SOURCE: 97 murcury mountaineer blows #10 fuse
check for a short by the starter exhaust melts these wires together good luck
SOURCE: How do I remove the door panel on a 1997 mercy
1st Remove the screws in the small panel behind the door lever and remove it. The door panel is held in by clips. Start at the bottom using a large flat head screw driver and pry across the bottom working your way up each side. then then lift the panel upward to remove it.
