes. if too much load it put on your brush motor--the unit will think that something is wrapped around the brush and slowing down the motor. if you have cleaned your brush and are sure that is not the problem; you need to look for anything else that could be slowing down the brush/motor. If this is inconclusive you need to put your roomba into diagnostic mode by following the procedures in the link below http://swiftracer.com/index.php?myPage=RoombaDiagnosticMode.php
Jun 13, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
iRobot Roomba 560 Robotic Vacuum Logo
1,102 people viewed this question
Top iRobot Vacuums Experts
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
